OK I've changed the 15, 17 and 20 Direct Drive drivers. You'll need new links though. They are all under my OSHPark profile.
The diodes on the FET boards are the stock off the Nanjg boards, I had to special order the ones you have on your 20mm I built TexasPyro…but it worked like a charm though
(DIY’ers can’t be choosers )
It was my fault the 17mm board got pushed…we hadn’t reviewed it…my apologies to you Mattaus. I already ordered 3x of em…so that is my penance for rushing you.
So that last SRK board with the FET looks rather awesome. I just can't keep up with all that is going on in the world of drivers. I'll just wait until RMM stocks them :)
New links in place.
Tivo532 has a couple:
Thread - DIYDriver AMC7135(PWM) and DMG6968U(Direct Drive)
OSH Park Project - DD
Thread - DIY Driver Nanjg Style/AMC7135 using Z8F082A MCU
OSH Park Project - 7135
Make sure you mention his uses a Zilog MCU not an ATtiny13A
It has 8k flash, but needs a special programmer…but I tell you, his turbo my using those FETS! WHOAH!
And for a little driver porn…forgive my photo ability…I only have a cell phone camera
Nangj 105C 32*7135 SRK driver
This one was done on a skillet on my stove
TexasPyro 20mm Nangj 105C
This one was done with a hot air rework station (in about 20 minutes)
You got one already? Wow, that was fast...and I'm jealous :)
Darn, I think I ordered before you changed. Do you know if I have to request a cancellation from OSH Park? Hoping they know to use your latest version.
EDIT: I created Support Tickets asking them to substitute the changed designs for my orders. If that doesn't work, I imagine I might be able to rig a ground connection on the boards.
Shoot em an email BEFORE it goes to production
Mattaus wrote:
OK I’ve changed the 15, 17 and 20 Direct Drive drivers. You’ll need new links though. They are all under my OSHPark profile.
Which ones did you order? You might be able to add a couple pieces of wire near the edge to act as a ground ring.
All 3. The 15, 17, and 20. I created support tickets for them. If that doesn't work your wire idea will probably make them functional. Thanks for the suggestion.
I’ve sent TiVo a pm with an invitation as he is offline now and this thread may be well down the pages before he comes back. Any other Oshpark flashlight projects that people can think of should get mentioned as well.
The BAT54WS is in SOD-323 package. The BAT54/A/C/S are in SOT23 package.
I would definitely hold off with the FET based design. It's not working well with more than one FET (accommodates up to 4), and he's still working on a solution. The fix will probably be a design change.
Thanks Tom, I want this to be as inclusive as possible but it makes sense to be sure that these are working systems. Is the 7135 board a go? Matt’s larger designs are based on Comfychairs work on the nanjg east-92 which is well enough established by now but the 15 mm board uses a much smaller FET that has not been tested to any great degree if at all. I have some of the IRLM2502’s coming that I hope to try on a regular nanjg board within a week or so but they were an option suggested by Werner for a very similar project(I would call it a parent project in fact) that he was(and may still be) working on. Patience not being in abundant supply around here we’ve been jamming to get these done and ready to try but testing has been mostly limited to the 70N02 FET. I would suggest that initially at least people consider these FET boards as beta prototypes until they have been assembled and played with in greater numbers.
I "think" the Z8 7135 board is a go, but no experience myself. I'm all setup with the tools and able to program both Tiny13A and Z8 based drivers, just the Tiny13A's have a big advantage right now in developed/tested firmware. Tivo did an excellent job, but doesn't have battery management or e-switch support yet. Love the ability to re-program the boards from the spring side - I've used it and it's really nice, not having to dis-assemble a pill.
Thanks for doing this! I agree - it's moving way too fast. Waiting on build/test threads of the newly posted ones. Not sure what the thru-holes are for, like in the 17mm FET - was hoping it was for programming .
If you were designing a board from scratch couldn't we just reroute the traces needed to reprogram the attiny13a to through hole points as well? I don't know if there's enough room but it seems like you could do the same thing.
I got this one from Scaru. Triple XML PCB. Work awesome with the FET drivers. I’ll have to get back to that project.
I traded him for a few of those boards. I thought they came from another fabricator as they were thinner than 1.6 mm. Thanks for the link. If Scaru gives the thumbs up, there’s a category waiting for it.
18 of the original design with no ground ring already being made.
I didn’t even notice.
