Oshpark Projects
I’m about to put my very 1st scratch built driver together. I’ve got the 17mm FET board, V1, and all the components. But now I can’t seem to locate what goes where and in which direction. This is pointed at which resistor is R1, and which direction does the diode go? Is the line on the diode the positive?
For the diode, best to check the datasheet for the specific one you have. They don't all follow the same rules.
Pics or it didn’t happen :smiley:
Tom, I'm still young and I need a headlamp strapped on and glasses as well. My hearing is still good though!
You really don't want to see this ... Can't believe I'm planning on playing softball again this year - first game this Sunday morn. These guys were begg'n me - dunno why, accept maybe for a few laughs as I stumble down to 1st base. Actually my reflex's are still pretty good - been playing ping pong and can still keep up with the quickness. I pitch, so reaction time is extremely important against these roid rage kids and their shaved bats... (ooops, off topic). Well, bats that are high powered and mod'ed -- sounds familiar...
Sure you can… just don’t shower or change your underwear for a couple of weeks. You’ll be smellin’ big time in no time. J)
Welp, my old standby version of luxdrv doesn't work on the 17mm FET board (sometimes a half-press gives two mode changes instead of one, sometimes none at all), even though with the same components on a 105C PCB it works fine. I think I need a nap.
Based on the components as they were on the Qlite. I wired it as it seemed best and the DMM shows power, but no light. I’m at a loss.
Only to others though
"Based on the components as they were on the Qlite. I wired it as it seemed best and the DMM shows power, but no light. I’m at a loss." which board?
Matt’s first FET board, the one with no ground pads on the spring side.
Can you post a photo of both sides and I can tell you if it's a hookup issue or if there is (I hope not) a potential trace issue?
Mine acts like the early attempts when the code didn't work right without an added capacitor. Just weird, unpredictable mode changes. Sometimes it even does a strobe mode that's not there. Sometimes it does weird patterns of blinks like morse code. Checking the board with the meter, the cap is connected to where it should be.
Check the Vcc voltage of the MCU to make sure the diode is not connected in reverse.
If the diode were backwards it wouldn't work at all.
The diode seems to be compatible with what comes on the 105C, I get 9 blinks in luxdrv's battmon mode from a cell that measures 3.87v, close enough for me.
Now that I think back, on the big 46mm version, mode changing went goofy as well when I was testing without the big 470uF cap. I'm using this one, should be correct right? Does it just need one rated higher than the 105C's original?
Comfy, I think that capacitor is correct, I think I've seen mentioned that the stock cap is also 10uF. This one should even be better since it's an X7R from a name brand... dunno what's going on there. You could try and stack a second cap on top of that one to see if you get any better results.
Pics of your build please?
Diode backward?
What OSHPark board are you building the 15,17, or SRK?
Comfy…is that the 17DD initial release the one w/o the ground ring on the battery side…might not be getting a good ground (floating ground)
Looks to me like he's got a wire soldered directly to the FET pin for ground, is that correct?
Ah…duh…bench test
Why did you go to a 10μF from a 470μF? Wouldn’t it be advisable to go higher rather than MUCH MUCH lower?
I have a separate ground wire stuck right onto the FET's ground pin, testing right now with a battery box with alligator clip leads but I'll be using a separate wire soldered to the inside of the pill, and rely on just a press fit to hold it in place, it's plenty tight like that if you don't completely file off the flashing.
