MT-G2 COURUI Anyone? Another O-L mod. PHOTO HEAVY - BEAM SHOTS ARE UP! 02-06-14
The original was on a thin board, so there will be issues. What will have to happen, is the head will not be down all the way and I will have to make some type of spacer ring, like a copper ring, so that the gap will not be as noticeable. If I had a lathe, I would just have cut the shelf inside the light lower and threaded it deeper, so that the led would be in original position, but I cannot do that by hand, so it’s a just do what I can kind of thing.
I figure what will happen is this. At first turn on, it will be bright as hell for about 30 seconds. Then the batteries will sag a little and it will get dimmer. After about a minute the whole head will be warm, but by then the 7135 chips will start to back off and loose power, because they will be hot and the light will get dimmer and dimmer quickly. So… all in all, it’s a 30 second light for max power and after that, it will just keep getting dimmer, so it will probably never get too hot. Within 3 to 4 minutes, I would expect it to be at about 70% to 60% power on it’s own, just from battery sag and overheating 7135 chips. What I am waiting for is someone to make a dedicated driver especially designed for the MT-G2 and a light/reflector for it too.
I think I will pass away before I ever see that day though.
Eat lots of kale and tofu.
Then you won't mind passing away so much.
There's no such thing as a "MTG2 driver", it's just a LED that needs a higher voltage than a single XML. Anything that will run two XMLs in series will also run a MTG2, the driver will never know the difference. There's probably 20 drivers listed in the 'post your MTG2 driver results here' thread that work straight out of the box with no mods required.
Updated the OP, it's basically done. I am waiting for batteries now.
Nice work there, Justin! Can’t wait to see your beam shots!
really wonderful to see your professional work.
truly inspiring and your youtube channel.
you are great
Whoa. Incredible build. As a fellow user of split and flattened out copper tubing, I can appreciate a lot of the work you're doing here. My craftsmanship is no where near yours though.
Nice job.
You scribed the inner diameter to the size you Dremilled it to after drilling a hole. How did you Dremil the hole?
I scribed the line for the hole diameter. I drilled a starter hole with a drill bit. I took the dremel tool and put it in the hole and just kept opening up the hole bigger and bigger till I got it to where I wanted it, using a #115 dremel bit in the dremel tool.
Thanks OL. Google is my friend. I dont have a dremel and wonder if I should. Na. Just something else I would spend to much money on. Nice job. If you dont mind me asking how do you clean the burrs of?
Hmmm. Did you take the photo before you replaced the ground wire, or are you devising some other devious plan?
Nice work. Can’t wait to see beamshots.
Just to confirm, with your mods, this light will only work with 6*18350s rather than 3*18650s?
If it works with 18650s, then I might consider being in line to buy the light (if you end up selling it) because I was thinking about getting another Big Head but couple if with an MT-G2 this time around. Otherwise, me thinks an MT-G2 plus another Convoy L2 host (if they ever come back in stock again!!!).
3 x 18650 in parallel will only give 4.2V. An MT-G2 needs 6V to get started. 6 x 18350 makes it a 2 x series light and 8.4V.
I just used the wrong photo…
This is a light I bought from another member and apparently it was destined for a mod it never got, so my half circle wire is just undoing something that was done and with 9 amps, I wanted to use 18ga wire. Apparently that contact plate is also used in a tail switch light as well as this side switch light. I did not take a photo of the other wire added, because I forgot. I was debating on putting the wire there, or actually adding a switch for lockout, but since I had to move the plate out, for the 18350 batts, I had to just go with the crossover wire too. I will change the photo out, when I finish up the light this week.
I use an exacto knife and just lightly trim around edges on an angle to the surface, to lift off burrs. If they are too heavy, I use sandpaper.
Could you shuffle the battery carrier to have 1 dummy 18650 and the other 2 18650s in series?
Besides that, this is an amazing build! I can’t believe the precision of your handwork. It’s a relatively tiny detail, but the copper spacers on the stacked boards is pure awesome.
Thanks for sharing all the info and great pics.
