Love that video; “You cannot be awesome without this rifle”
Back to the thread, Hold Sweet Mother of God, now that is a Shocker! Mine is relegated to a box in the corner as of late. I still like it, but I have other lights that get more use due to form-factor.
Hehe… not surprised by that, the shocker is a club of a light.
Thanks for ressurecting the thread and giving me a kick to get back to this project, got a bit distracted over the holidays with simpler mods.
Time to finish this one off and finally see it throw some photons!
ps. Oh and I found a pair of these motherboard auxiliary blowers a while back and am thinking of making a bracket for them that can be attached to the BTU so they can blow some air over those heatsink fins. They’re just the right width and it looks kinda cool with a pair of these blowers hanging off each side of the light.
Don’t know how much it would actually help to keep things cooler but they do move a decent amount of air even at ~8v. Worth giving it a go anyway i think.
Hi guys, sorry for the delay.
I definitely intend to get this sucker finished but have been getting sidetracked on other projects lately. Definitely need to get the ball rolling again so I’ll try to make some progress this week, thanks for the kick
Sounds good. Thanks for the update! Been following this one for a while.
I know what you mean about being sidetracked... I have been working on my own BTU shocker since November...and it is just a simple mod in comparison to this!
I did a mod on a Pelican King D a while back that included a rail mounted reed switch for mode control of a Hipflex driver that might give you an idea or two. I never got around to taking pics of the build since I don’t ever use the beast as the buoyancy is all wrong. In any case a reed switch is capable of operating the mcu all by itself. I’ll take some pics and post them in a bit.
At the front is an odd shaped lever that controls a dpdt switch and allows the Hipflex driver to control either 4 mce’s or 3 x 3p xre’s. Behind that is a lock.
The magnet for the reed switch is located in the black trapezoid just in front of the handle. It’s made from fiberglass cloth and cast epoxy resin and tinted with shoe polish.
You can just make out the magnet at the left.
The business end.
This how I manage heat in a plastic housing, 1 1/2” copper pipe with a portion of pipe cap attached to the 3-layer copper base plate. On the side of the tube is the driver, the reed switch cast in epoxy, and a momentary switch for programming.
A close up of the reed switch located below the right hand screw. The epoxy is fitted to one of the interior ribs of the host to keep it aligned with the magnet.
The rest of it is a cage to hold the dpdt switch, 8 male Deans connectors for the 30 4/5 subc cells, and the bottom end of the copper tube.
Lastly, here it is with some of the packs installed. There were two - 5 cell sticks, 4 - 4 cell sticks, and 2 - 2 cell sticks in a 15s 2p arrangement. I canabalized the 2 cell sticks for bike light packs.
The handle on your shocker reminded me of this light along with your question about reed switches. If you wish I can dump this post into its own thread and just create a link to it. This wasn’t meant to be a hijacking but it’s a big light with a lot going on.
Thanks for posting, very cool light you have there.
That seems to be the sensible way to use a reed switch, with an actual permanent magnet for activation. I came to the conclusion that trying to do an electro-magnet activated reed over the distances I would need wasn’t going to be a great idea or very efficient so I decided to go back to just doing a spring loaded contact to get the trigger switch line into the head.
Wow it’s been a while since I’ve been on here but it’s definitely time now to get this project finished.
I’m sure you guys know the feeling when you have 10 or so aspects of a project that all need attention and non are obvious or simple to knock off the list first. It’s easy to get sidetracked.
In any case I’ve now got two of those critical parts working. Namely the clicky switch circuit that passes power into the driver cavity through the contact board and the layout of the main power circuitry on the driver assembly itself.
First is the turning contact for the clicky switch. I just needed a raised contact patch that would complete the circuit between the switch wiring in the handle and the MCU in the head. That was easier said than done since it needed to be isolated from the grounded contact board and make contact only with the pin on the battery carrier when the body of the light is fully tightened down. Was fiddly to get the height and location of the copper patch tuned in but thankfully once I had it in the sweet spot it worked as planned.
It’s just a small piece of copper center punched to create the raised contact area, then insulated from the plate below with some kapton tape. Behind is a small hole through the aluminium with the wire to the MCU passing through it, the whole thing is then epoxied into place.
…and here is an old photo showing the spring loaded pin on the “battery carrier” that makes up the other half of the system.
Next I had to tackle getting the main power to the driver board. The positive will run directly to the LEDs so I cut a slot out of the driver assembly to accomodate the wire and for the ground I mounted a copper standoff to one of the driver posts. The whole assembly is grounded and each drivers outer ground ring soldered directly to the copper posts to make a solid contact. It’s really messy stuff so don’t look too closely, but hopefully it will be functional. The small red wires are PWM signal wires for each driver.
So that’s it for now but hopefully with the ball rolling again I’ll be making plenty of progress over the next few weeks. Next up is torture testing the whole power system wiring at full power (~18Amps) to make sure nothing melts or shorts out, fingers crossed.
Looking good. What are you going to do with the excess heat? May I suggest running a small power plant to supply electricity to a large town. Whats the eta for night shots? No pressure or anything.
Not a bad idea, though I’m hoping to get a few extra lumens out of the red hot glowing carcass of the BTU myself
I’m focusing entirely on this light at the moment so I should have it up and running well before Christmas, that is if I don’t spend too much time drooling over in your BTU monstrosity thread!
This forum is incredibly intoxicating, so many cool and interesting projects going on!
Quick update on the driver, i’ve been building the final version of the control board and programming it with the STAR firmware.
Of course that means I spent the first 2 hours dicking about with the SOIC clip and building a whole second board because I wasn’t able to power up the old MCU for flashing…thought it was because the pins where a bit too angled and dirty. Of course once I built the second board I realized that star 2 being soldered for moon mode doesn’t allow the chip to be flashed…doh! That might be something to add to the Firmware annotations actually as I’m probably not the only fool to be caught out by this
Anyway I ended up with a cleaner board than the first attempt and decided to investigate adding low voltage cutoff capability back to the zener modded driver.
By my calculations I needed to replace the 19kOhm resistor on the voltage divider circuit with a 47kOhm version to get the correct Vout range for the MCU to measure. I also needed to get a clean battery plus+ (>6v) connection for the voltage divider that wasn’t connected to the zener diode controller power circuit. Since otherwise the measured voltage would simple be at a stable 4.3v just like what the MCU sees.
Ultimately I’ve ended up with this setup. Bear in mind I haven’t yet tested the LVC using this board but theoretically it should work just fine, at least once I’ve dialed in the correct settings in the driver firmware.
Front of the control board showing the 47k resistor connected to the unused Led - traces which I’ve reappointed as a clean battery + supply. 200Ohm resistor as usual for Zener mod on the diode pad.
And the back showing the spaghetti wiring. From the battery + pad to the led - trace is a wire which I’m using to feed clean 6v+ battery power to the voltage divider circuit on the other side. The small long wire going from ground to star 2 is simply a workaround for not being able to flash the MCU when that connection is soldered. So now I just unsolder this wire before flashing but I’ll probably adjust the firmware so that moon mode is enabled by default.
Again the long thing wire is the PWM signal that will be driving the 7135 slaves and the bigger wires are power for this board.
Finally there’s the usual 4.3v Zener diode piggybacked on the the capacitor.
Big thanks goes to JonnyC and everyone who worked on the STAR firmware, the documentation is fantastic and the driver source is a joy to work with. Just fantastic stuff all round. Not to mention I have some 1uF caps on order to make this an off time memory driver just how I like it. :bigsmile:
