The best and cheapest place to get cool switches from is to place switches in the fridge for about two hours. For really cool switches they go in the freezer for about the same amount of time.
The switches are SMD momentary and come from Spark Fun. I solder them to XM-L stars, because the spacing is close enough to work. Not perfect, but close enough.
Buenos notches. The hands take a beating. I think maybe that’s why the call it hand work. Small lip on the spacer ring w/o-ring? Similar to the lip in the head.
You mean an “O” ring groove on the body? I’ve thought about it, but I have never tried one. It’s such a tight fit now, I don’t know if an “O” ring could fit.
You put a lip on the head to retain the glass. If you put a lip on the split ring in the same fashion then the p60 would be centered by the split ring and also press against the new lip - which presses against the glass - which presses against an o-ring - and finally against the lip in the head. Spring pressure from the battery keeps it all in place. This allows a snug fit for the pill since to remove it you just press on the glass and it all slides out. No need to make new parts just add the lip.
Edit, like this:
A thin smear of silicon allowed to skin over but not cure and then assemble the light and no o-ring would be needed just make the retainer a bit looser (easy press fit).Even with an o-ring those notches should still work, the spring will just compress a bit more.
Napoleon Bonaparte had such an idea and imposed it on the countries he controlled. It is called the metric system. But when I was in Germany, they used US inches for seat belt fasteners and their own old unit close to it for plumbing.
Nice flashlight! Don’t think it needs fins with all that copper.
I don’t know whether to cheer or cringe. My heart skipped a beat or two. Can I just be a judge this time around. Dammit, you made me start thinking again.
