It's not a type, it's NEC's model number for that specific part. What did you search for to get that list? I don't see anything there that looks related.
http://www.digikey.com/product-search/en?vendor=0&keywords=2sk4212
It was the package LFPAK33. Less than 4mm square with low Rds at 4.5V and very high power dissipation.
EDIT- I realize This is the usual pap but it still seems worth a look.
WOW! Interesting and if those specs on the RDS (on) then wow…very low resistance…nice
The current and power ratings are through the roof as well. I think I looked at ones like these in the thread where CC and Werner were working on this idea. They’re not expensive and have been proven up to 175C. Less than half the size of the TO 252 leaves room on the 17mm board for needed resistors. Pick some up?
EDIT- The LFPAK 56 is 5x6 mm(slightly larger than a 7135 including pins) the LFPAK 33 is 3x3 mm(smaller than a 7135). The 56 has even lower Rds on and higher power dissipation than the 33.
Depending on the Qg, it probably won't need the resistors. And if you're picking a new part might as well make sure to get one that works with the simplest circuit possible, i.e., no resistors.
Or, try the AOD510 on the existing board design, it may not need the resistors either. There's not going to be much measurable difference between 4mOhms and 2mOhms, there's no magic bullet there, it's still limited to no more than what it would do with the cell wired direct to the LEDs.
I remember the FET led4power is using on his driver had this odd shape and very high power dissipation numbers and the K4212 from earlier posts and just spent the evening wandering the web looking at specs. When I googled k4212 the Digikey link came up and I looked at pictures until I saw this odd shape again. Googled some more and found the NXP page and mouser links. BTW mouser is soo much easier to navigate for parts.
True, but the smaller package should work with either the 17 or 15mm boards and might eliminate parts/traces on the backside. They also have higher operating temps and higher current ratings for their size which may or may not be helpful. It’s a newer, possibly better design than the Dpak. I’m still going to try out the 2502 but it’s not as likely to be able to handle an imr 14500 or 14650. In the end, whatever fits and works is fine by me but we’re still in development so I don’t see any particular reason to be wedded to an older part unless it works better. The “33” is the same size as the 2502 but is more than an order of magnitude more robust in almost every respect and the “56” is only slightly larger and even more potent. There may well be reasons that they won’t work but it may also be true that they’ll work better.
I have 150 of the Vishay 70N02s, that's one reason to use them... :Sp
any reason to use the luxdrv when STAR V1.1 and Star_mon V1.0 work…or does it not work…I haven’t gotten my boards to build yet
Not as a sidetrack…see if you can invite this guy over to join in the fun
On the SRK version... minimo (phase correct) works fine, but is noisy, as it has been on any of the drivers I've used it on. But STAR v1.0 works on it too, and I think (though not sure) it's set to use fast-PWM as-is, and I didn't change anything in the code except to plug in my own PWM values.
On the 17DD, luxdrv didn't work right before the two resistors were added. STAR v1.1 did work, but again I'm not sure which PWM version it's using as the default. After adding the resistors, it worked with the other DrJones fast-PWM firmwares, which none of the other boards using the FET have been able to do.
I even took the same build of minimo that worked on the SRK driver, and flashed it to the 17DD (before adding the resistors - and remember, the SRK board doesn't have those two extra resistors, and yet it works fine), and it didn't work. It did the same goofy halfway or double mode changes. So, same parts, same firmware, different PCBs, one worked and one didn't.
Or you could just ask me.
Yes that's nxp lfpak 5x6mm. Many other manufacturers have similar 5x6mm power packs=power soic.Nxp lfpak is interesting because of exposed drain pad,so no need for extra pad on pcb for cathode led wire(of course this isn't the only reason why I chose nxp mosfet,many other parameters are important).
The biggest difference between lfpak and old packing technologies like dpak,d2pak etc. is lack of bonding wires,which means much better characteristics.
That's all wonderful, but are the olde-timey FETs prone to failure in a design like a 4.2v max flashlight driver circuit? A motor controller for an electric/hybrid car, sure, that's a highly stressed and critical application. But that's a long ways from a flashlight. If the driver gets up to 150*C, you got bigger problems to solve first.
Per compile
define F_CPU 4800000 CPU: 4.8MHz PWM: 9.4kHz ####### use low fuse: 0x75 #######
Did you compile luxdrv at 9600000
define F_CPU 9600000 CPU: 9.6MHz PWM: 19kHz ####### use low fuse: 0x7a #######
OOPS…I stand corrected
bove PWM speeds are for phase-correct PWM. This program uses Fast-PWM, which when the CPU is 4.8MHz will be 18.75 kHz
Nice to see you led4power. I actually like poking around the web so I don’t often ask unless time is critical or I just can’t find something. I learn more this way. I had actually first seen that FET before you posted your driver thread and it totally made sense to take advantage of its capabilities the way you have. Definitely subscribed to that one by the way. Comfychair I have loads of 7135’s but I’d use something else if it worked better. You seem set against trying another chip more for personal reasons than performance based ones and there’s nothing wrong with that but the Dpak doesn’t fit on anything smaller than a 17 mm board and that not well. I’m not saying we not use the older style FET at all, just that we keep our eyes open. Both Werner and tivo532 had to resort to multiple small fets which introduced yet other issues because of inadequate power handling capabilities and this new style may eliminate that problem. As to the temp rating, having excessive overhead is better than having none. There may certainly be other small FET’s out there with current capacities somewhere between 5A and 70A and I’d be fine with one of them(the 56 is rated for 100A), I just didn’t see one.
I put this one together like I knew what I was doing, it went together nice and neat, including the resistor under the PWM gate…all re-flowed nice and pretty. Everything went in place nicely on the back as well. I sized the board to be a tight press fit into one of Ryan’s big copper pills for the HD2010. Snapped it in, inside outer ground ring is making ground, soldered the XM-L2 U2 1D on the 16mm Noctigon (glued in with AA) and it works. Mostly.
No moon engaged. There are 2 modes, Lo and Turbo. Lo is at .25A and then it goes to Turbo at 5.8A. How in the world have I lost Med and High?
In MiniMo, change TCCR0A=0b00100001; to TCCR0A=0b00100011; for fast PWM (18kHz).
Note that a PWM value of 0 doesn't switch off in fast PWM mode.
Thanks! I'll figure this out, eventually...
The LEDs don't turn off, but that's fast PWM when using 7135s, the FETs react differently at the very low end. But does the MCU shut down like it's supposed to? I haven't had time to experiment yet and check any of that, I guess measuring parasitic drain between phase correct & fast PWM versions (assuming the LEDs turn off) would answer that.
I do know that with the phase correct code it used to work with a value of 1, but after adding the gate resistor it no longer turns the FET on unless that minimum is raised to 2. With the same code the 7135s don't start working until 4 or 5.
If there was a performance difference between LFPAK & DPAK parts in this application the same as what there is between DPAK & 7135s, then we wouldn't be having this conversation and never would have bothered with designs using the DPAK parts...
I'm not opposed to changing anything ever for any reason, but I am opposed to changing things that end up only making it theoretically better on paper but don't show any difference in actual use. If they're both similar cost then that's a wash, the performance is similar since once you get down into the sub-10mOhms range there's just not much improvement to be had so that's basically a wash too, yes they are smaller so the board design gets easier so that's a real tangible benefit, and then the durability issue is a wash as well since neither design is highly stressed enough to show any vulnerability to failure.
The LFPAK devices require proper surface mount equipment to attach them to the board correctly… solder paste stencil, reflow oven, etc. And good luck getting them off if you need to…
