Nitecore HC50 565Lm Headlamp Review
Really cool setup there! :slight_smile:
That clamp looks really useful for attached stuff to crab scoop nets. L:D
Great review. But why no MSRP in the review?
http://bit.ly/19EA5Go
It was easier for me to select that nitecore with my mouse right click and use the context menu to search the MSRP or to even type that long ass response to your lmgtfy link.
I mean the review is great but including a MSRP at start of review would be much better and put the light in ‘context’
Has the glow isue been fixed?
Never had an issue in the first place :P
Same for me.
whats the difference in using 1 or 2 batteries ? in terms of performance
2 batteries have higher total voltage and respectively the light will stay longer in regulation(will maintain constant brightness).
Shorter run time with two batteries.
The HC50 has no enough space for two protected 16340(RCR) batteries. CR123A,IMR 16340 or unprotected ICR 16340 can be used,but the CR123As are not cost effective.Using unprotected 16340 requires more care to their voltage.
Hello. I overcharged 2 of my 16340 cells and put them into my HC50. The battery meter read 8.6V. Is the light brighter at this voltage?
thanks.
pat
I’m curious about the flood, my HL 21 is too focused, my HL10 is very nice, and my HP25 is nice on flood but too focused on throw, is this beam floody with no hot spot, or least a wide hotspot that blends in to the flood (spill?)?
Probably slightly brighter,but not much. I can’t test it though.
Just for info,what batteries do you use?
The light still has a hotspot,because of the reflector,but it’s not too bright and doesn’t disturb my eyes. Hotspot and spill blend well.
How do you think it would be for reading and working at arms length?
The HL21 drive me nuts.
I think it is good for reading and working. Sometimes I use my HC50 when soldering and I found it comfortable. I usually use a flashlight with attached diffuser.
Very very good review! a shame it has only 40 replies, but i guess you left a lot of us speechless.
FlashLion, jaw dropping pics man!! Great review too! One thing you didn’t mention in the OP is approximate tint of the light. Cool, neutral, warm. Thanks again
He did actually:
Oh crud. Sorry :weary: Thanks
