I tried some T10 LED bulbs for instrument light and reading light, till now they works well. The light brightness is good.
But I for headlight, have no plan to switch to LED now. Will go and see for a while.
Replacement LED bulbs are unsafe when used in a light fitting designed for incandescent bulbs, they also will not meet the lighting requirements of nearly every civilized country.
The specification for light output and how that light is dispersed are quite strict, by changing the light source from a filament to a LED changes those specs, the light will no longer conform as designed.
Seems there are a lot of people prepared to ignore such matters, or think they will get away with it. But tell that to a good friend of mine whose vehicle was written off in a rear end shunt and a sharp eyed insurance assessor noted his non compliment LED bulbs in his tail and stop lights, the claim was refused as the vehicle no longer met the manufactures specs. He’s out almost £7000.
Regardless of safety reasons, have you never encounter on the road someone just ahead of you and turned on the rear fog light when I there us no fog (worse, when it’s raining)?
But for interior festoon, I highly recommend some festoon that use Cree XR-E Q5. Just search “Cree festoon”. It could be too bright for rear license plate.
I hate to be a downer here but…………………check out the link I have provided dealing with Federal automotive lighting. Get caught putting in a non D.O.T. certified light no matter what you think about them or claims made by the manufacturer, and heavy fines are involved if said lights are not D.O.T approved. Get into a night time auto accident with unapproved lights, lamps or bulbs and it gets even worse. Don’t take my word for it. Read the document. It’s very real.
old school leds bulbs with 5050 or 2875 leds are garbage, newer with cree leds, sitting on chunk of aluminium should be better, one would think, but the problem is, heatsinking still, is crap, no where for heat to go, if they only drove those leds at 350ma or less, that there would be no problem, they would be still bright, but last a lot longer. but they drive them at close to 1A, and often, there are more than 1 led there.
i used such bulbs a lot, but not in cars, actually mine were used most of the time in open light fixture not in closed tail light, but they still fail.
if someone wants to build led tail light, it needs to be done from a scratch, not just replace bulb, but an array of leds, inside tail light, not an easy task to do.
as for leagl part, well you take a chance, you might get in trobble or you might not. your choice. i personaly don’t care for changing anything in my car, i lease brand new cars, give it back 3 years later, and could not care less how lights in the back look. but that is just me.
also, regarding fast light up time of leds, it is true, however, in reality, it did not affect accident rates in any way.
I did a fair bit of research and settled on some 5050 based led’s in 1157 format. They turned out to be bright enough so I was happy for a while but after about one year half of them aren’t working anymore. I was trying to conserve power on an older goldwing that are known to have weak stators. With brake, accessory brake, and signal lights I flushed over $100 down the toilet. I did use an led taillight assembly (princess auto) on a bike trailer I built and it works well. Like others have said, skip the bulbs and buy a rated assembly. At least they have to pass some kind of standard to get a rating not like the crap bulbs.
i never had to replace a single bulb, in at least 7 cars my family leased over last 10 years. neither headlight nor tail, nor interior. none failed in 3 years lease term.
i’d say lifespan of regfular bulbs is way longer than of those led retrofit bulbs. even thou they supposed to never burn out, lol.
That’s odd. When I converted my brake lights it was after reading the results of a study like this one, release last year by the US Gov’t. It seems to have some interesting results. For example, if you drove a Honda Accord or Cadillac Deville that was the model year that was tested, you had a significant safety advantage by switching to LED, but other models such as the Infiniti M45 the stats got worse. At least this study seems to be a bit more germain to the discussion in terms of their (LED’s) effect on cars anywhere in the world, rather than quoting laws (or fabricating antidotes), that only apply to certain jurisdictions (or seem rather specious in nature).
The link I posted are Federal laws. They do vary a little from State to State but Federal law trumps State law every time in court. The law is the law. Thumb your nose at it if you like. Violate it at your own risk. NO sarcasm here.
Or to rephrase that somewhat, “The law where you live is the law where you live, and not the law where I live”. Helps to bear in mind that the members of this forum are not necessarily under US jurisdiction (at least not yet).
If however you want to make your post more helpful for your fellow countrymen, you may want to paraphase the appropriate relevant parts rather than demonstrating that you are adept at using the copy and paste keys.
The link will be helpful to anybody living here in the U.S. Any clear thinking person NOT living in the U.S. will ignore the post. Judging by your snotty comments, I’m guessing you are not a clear thinking individual. Any idiot looking to pick a fight (you?) - will. If YOU want to be helpful - quit going out of your way to start arguments about nothing. I have no interest arguing with idiots today, no matter what country they are from. Sheesh!
As I mentioned in an earlier post critical laws relating to automotive lighting do not vary greatly from first world country to first world country, you can ignore your local rules at your own peril. Ignoring the fact that the rules do exist doesn’t make the rules go away.
I don’t mean any disrespect here, but unless referenced by a peer reviewed article by an international legal expert, I find claims like the one in quotes posted in Internet forums to be absurd (as was your incredible tale about the insurance adjuster who somehow managed to ignore the legal concept of ‘evidence continuity’).
Now let’s go back to the facts folks. I would appear if you owned a Honda Accord Coupe, or maybe even more appropriate, if one of your loved ones owns one that was in the above study, you would probably consider that if they have a 33.7% less probablility of getting rear ended by an inattentive operator in a big rig truck, you might feel better if they were using LED’s. By all means, if you can get a Type Approved light, do so. In the meantime, just keep one thing in mind:
Is it so hard to believe that insurance adjusters will use every excuse to deny you coverage, and that it has happened before?
You are correct that it should not happen, but unless you can afford some pricey lawyers you are at their mercy, corporations don’t look for ways to spend money on you, they look for ways to take money from you.
I really don’t care what you do to your own vehicle, just trying to share what was a very unfortunate and costly indecent.
Ignore whatever you wish just don’t call me absurd.
Fatyburn story is not absurd. Insurance company are not your friend, they take your money and give your services for what you signed for. If it’s now what you signed for, they’re will be happy to don’t pay.
Long time ago I had a problem with my car while driving. I had to call a tow truck.
Back then my contract covered the tow truck only if I call them more than 50km from my home.
And my insurance told me that I was less than 50km from home (and the tow truck is not cheap…)
I verified later I was between 45 and 50km, definitely less so OK I don’t contest, but it was so close!
