I do not know, now it works. As I said, I removed the copper film below the areas I marked. All I can think of, if that the current was jumping through the layer somehow, but that's hard to believe. Once I removed the copper under the top coat and put everything back, it works, but I can't give a definite reason for the change. All I did was make sure that there was nothing in the path of the jumpers and nothing close to the spring. That area around the one spring was cleared away, because that pad is smaller than the other two. It was a positive pad and the others were negative. The spring was larger than the pad, but the area around it was coated. It shouldn't have mattered.
Glad you’re back in business OL. The resist layer isn’t perfect - I sometimes stab a multimeter probe straight through it to get a reading.
Worked on the contact plate today. Photos in the OP. Won't have parts till late in the week, so the week-end will be when I finish the build.
Finished and Beam shots are up. See the OP.
Looks like an amazing personal defense weapon. :bigsmile:
Wonder how crazy strobe would look!
LMAO I seriously can’t stop laughing, that is just INSANE!!! Wow, would love to see that in person. Very good work, really hope the owner is happy, I know I would be!
I’m already blinded from the beamshots. 8)
That is one mean light!
wow… just wow, your creations is always bring smile to my face
OL, that is insanity! :Sp I love it. Looks like it could double as a BBQ grill. Might want to wear some sunglass while testing, just to be on the safe side.
Well done (insert roaring audience sound) I love it!
geez, that is one bright arse light!
Who needs a tanning salon?
Heheh, one click mobile tanning.
Don’t tell me why, I somehow missed the drivers. What an amazing array. Orsm effort. I assume you used Mothers on the reflectors reflective surface as well as non reflective surface. This cleaned the surfaces up without damage and if so have you used it on other reflectors?
I thought I seen a glow to the east!! WOW! That would be the ideal search & rescue light... with a flood like that you should find about anything / anyone!! Nice OL! The driver image is a keeper! That needs to be a poster on every modders wall!!
Thanks for sharing! Dan.
Sweet build! If anyone asks about the cause of global warming, I promise I won’t let your secret slip.
I only used it on the very top of the reflector, not in the cups. There was a film all over the top of it. I know it would definitely ruin the cups, but on top, at least it removed the film.
wow!
Amazing work - not sure how I missed this thread! I've seen this exact light, and think did a minor repair. Yes - I recall the cloudy effect over everything as well. There are real practical uses for lights like this out there. Since I got around 6,500 lumens on a J18 with only 6 LED's of XM-L2 U2 1A's on copper in about the same amp range (maybe a little higher), I'm guessing that light is doing in the 7,500 to 8,000 lumens range now.
I could use this light right about now to help me melt the snow
