The one on the right appeared to be an orange XR-E instead of red (did not even remember I had one ) so I decided to test the left one anyway, I figured that the colour would matter more than the chip lay-out. I would not think that Cree made one that performed completely different from it I guess...
It was a cosy test athmosphere :-) :
Here's a graph I made from the numbers, there's the voltage in it as well (should be close to Vf of the led), and the lumens, as calculated from my ceiling bounce lux-numbers. Do not pay too much attention to the actual lumen numbers, they do not tell a lot of the output 'power' with (close to) monochromatic light so far from what your eyes percieves brightest. Within this test they are a relative measure of output of course.
So 1.4 A is spot on for the maximum output
(and I had my bit of fun for tonight. That is not mad?.....or is it? I did not even destroy the led :-) )
the red XR-E does not exist. what you have there is a red xr-c. Check cree’s data sheets. The emitter on the left is a genuine cree, the one on the right is a counterfeit. .
The red xpe2 is what you should be looking at. The red xr-c puts out a whopping from high bin to low bin 23.5/30.6/39.8 lm/350mA, the xpe2 p3 73.9 lm/350mA. They can be safely driven to 1.4A after that, all you get is more heat and not more light which your graph does support. and if careful attention is not paid to the assembly you will get 20% plus drop in candela after only seconds. The red led’s have a very low Vf requiring the driver to shed alot of extra voltage creating heat that kills the light output.
Yes. MATCH’S graphs and data are one of my go to sources for modding hunting lights with color emitters.
@ OP the hs-802 comes in a few different forms much like the C8 you never know what your going to get. some have a nice brass pill some have an aluminum pill. There are huge differences between the brass pills also. I have measured over .070 in difference in height between several different pills measured. The final assembly requires shimming and filing to get the focus correct in the hs-802.
As delivered the hs-802 red puts out a dismal 8000Cd. My last hs-802 is putting out about 18,000Cd RED. You should be able to get close to that with a red xpe2 on a copper sinkpad at 1.4A
I tested that for a white XR-E some time ago, and there is some gain using copper, but not really worth the trouble, because the solder pad of the XR-E is so large already that the solderpad-board junction is not the bottleneck for the heat in the XR-E:
There's always new things to learn about leds, I did not know that in red, the xpe performs so much better than the xr(e or c), for white leds the gain is not that much.I'll have a look in my spare leds box if I have a red xpe somewhere, see how it tests in practice, but I fear I do not have one.
The red led that I tested was indeed bought as a XP-C, but because the die looks larger than the white XR-C die, in fact the same size as a white XR-E, I thought that they had send me the wrong led.
If I look at the fine details of the led that you mark as a counterfeit, I see no clues of that, I'd still guess it is from the same maker as the left led, so both are Cree or both are counterfeit from what I can make out.
I appreciate your input. I was questioning a red xr-e after not finding one on Cree’s site, but a google search shows others selling what they also claim is a red xr-e. Apparently, many vendors are misleading folks.
You also mentioned a red xp-e2. Do you have a source for those, preferably already mounted on a sinkpad?
Lastly, you mentioned focusing the light. Do you typically have to shim or grind on the reflector to get focus on these lights?
I have used the emitter that MRsDNF mentioned. They work well. They are mid bin xpe’s. In an HS-802 you could expect to get about 15,000Cd at 1.4A attached with AA epoxy, the Cd will drop to around 13,500 after a few minutes of run time.
Yes. almost always have to shim or file parts to get the the light focused for best throw/beam pattern. Manufacturing tolerances in the HS-802 are quite bad.
I have received the xpe-2’s in red(p3), and green(r2) from Mouser, along with 16mm sinkpads. Now it’s time for reflow soldering. But one question, how do I know which direction to put the LED on the sinkpad with respect to polarity?
Thanks to the help from y’all, I reflow soldered an XP-E2 to a sink pad, replaced circuit board with a 1400ma, and filed a little to get the LED into the reflector.
It is a huge improvement over factory!! Now I want to mod every light I have!
