Oh yes, I knew I forgot something, battery carriers thanks djozz
how cool would it be if we had 3xAA serial, 4xAA serial and maybe 2S2P because I remember looking at Sunwayman D40A battery carrier and thinking how nicely it is made, would be good to copy that design. Also 3x18650 serial and parallel and 4x18650 serial, 2S2P and parallel…
This is not hard to do (on paper but I doubt that OSH Park accepts hand drawings), and it was one of the reasons I instaled Eagle but I thought it would be like: add board, specify shape and diameter, add pads, via holes, solder mask and milling marks but after about 30 minutes I couldn’t even find how to draw a board shape I expected to see component libraries and then just drag & drop resistor, d&d mcu btu noooo.
It’s discouraging to think that it would take me 2 days if not even more to make something that PCB gurus here would do in just 5 minutes…
If anyone has anything they want designed in Eagle please PM me and I'll see what I can do. Please note it helps if YOU have a very good idea about what you're after first. I find it difficult to get motivated if I'm doing all the thinking on a project I have no meaningful/personal attachment to. Sounds odd I know lol.
I’d very much like to encourage projects and think each one should have its own design thread that can be linked to here but having them mixed up here would be a mess. Matt is good at this and these are great topics for general forum discussion as they can be very inclusive, stimulating a lot of input. I think battery carriers and switch plates are am excellent idea. Try and be specific when labeling them so that those using them later get the right ones.
Yeah I need to improve my 'finishing'. Labeling, revision status etc. Because of the numerous versions of the same designs I got a little lost with where each was at and thats why we ended up with a few boards missing rear ground points.
You know what they say - practice makes perfect :)
+1 on the 4 x aa battery carrier as per RBD. Serial and parallel. I could probably sketch something up with rough dimensions in DraftSight. Its the boards I would not know how to tackle.
There are too many layers in the EAGLE you are switching here and there. It is very possible you will omit somethings. After finished my layout design, I always transfer it to Gerber Files and then double check the layout layers by Viewplot ( Gerber Viewer ).
It is the same program file. If you do not purchase a license, it is a free version. Some restrictions will be released for the full version after you purchase a license.
I have not done a test order. I don’t really need a 4 x AA carrier myself.
12 awg wire should fit through the vias to connect the boards. Four around the edge and one in the center. The vias (on the topside of the top plate & bottom-side of the bottom plate) should then be covered in a thin layer of epoxy (kapton or packing tape even) just to prevent anything in the host from shorting top to bottom through the supports. Silkscreen is used for extra abrasion resistance in some places.
Masked vias look cleaner to me but those need to be soldered from the inside. Its soldermask + silkscreen. If in doubt, get exposed vias, easier to solder.
Again, untested. Only order one to try them out. Oshpark provides three copies anyway. $9.05 for three (34.2mm diameter). I could push the size down a bit to save a little on cost.
I don’t know if a simple 4xAA carrier deserves a thread. Let me know if you prefer it moved. Somewhere. Into the void. Perhaps we could use an “Oshpark request / suggestion thread”?
Eagle feels user-interface wise like a time travel in the early 90s (or worse )
I’d give diptrace a go: http://www.diptrace.com/
It also has a free non-profit version (2 layers, 300 pins. you can request a 500pin version for non-profit hobbyist or academic use) and a big upgrade/ui overhaul is coming in the next months.
Thanks for drawing these carriers Helios, although the design would not have been as time-consuming as making a circuit board, it must have taken some effort to make them.
I think the pace at which ideas come up for Oshpark designs would justify such request/suggestion thread, perhaps you could start one, or Rdb or Mattaus?
