Price has dropped to $97.00 at Lightmalls and $98.00 at Manafont. Guess these haven’t been selling to well.
Zeke, what happened? Did all the lights work ok?
thats also prolly because it can be had for about $85 shipped here
18sixfifty bought his here
It may be a business strategy to sell cheaper flashlights that require more batteries, and make money on battery volume….
Anyone got this light?
I get 3A tailcap with 4 battery, not impressive.
Then i got an extra extension tube and change the driver.
Result: 5x Sanyo 2600mah get 7A tailcap current! Impressive amount of light!
Waiting for my last Sony 26650 50A battery and will see if the light handle 5 of them!
Try to get beamshot to you guys but i dont figure out to do it.
you can get to the driver? oh cool… and yes please post the the mod to this light.
I have one too it’s bright but could be better…hmm i didn’t know you can add another battery to it and still work
BTW… which driver are you planning to swap it with?
The Reading I posted was With the driver installed and 5x battery.
It is a driver for SST 50. I also use this driver to my 12X t6 lights. Have try to install 4 of the KD 9A driver but all this driver died or dont work.
The Board is big so you has to remove the treads to get it installed.
It is the batterytube who fastend the driver. Use it with thermal paste and not use any spring. The driver is designed for up to 18volt input. The tailcap is about 4A with 4x battery and 7A with 5x Sanyo 2600mah.
Here is link to the driver. This guy deliver now tiny driver Board for SST led.
thanks for the link, the driver is 6mm bigger than the original… but I can’t even get my driver out from my light, how did you able to get it out?
I did a couple (J12 & J18) for a forum member and it took a nice tug on the spring along with some twisting to get the spring out.
TR-J12 or TR-J18 isn’t difficult to pull the drivers out… I was talking about the drivers on the 15 LEDs light
Now at aliexpress for $58
that is really cheap
thanks
And inexpensive…
Wow. Less than $4 per xml2 emitter. Sure wish they would make these long lights with side switches.
So what does this light need?:
- I think I read 18650 said there are some open spots under the emitter base. So copper sheet inserts to get the heat to the fins.
- Copper plugs through the one large emitter base
- Better driver or maybe a driver mod?
- Side switch mod (not an option on a light this long)
- Dedome the 3 center emitters
Sounds like a totally unnecessary, but fun project. I really like the form factor and size of that 12 emitter that RaceR86 modded, but with stock xml2's for $58 this one is looking irresistible to me. Anyone got a better bang for the 15 emitter buck option?
I bought one of them a while back. Not terribly bright and the driver died. also it has one round aluminum star and it’s hollow under the star and around the edges where the emitters sit. The star is sitting a a large donut. I filled the stupid hollow donut in and now I’m looking for a new driver. But I have a feeling I mostly bought some cheap XM-L2’s.
If you wire the leds 5S3P, a 5xT6 driver will work, or the extra voltage of XM-L2 will kill the driver?
Hard to say what will happen until you try! At least for me, I’m not much of a driver guru.
Might be worth a shot though. Potting the driver really good would help the chances a lot.
Not a fan of boost drivers in big lights. Sorry, I don't know the answer Zeremefico.
The way I look at it 18650. That hole in the pill made this light's price drop. So I like it. Nothing some good old reclaimed copper can't fix. The light looks like it could stand more heat sinking mass and surface area, but hey, the cost is low once the 15 xml2's are factored in. Sure they are unbinned and probably cool tint. But with 15 of them, I won't matter that much.
Still wanting to hear if anyone has a better alternative for about the same cost..
As long as the number of emmitters is dividable through the number of batteries used it can be used with a FET driver…
So 15 LEDs and 4 batteries might get difficult…
Maybe drill the center three LEDs away and use one additional led with a seperate reflector and driver…
I also like the parallel batterytube multiemitter lights more especially the batteryvoltage monitoring is difficult in such a beast of a light with series cells…
