The BIG flashlight collection thread - List your flashlight collection here!
Goddamn guys. So many flashlights…
wow there are some great collections here ! maybe i should do a photo set of my lights after the new year. im guessing i past the 200 mark by now.
My collection in my display case. (Around the house and in my pockets are several more lights spreaded)
Not as nice as some of you, and as of now most of them are cheap, but since the last couple of months I’m more focused on better quality and brands.
Picture is not so great as I just took a quick snap shot with my cellphone.
Instead of buying better ones, you could fix what you don’t like in the ones you have. That would be more fun for less money.
It’s not really a matter of not liking them, it’s a matter of getting some lights that will power on when needed (and just another reason to keep buying :P)
And modding is a whole next level. The goldenbrown one second from the right on the top was disassembled and reassembled by me, now the tailcap isn’t working anymore, and I’m almost positive I put everything back in as I took it out. Light turns on as soon as I twist the tailcap on and won’t turn off anymore until I twist it back :stuck_out_tongue:
Ah well, at least it’s one that I already didn’t use that often anymore.
I only have Fenix E05 and Olight S10 L2 in my collection. I also acquired a couple of Energizer Lithium (AAA) and Nitecore RCR123A with Nitecore I2. Just Ordered a Convoy C8 and a couple of Sanyo UR18650FM. I don’t looking to add more lights now maybe after a few months.
Solarforce
‣C2000
Flashlight collection? off the top of my head without looking:
1xAAA lights:
  • Fenix LD01
  • Liteflux LF2XT natural anodizing
  • Liteflux LF2XT black anodizing with emitter upgrade to XPG R5
  • Tank 007 TK703
1xAA lights:
  • Eagletac D25a titanium XPG2
  • Jetbeam BK135a
  • Jetbeam PA01
  • Sipik SK58 (modded to XML2 neutral, 4 amp, electronic switch)
  • Sipik 58 (modded to triple Nichia 219 @ 3 amps)
  • multiple Sipik 68s and clones
  • XTar WK41
  • Sunwayman V10a XPG
  • A couple LED Lensers (I forget the exact names)
  • Zebralight SC52
  • Zebralight SC52w
  • Spark SL5 neutral XML
  • Zebralight SC80 XPG
  • Thrunite Neutron 1A
  • 4-Sevens mini AA XPG
  • 4-Sevens mini AA Titanium XPG
1xCR123 lights:
  • Eagletac D25c aluminum 2012 neutral XML
  • Eagletac D25c aluminum 2013 neutral XML2
  • Eagletac D25c Titanium 2012 upgraded to 5000k neutral XML2
  • Jetbeam RRT01 (modded to XML2 neutral)
  • Jetbeam TCR01 (titanium)
  • Olight S10 (modded to XML2 neutral)
  • Olight S10 Titanium
  • XTar WK42 (modded to 3 amp XML2 neutral)
  • Sunwayman V10r XML
  • Sunwayman V11r XML
  • Lenslight Mini XPG neutral
  • Spark SF3 neutral XML2
18650 size lights:
  • Convoy M1 (modded to 4.5 amp MTG2)
  • Roche F12 (emitter swapped to XML2 neutral and lens swapped)
  • Roche F12 (modded to triple XPG2 neutral at 4.5 amps; battery tube cut down to 1x18350)
  • Zebralight SC600 (early model)
  • DQG mini 18650 (first version)
  • Shiningbeam S-mini (neutral XPG)
  • Sunwayman C20C (emitter swapped to XML2, but will shortly attempt to mod to MTG2 @ 3 amps)
Other:
  • Probably 15+ other cheap budget LED lights of various sizes, some modded, some not. Many of them zoom lights.
  • Several old Inova lights, some with 5mm LEDs
  • Lots of cheap keychain LED lights with 5mm LEDs
  • My earliest LED light: a small plastic keychain light with a titanium sleeve. Powered by 3-button cells. Light source is a 10mm red LED. Purchased at least 22 years ago.
  • Various old incandescent lights: small maglites, 3 battery powered fluorescent lights, a couple Underwater Kinetics dive lights.
_
My current EDC is my modded XTar WK2, now equipped with 3.04 Nangj 105c with DrJones Lumodrv, a Radioshack micro-momentary switch, and a 5000k XML2 neutral on Noctigon.
Copypasta from my database:
4Sevens Maelstrom G5
4Sevens Maelstrom X10 XM-L2, S6, 7D3 90+ CRI
4Sevens Quark 123² Turbo
4Sevens Quark MiNi 123 Q3-5A3 Neutral “feeler” run
ACR ACR/L-6A Super Beam Gun, PAR36, magnetic reed switch
ACR C-Light USCG Approved Lifevest light
AELight Xenide 25W
CMG Infinity Amber LED
CMG Infinity Ultra
EagleTac D25C Mini
EagleTac D25C2
EagleTac M2SC4 MC-E / Neutral
Etek HID Spotlight
Fenix E0 None
Fenix E01 None
Fenix E05 None
Fenix E21 None
Fenix L0D Q4 None
Fenix L1P None
Fenix L2D None
Fenix L2T LuxIII 450nm LED
Fenix PD32 XP-G
Fenix TK30 MC-E
Fenix TK35 XM-L
Fire-Foxes FF4
Foursevens Mini ML CML-FA, Satin Titanium
Foursevens Preon P1 CP1-FA, Satin Titanium
Fulton MX-212/U Black/Yellow, Intrinsically Safe
Fulton MX-991/U Olive Drab, Dorcy 2D LED
Harbor Freight HID Spotlight 55W Ballast, 4S 4000mAh LiPo, 60m runtime
Hexbright Flex Blue
Icon Rogue 1 Grey
Icon Rogue 2 Black
Inova X5 Blue LED, original version with rev. twisty head, gunmetal
Inova X5 Black, newer version
JetBeam BC20 S2 Edition
JetBeam Jet-III M R5
JetBeam M2S SST-50t
Koehler 8400T Waterproof, intrinsically safe. Ref. CG-D-02-95 pg 30. Catalyst
MagLite 2D MJ LED Blue
MagLite 2D LEEED 6xAA, TeraLux TLE-310M, UCL
MagLite 3D
MagLite 4D TerraLux LED
MagLite 4D LED Blue
MagLite M@g85 WA1185, 9xAA, Carley MS, Borofloat
MagLite M@g85 WA1185, 3x18650, Carley MS, Borofloat
MagLite MagCharger
Nitecore D11 SP R5
Nitecore EC2
Nitecore EC25W Cobra
Nitecore Sens Mini
Nitecore SRT3
Nitecore TM11
Nitecore SRT7 Grey
Nitecore Extreme Infinity Q5
NovaTac EDC120P Lux K2-TFFC
NovaTac Storm 120ST Desert Tan
Olight M20 R2 Edition
Olight T20 Q5
Peak Eiger 10440, NW, Nar #5
Peak Eiger 10440, CW, Med #8
Peak El Capitan Red Lvl4
Peak Matterhorn Red
Peak Shasta HA-Black, packet, 3 LED
Peak Shasta Prototype, 1 LED
Peak Shasta Brass, 3 LED
Pelican Super PeliLite Yellow
Prometheus Beta QR NS
Ray-O-Vac IN2-MS MSHA, CSA, UL listed
Solarforce L2M Malkoff M61W, SureFire Z59
Stanley LED Spotlight Neutral White XR-E Q5
Streamlight Microstream
Streamlight Tasklight 2L3W SSC P4 U-bin
Streamlight TL 2
Sunwayman V10R Ti+ XM-L2, S6, 7D3 90+ CRI
SureFire 6P HA-Nat, bored, EDC+ Triple-219, UCL, McClicky hardpress, steel cren bezel
SureFire 6P Defender Bored, Nailbender P7 3-mode w/memory
SureFire 6PX Pro 9/11 Commemorative Red
SureFire 6PX Pro
SureFire A2 Aviator calipsoii Cyan ring
SureFire A2L Aviator Red secondary
SureFire E2e Executive Elite LF IMR-E2 + AW IMR
SureFire G2 Nitrolon G2-TN, M61WLL
SureFire G2x Tactical Foliage Green
SureFire HL1-C-TN White/Red/IR IFF
SureFire L1 LumaMax L1-HA-WH
SureFire M3-CB Combatlight Veleno Designs XP-G NW
SureFire M4 Malkoff MD60
SureFire S2 Stratum S2-BK-WH
SureFire U2 Ultra 1st Gen, LuxV
ThruNite Neutron 2A
Unknown Cow 2x3mm + Sound Effect
Unknown Hello Kitty 5mm w/optic
Xenonics NightHunter One
Zebralight H31W
Holy shit that’s a lot of flashlights
Must be DayLighters cousin…
LOL… I should get myself one of those glass curio for my flashlights :smiley:
That’s DETOLF, from IKEAland. Only $65. My downlight is a Malkoff M60LF in an UltraFire host, hard-wired to a lamp circuit via 9V transformer.
Something I noticed is that many newer collectors don’t seem to own SureFire lights, they must have lost some appeal in the past few years.
I have that same Detolf Ikea cabinet for some of my lights. ( i need a second one though as this one is full.
Just a few of my quickly-getting-out-of-hand group of flashlights…
I got a few more :zipper_mouth_face:
I love the S10 and S20…
You are not allowed to make posts like this promoting your business. You are not posting here as a regular user, you are posting here as part of your job. READ THE RULES you agreed to when you signed up--> http://budgetlightforum.com/forum/misc/commercial
Damn dangerous. Those some nice lights. I don't have a single one of those. Congrats man
I got my first ‘budget’ lights. All the multiples are with different tints.
