12x CREE XM-L T6 LED Super Bright LED Flashlight
28 posts / 0 new
Richie086
Richie086's picture
Last seen: 6 hours 33 min ago
Hi folks,
I was polking around the internet and found this. It looks like they’ve finally did a 12X T6. I’ll have to think about purchasing this one, but my Skyray 9X T6 has been really excellent, so I may give it a try. Any thoughts?
http://www.epathchina.com/13000lm-12x-cree-xm-l-t6-led-super-bright-outd...
http://www.aliexpress.com/item/13000Lm-12x-CREE-XM-L-T6-LED-Super-Bright-Outdoor-Sports-LED-Flashlight-Torch/707185281.html
Richie
Edited by: Richie086 on 12/13/2012 - 09:01
joe1512
Last seen: 6 months 4 weeks ago
Wow. Pretty soon our high end flashlights are gonna look like the ole Showerhead 101 LED lights you can get at stores.
Wonder how hard its driven?
The big problem is this:
The triple XMLs like TK70 are driven at 3 amps on high. A 5 XML at 1.9 amps will be brighter even with the same wattage because of better efficiency at lower amperage.
BUT, XM-Ls have a pretty linear performance curve (lumens per amperage drive) up to about 2 amps.
So, driving 9 lights modestly, or 12 lights a bit less should produce the same amount of heat and light and use the same wattage.
In other words, theres little point to adding more XM-Ls past a certain point because more LEDs doesnt give you more efficiency.
I’d be willing to bet you wouldnt see ANY difference between your 9XML and this 12XML.
dthrckt
dthrckt's picture
they’re on ebay (just search 12x cree) and someone started a thread on the light here
my thought, shared by some others – we’ll see 18 next…look at the spaces in the reflector Smile
I love floody lights – but no way I’m spending $200+ on a crapshoot-fire
although – w/ 18x, one might be able to cram 2x of the KD 9x drivers in there and have a 130W ‘torch’, and 4×26650 IMR might give a
whopping 5 or 10 min run time, at which point, if the emitters aren’t toast, one might be tempted to quench the head in oil :Sp
____________________
Girls can shoot!
DayLighter
DayLighter's picture
Last seen: 2 years 5 months ago
hmm.. something like this? it can burn paper Big Smile
http://www.wickedlasers.com/torch
The only way to do a great work is to love what you do.
M3TAL_L0RD
M3TAL_L0RD's picture
Last seen: 4 months 1 week ago
DayLighter wrote:
dthrckt wrote:
they're on ebay (just search 12x cree) and someone started a thread on the light here my thought, shared by some others - we'll see 18 next...look at the spaces in the reflector Smile I love floody lights - but no way I'm spending $200+ on a crapshoot-fire although - w/ 18x, one might be able to cram 2x of the KD 9x drivers in there and have a 130W 'torch', and 4x26650 IMR might give a whopping 5 or 10 min run time, at which point, if the emitters aren't toast, one might be tempted to quench the head in oil :Sp
hmm.. something like this? it can burn paper Big Smile http://www.wickedlasers.com/torch[/quote]
Yeah, that is TORCH, not flashlight.
nqcken
Last seen: 1 day 18 hours ago
all of the above, there looks to a lot of vacant space in the reflector to say nothing of the fact that the head diameter is 76.5mm vs say the tf ak47 with 9xt6 and an 88mm head. guess you will just have to buy it and compare with your 9x Smile
ken
RaceR86
RaceR86's picture
Last seen: 3 years 8 months ago
9 XM-L2 could equal= 10.000+ lumen @ 3A to each led.
27A total
27A/6 18650 batteries would equal= 4,5A per battery. Which should be no problem for normal good protected cells.
Now, give me a proper “compact” flashlight light that looks something light this with a proper UI (possibility to get into the mode you want quite easily):
Turbo: 30A (3,3A to each led, 5A per battery. Built in temperature monitor would step down the light to the needed mode)
High: 18A (2 A to each led, 3A per battery)
Normal: 5A
Low: 0,5A
Super low: 0,1A
One light to rule them all! Smile
BLF LED database – collaboration spreadsheet and latest news about where to buy LEDs
http://budgetlightforum.com/node/19342
blueb8llz
Last seen: 14 hours 40 min ago
Richie086 wrote:
Hi folks,
youd be the perfect canditate to purchase this light too since you have that 9xml to compare it with. i too, also love floody lights!
PaulR
Last seen: 1 year 8 months ago
I just received one of these, I know this is an older post. Tested it and at startup it’s pulling 4 amps. So, that means each LED is only getting .333mA! It is bright, but, I think it could be much brighter if the LED’s were driven better.
What driver would give more power???
Thanks for the help.
I have several lights that I want to modify. Resistor mods seem the simplest. I have double of a few lights.
Paul
relic38
relic38's picture
You mean 4A at the tailcap? That’s 48W on three cells. About 3.5W per LED factoring some driver loss. That’s closer to 1A per emitter. Not horribly driven, probably could be pushed further.
BTW, welcome to BLF!
Welcome the night.
My Reviews   My Mods    http://budgetlightforum.com/search?
PaulR
Yes, 4A at the tailcap. I would like to get more out of this light. It’s supposed to put out 13000 lumins, I have read (not tested it yet) that it is really closer to 3000.
I have a nice Sekonic light meter that measures EV and found a conversion chart. I may see what I can measure in the next few days.
Any ideas for a different driver or can a resister mod be done on this light???
Thank you for the welcome. I hope to spend some time here. I think my future is bright!!
Paul
Flomotion
Flomotion's picture
Last seen: 4 weeks 1 day ago
Paul
Welcome, and this is a respected seller:
http://www.kaidomain.com/product/details.S020991
Actually, you would be better to buy this:
http://www.kaidomain.com/product/details.S021457
It is very strongly driven, and will produce more actual lumens.
Flomotion
Hikelite
Last seen: 4 weeks 8 min ago
RaceR86 wrote:
9 XM-L2 could equal= 10.000+ lumen @ 3A to each led. 27A total 27A/6 18650 batteries would equal= 4,5A per battery. Which should be no problem for normal good protected cells. Now, give me a proper "compact" flashlight light that looks something light this with a proper UI (possibility to get into the mode you want quite easily): Turbo: 30A (3,3A to each led, 5A per battery. Built in temperature monitor would step down the light to the needed mode) High: 18A (2 A to each led, 3A per battery) Normal: 5A Low: 0,5A Super low: 0,1A One light to rule them all! :)
3A each LED, 90+Watts, that's some heat to handle.
relic38
relic38's picture
That’s 13000 Chinese Lumens, which has a conversion factor somewhere between 2 and 3. These lights have been made to output about 5k or 6k lumens. It is just too much power to get more than that in this light format.
I believe there is a thread on here about modding this light with a KaiDomain driver. Maybe it was 9x light but very similar.
If you want to and are comfortable with tearing it down and provide pics, we will be happy to help.
Welcome the night.
PaulR
The first one you listed is the one I have, but i paid 57 for it. Smile I want to mod it to get a little more out of it.
Thank you,
Paul
Thanks for the Welcome!! Smile
PaulR
relic38 wrote:
That’s 13000 Chinese Lumens, which has a conversion factor somewhere between 2 and 3. These lights have been made to output about 5k or 6k lumens. It is just too much power to get more than that in this light format. I believe there is a thread on here about modding this light with a KaiDomain driver. Maybe it was 9x light but very similar. If you want to and are comfortable with tearing it down and provide pics, we will be happy to help.
Thank you very much for the offer!! I will be pulling it apart in the next few days. Hoping a resister mod can get it a little brighter!!
Paul
PaulR
Ok, I put some fresh 26650 batteries in and retested, i have 6.2A at the tailcap. Better than the first test! So, this would mean 1.5A at each LED?
Thanks,
Paul
relic38
relic38's picture
That’s a decent power input, assuming 80% efficiency, you are getting 60W+ to the emitters. That’s in the ballpark of 1.5A per emitter. Probably close to or over 4000 lumens OTF.
Welcome the night.
PaulR
Now, when I just took it outside, it has a discernible hum/vibration. Why would that be???
Thanks,
Paul
P.S. I will test the output sometime this week.
relic38
relic38's picture
Thanks,
Paul
That’s the flux capacitor Wink
No idea, but it might be the driver’s boost switching regulator. Sometimes the coil can make noise.
Does it hum/vibrate on high? I could expect the PWM of med or low causing noise as well.
Welcome the night.
PaulR
It vibrates/hums on all settings.
It is bright though! May want a little more out of it (am I too greedy?? I feel the POWER!!!)
Thank you,
Paul
relic38
relic38's picture
Thank you,
Paul
Too greedy? You’ll find out once you mod it.
Hint: the humming is trying to tell you something. Wink
Welcome the night.
PaulR
I don’t want to burn it out, is that a possibility??
relic38
relic38's picture
Um, yeah. It’s possible. Big Smile
Only one way to find out for sure though. Wink
These 12x lights when pushing any power cannot be run for very long. Your light is right around the limit I’d say. if you only want a massive output for a couple of minutes, then you might get away with an increase. I do not have one of these, but there are threads on here about modding them. Most involve installing a new driver from Kaidomain.
Good luck with the mods. If you want to try something with your existing driver, post a few pics of it and we’ll help you blow it up increase the output a bit. Big Smile
Welcome the night.
Aidie
Last seen: 6 years 5 months ago
Hi,
Thinking about splashing out on a huge 12 LED Skyray, well take a look here at the junk being passed off on eBAY
http://www.999wed.com/skyray_torches.htm
Assuming of course you can find a genuine seller to sell you either a fake or one that puffs out lovely blue smoke.
When you finally get your torch don’t be surprised when eBay supports the seller and leaves you the victim of fake or shoddy goods.
Cheers.
Aidie.
VALUMENS
Last seen: 5 years 10 months ago
HI
DOES ANYONE KNOW IF BY ADDING ONE MORE BATTERY18650 TO IT TO MAKE 4 CONFIG , HAS ALREADY 3 BATTERIES AS A STOCK, WILL IT BURN THE CIRCUIT ? Beer
atten
Last seen: 1 year 1 month ago
THANK YOU VERY MUCH 60W Digital & Lead-free Soldering Station
Temperature read out in ℃ and ℉
On/Off switch on the right side of the unit.
MCU controlled temperature calibration. rc AIRPLANE
Simulate bar indicating heating up status.
LCD display screen making control visualization.
User-friendly menu enables system setting easier.
Separate iron stand to save room and to make easier deposit.
Buttons (1, 2, 3) for pre-setting or switching frequently used temperature.
Low-voltage heater separated from power supply to keep soldering work safer.
Soldering tip designed separate from heater and using exchangeable 900M series to save use-cost.
MORE INFO http://www.atten.com/project/at938d/
atten
i like them it can help me
fms rc airplane
