@Bocian: Due to the language barrier, (which is my fault, not yours) I think I only understood about 50% of what the driver actually accomplishes, so it was hard for me to decide if one would be helpful for what I do or not. I do empathize with your observations about the copper pill however, and think that your offer is very reasonable. Thanks for bringing it forward as an alernative to consider.
No problem. I can assemble with additional AMCs (0,5$/piece).
Looks like a great driver! Price looks fair too. :)
PM sent!
I’d be delighted to see you put a review of a stock light and after the mod with some pics and runtimes etc Would be awesome!
From fully charged cell to 3V, I assume it will work pretty much like a Qlite/nanjg105C. Runtime ( especially on high) will depend mostly on output, battery, and the emitter type (Vf). I wont bother with runtime graphs and such. I guess others have already posted some runtime graphs with various setups using fairly similar drivers.
I might do a stock vs modded light just for fun. But that will only display the difference between a mediocre 2amp light, and a light with lots of amps. Nothing that hasn't been covered before in a ton of mod threads.
Its the UI and special features im interested in. I will test all of them. I can report back how well I like it. Ill probably do a simple runtime test from 3V and down. I look forward to test the overheating function as well. :)
If its as good as I hope, this will pretty much suit all my needs for a "sophisticated hotrod" light. 0:)
Now available with increased PWM speed and better thermal mechanism.
Did you discontinue the weekend promotion already? It's still the weekend.
In few days I will provide new version, with auto temperature calibration procedure.
Thanks, I thought my calendar was running slow again.
PM and payment sent. Thanks.
I would like to inform that since 1st February Polish Post Company changed its pricing Now shipping World Wide (registered, priority mail) is 5,5$.
C’mon, How much is that? Two saturday evening beers? Good Job Bocian ! I’ll definetly have one for testing
Final versions of Attiny25V and Attiny13A driver have been established and little price update
I hope you don’t mind beginner questions, but the programmable modes you have make me interested in this driver.
Both Attiny25V and 13A are 17mm drivers?
Are they for 1 x 18650 applications only, or for 2 x 18650 also?
I don’t really understand the difference between 25V and 13A versions. I thought I read that 13A also has temperature control? The 25V costs a little more, could you specify difference for beginner?
Thanks in advance.
Yes, both are 17mm drivers. The main difference between 25V and 13A is temperature control mechanism (attiny25 has it, 13A has not). Another difference is that 25V has precise voltage measurement (13A has simplifier voltage measurement). Also Attiny25V can handle lowest mode more stable (13A lowest mode is once visible, other not).
Up
Welcome back Tomas. How have you been? If your avatar is your beautiful baby, it's surely time for an updated photo.
Awesome. I didn’t see this thread earlier, but it looks interesting. I take it the attiny25 is a drop-in replacement for the attiny13? If so, I’m tempted to get some attiny25s (or maybe even 45 or 85) so I can have more flash space to play with. Do you know which is the highest-spec attiny which can fit on a common nanjg driver?
I’ve recently been pondering adding a battery check mode to my EDC firmware, but I’m already at 1024 bytes so I’d need to remove something to make room. And on some e-switch lights, I’ve found it difficult to fit everything I want so again more space would be helpful.
Attiny85 can fit a nanjg driver by bending the legs under. Making J leads. example
Skip the tiny25 and go straight for 85.
