Review: Palight X4 1x14500/1xAA *Beamshots added*
I like side switch lights easy to operate with out changing position of grip, beam shots when you can.
Thank you
You may have set the standard for reviews many of us “noobies” really want to see, especially for budget lights.
For those of us from the BLF “parent thread,” here’s a link to the questions, issues and unknowns which koyotee was kind enough to respond to: A New 1xAA/1x14500 light with Side Switch (Stepless Version Added)
Great job, and Thanks!
ⓣⓗⓐⓝⓚⓢ…… nice review
is it floody or a thrower?
is it brighter with the 14500?
Thanks for the review! Always appreciated when people take their time and effort to share with the community.
This light can be found t cqg… aaand… any other place???
Aliexpress, soon at other vendors too. I think a groupbuy is also very likely to happen.
Nice review, this is a handsome light. I think it looks better than the solarstorm .
Thanks for the review koyotee. Am I just being selfish hoping for a UI comparable to zebralight’s?
Im not familiar with the zl ui, but i can tell you i like this one :slight_smile:
Beamshots added :slight_smile:
Beam shots are with 14500 battery? Maybe adding some with AA would be helpful.
This sounds like a really interesting light. On the outside it looks like it was modeled after an Olight S15.
I wonder what the internal construction is like. Is there a pill? If so, does the pill screw in or does it simply slot in with an alignment tab like the S15?
I might get one of these. I like the styling. I’m a fan of small sideswitch lights.
Yes, with 14500, i was thinking about AAs but i’ve forgotten them at home, i’ll do that today :slight_smile:
nice review… but surprisingly 3.8A Convoy C8’s spill is so dim, I thought it would light up the garage even more :slight_smile:
Maybe it’s just me, i’m not that pro at taking beamshots yet :slight_smile:
FT has its sibling, the Solarstorm sc01, for a lot less... not sure if its the same or not,
(just saw it posted in the FT deals thread)
You should pull the trigger and do a review :stuck_out_tongue:
If all goes well I'll let everyone know in a few weeks.
Mine has cooling fins under the switch, this one doesn’t.
so yours must come from Hawaii ;)
