Are there any mods which need to be done for having a good light?
Are you sure? The LEDs sure look like they have the green base (xm-l) instead of the silver base (xm-l2).
If you also have the 3-emitter Kings, how do they compare light-wise.
For these two (SkyRay & UltraFire), beam vs. spill, artifacts, rings, visible flicker or humming sound, etc?
Thanks for as much as you can tell!!!
Sounds too good to be true, but for the Price, I ordered one … Thanks for the Heads-Up…
Me too…hope it is the real xm-l2.
Well, if I’m not mistaken, I actually can see 3 leads there on the LED so picture shows XMLs, not XML2s. But it says XML2 so…hmm.
:bigsmile: Bought one for $ 15.76 using a coupon Dx.
Now to wait for the send.
I could not resist it, and ordered one.
it will be my first compact 4x18650 multiemitter light.
$16 for a SRK is awesome!! :bigsmile:
I would buy it if I knew for sure that it’s XM-L2 just because of emitters but I’m not 100% sure and I see you guys are not too.
It surely looks XML 2! Can only see silver, not green around led
Edit: it could probably be just the white centering rings!?
What coupon? can you share? Please thank you!
Wondering the same thing I just bought one for the $25 but might grab another if a magic coupon code appears lol
I wonder if it's a typo. I searched for a $10.00 coupon with no luck.
A $10 coupon too would make this irresistible…where did you find one?
Also, I think there must be a strong case of wishful thinking going on, because I’m pretty sure both of you who said the picture shows XML2 have been at this hobby longer than me, and I’d say its pretty clearly showing 3 wires to the LED…which indicates XML…unless I’m the one hallucinating and/or there is another pic?
Either way, if there is a $10 coupon, gotta buy it
I see a bit of green on the substrate. Though there’s no guarantee you’ll get what’s in the pictures anyway.
Yep, either way, $25 for a sky ray king 6x XML isn't bad.
I really don't need one, but ordered one anyway!
Maybe I can replace the leds and reflector with the supfire m6, without too much modification.
Now we just need a decent driver (anyone willing to build one :bigsmile: ) and this will be one hell of a light!
I just ordered one as well! My first srk. I had a $25 gift card from a dx giveaway, so i barely paid anything at all for it
and used a store credit that I had from over a year ago.
I agree, the pic at first glance looks like XM-L2s, but after zooming in, I think I see the 3 leads to each emitter which sould indicate XM-L.
What is most important though is the description is XM-L2. That is what we should get.
