Does seem more NW than CW (though I actually would prefer WW)
I was worried it’d be too floody but definitely not.
before testing, I was thinking I’d dedome (to make warmer and add throw) but i like it as is.
i suppose i’d prefer 2 levels for the red (with one being a bit brighter than the stock single mode) but i haven’t used the red with night adjusted eyes yet, and it still seemed sufficient. I guess I wouldn’t mind a higher white mode also…ie 2.5amps, but it’d just be for wow effect, so this is all just grasping for a dislike…
ordered from illumination supply - i think it was $53 shipped (coupon happyholidays), arrived in 3 days
Just received this clamp mount from FT after “just” one month waiting(with tracking number) .
Fits perfectly HC50.
One more handsfree way of using the headlamp.
I will use it to give some more light to my photos and when modding flashlights. Very nice desk lamp. 8)
It was easier for me to select that nitecore with my mouse right click and use the context menu to search the MSRP or to even type that long ass response to your lmgtfy link.
I mean the review is great but including a MSRP at start of review would be much better and put the light in ‘context’
2 batteries have higher total voltage and respectively the light will stay longer in regulation(will maintain constant brightness).
Shorter run time with two batteries.
The HC50 has no enough space for two protected 16340(RCR) batteries. CR123A,IMR 16340 or unprotected ICR 16340 can be used,but the CR123As are not cost effective.Using unprotected 16340 requires more care to their voltage.
I’m curious about the flood, my HL 21 is too focused, my HL10 is very nice, and my HP25 is nice on flood but too focused on throw, is this beam floody with no hot spot, or least a wide hotspot that blends in to the flood (spill?)?
I think it is good for reading and working. Sometimes I use my HC50 when soldering and I found it comfortable. I usually use a flashlight with attached diffuser.
FlashLion, jaw dropping pics man!! Great review too! One thing you didn’t mention in the OP is approximate tint of the light. Cool, neutral, warm. Thanks again
