I thought they were nice too, I ordered the purple one on the day of first appearance (the black one was not listed yet), and two weeks later I received a mail from dx that it was on backorder. It was the same day that the blsck one appeared on the dx site, so I changed the order to the black one. And yesterday I got the mail that it was on backorder. So dx lists lights that they do not have. Well, I will just wait for it to come now.
This is not my common experience with dx though, I have bought many new listed lights from them that I received fast.
Works on AAA alkaline: high, almost high, strobe. Output is less than ITP A3 (xpg R5) but throw is better (because of bit wider and smooth reflector and of xpe).
Also works fine on EfestIMR: high, high, high with faint strobe , nice fat output with really good spot.
Bezel is SS . Reflector is aluminium, under the reflector is a insulating/centering piece of plastic that does the job well, no pill, led board sits on a black anodised shelf that is part of the body, driver needs a tiny solder blob in the middle of the battery+ pad to fit the flat top Efest battery. The o-ring that seales the head from the body needs to be thinner, even if lubed well the head twists too stiff for comfort. The spring at the bottom of the tube is stiff and short (good for conductance) and can be reached because the tail cap can be screwed off for some reason.
It works well enough stock, and also I think it is a nice host: everything is servicable and I see no major desgin flaws.
You can get one from AliExpress for $5 in different colors.
And you will probably have better luck than buying from WB. I haven’t received mine yet, as the logistics company the seller have used messed up the shipping. I got a refund though and he resent me the light anyway as a compensation for inconvenience.
I did a second mod on the LZZ-06 (https://budgetlightforum.com/t/-/25476), the driver size is mentioned there. It is 13mm, so the nanjg 102 should fit :-) .
Thank you Pregulla for the info in Post 25 above. The vendor came through with flying colors. I just received 3 black Jexree Mini's today. Ordered on August 7th. They were beyond super well packed. I can only describe them as crazy well packed. I think they could have been dropped from a plane and landed on a solid rock with no damage. I kind of felt bad throwing away all the bubble wrap and 2 boxes they were packed in. All 3 were in perfect condition and work great.
They look the same as the light in the OP except no sticker and a smooth refector. They have very good output stock. At about 2 feet (guessing) they read 1,600 and 550 lux (Direct beam to meter) on high and low, respectively. A TruNite TiS measured 1,200 lux at the same distance.
Compared to a TiS:
Tubes are the same diameter. The Jexree's head is about 1mm wider, but the reflector is close to 2mm wider. Jexree is slightly shorter.
Beam of the TiS is smoother. Jexree has a smaller more concentrated hot spot. Jexree has slight artifacts on a wall, but they are not too bad.
Jexree includes a very nice clip. Doesn't come off or even move when extended out. Holds its place and doesn't rotate unless you purposely push it directly from the side with the intention to rotate.
Jexree tail stands slightly better. A slight wobble will topple the TiS, but the Jexree will recover and remain standing.
Tint is almost the same. Jexree is slightly cooler. Nice white with no apparent tint.
TiS' knurling is far superior. Jexree's is not grabby. The clip, head and two body groves make up for it though.
Guessing the Anodized finish on the TiS is superior, but I don't want to test. The Jexree's finish feels pretty decent though. Seems like it will hold up well.
The Jexree is a little wonky with mode changes. Luckily it starts in high mode. Generally, changes modes in the following order: High, Low, Strobe. Sometimes it changes modes in different order or keeps returning to high. Looking at the driver on the light I have, it appears to not be well seated. I need to pull it and reseat it flat in it's bay. I think that will fix the issue.
I just ordered nine more in various colors for gifts.
EDIT: Reworded the last bullet after noticing that my driver was loose and did not fit in its bay. I attempted to force it in place, but it got stuck at an angle. Was at work and had not files to get it properly sized and seated flat.
The driver looks pretty decent. It's PCB is red and appears to be labeled "LG68". Has 3 good sized capacitors. Inductor labeled "3R3". Mode chip labeled "ECA1R". Diode labeled "S6 82". Has 2 stacked resistors. Top one is labeled R300. Quality of construction looks pretty good. Has a copper ground ring (Not just a trace).
My Google-fu is weak today.
EDIT: The driver appears to be far more sophisticated than this driver. I'll try to post a picture tonight.
