Based on the previous comments, I expected the color mismatch between the body and the head to be much worse. At least in this shot, it doesn’t look that bad.
I was afraid that this starry night would look more like the Colorado:
Now THAT is a color mismatch. I don’t care how good the light is, that just looks bad.
Has anyone else had SERIOUS trouble getting the light screwed in? I noticed it kept screwing and screwing, but never really attached when I got mine. It works great when you press down and turn it once, but you can easily thread it the wrong way and the light will not work. But you can never screw it down properly (all the way and in such a way as to get it to stay - you can always pull or wiggle the head right off, which means the o-rings don’t make a difference and can’t protect the light from moisture).
Anyone else noticed this? First time I played with it, I noticed this design was the worst-threaded light in the history of lights. Tried to demo it for a buddy tonight and found out how bad this design really is. He totally lost interest in it because of this. It just will NOT screw on properly. I’m amazed it stays at all.
Plastic body - made in China. The reason I will not buy one. Don't care what type of plastic it is, if it was molded in China. The specs will be off and the min/max dimensional ranges will be too big. OD of threads too small to hold well in the Aluminum head on some and too tight to screw in well on others. Not good, but expected when a process is out of control. Some will be great and some will be no good. My prediction, LOL.
I had to put mine together, the tiny driver/pill retaining ring was unscrewed on mine. I had to get an ice pick and stick it way down in there between the head and the pill and screw the ring into the head. The bezel ring also was loose.
It was the retaining ring; it wasn’t screwed in on mine either! I took a paperclip and screwed it down at work (not quite all the way, but enough to get the job done) and it threaded right on! It’s now screwing on and sealing properly. If you’re having trouble, be sure and check that.
I love a bargain as much as the next guy—but this light is already a great value IMHO.
Its just $24.99 from IS And others have reported using code “illumination”
for another (15%?) off , for $21.xx
Well, my cells may not have had a full charge (but I think they did), but I just now needed to recharge my Eneloops. I could see the beam dimming. So yeah, I’m thinking that 2 hour and 20 minute run-time is complete bullocks since I haven’t really used it that much. Wouldn’t be the first time the Fl-1 standard was wrong.
Any of you lucky owners planning on doing a review of this light? It seems there is a mixed bag of comments concerning build quality and run time performance. The only forum that pops up on a google search is this thread here, so hands on experience with this light seems limited.
Someone is probably testing this light for proper review, given that folks from Blackshadow have sent one light to someone for review, Im not sure if its here at BLF or some other forum tho :D!
