I just built the second BLF Tiny10 FET. :bigsmile: Itās running 3.48A to an XM-L2 T6 3C. Iām either going to hook it up to a de-domed XP-G2 R5 1A or a domed XP-G2 R5 3C. Whatdya think?
The little 3ā Texas Poker is now doing 552 Out the Front lumens at start up, 452 at 30 seconds. Pulling ~3.02A from an Efest IMR10440. De-domed XP-G2 R5 1A.
BLF Tiny10 FET with 22 ga Silicone wires. No limits in the firmware.
Nice! I did get access to some lab power supplies so I have been playing around with XM-Ls at sub-zero temperatures (peltier plates and dry ice); it got brighter all the way up to 9 amps. Someday Iām gonna get set up to measure lumens and redo that experiment and see how many lumens I can hit with an XM-L.
No problem, if they work without them the gate resistor can just use a jumper.
Is it possible the longer trace on the SRK board is why those don't need the resistors? I really can't come up with anything that makes sense to explain it. :~
I donāt know about dissolving fiberglass since itās resin and fiber but you can sand it thinner. The more common way of doing it so far has been to drill or machine out the center pad and replace it with copper.
Iām amazed at how close the components can be on the driver and not have issues. Some are difficult to see if theyāre not touching, theyāre that close. And yet some pretty major amperage runs through the circuits and all is well, and with these little bitty drivers the traces just canāt be all that bigā¦is 22ga wire from the driver to the emitter overkill? I had to stuff the wires into the TP pill, even had to pull em through with my curved jaw hemostats, they just do fit, like everything else on this driver.
Most of the traces only carry signal currents and on the Tiny 10 the trace length to the led pads is practically nothing. Led + is straight through the board with no trace, led- is less than 1mm and gnd is a wide tab. Lately this subject has received more attention and an effort has been made on some of the new project boards to make sure of adequate trace width. If you think itās necessary you could scrape the solder mask from the drain trace and when you solder the FET or 7135 it would flow to the - via. If it is an issue then that trace width could be increased but that driver wasnāt designed with 10A currents in mind. Wire size is a different matter due to increased length but at 2A awg24 will only drop .017V in 1/10 foot(1.2ā).
Mineās working fine and Iām loving it! Was just stating how impressive they are.
And yeah, keeping the battery size in line with the driver size there seems to be little to no issue of power handling. 3A with a fresh IMR10440 is ample, and of course that falls with the deteriorating charge level. On a positive note, the more the cell drains the slower it drains, right? lol
Seems to me that with the way mineās running, Turbo should deliver around 15 minutes, High should make about 30 minutes, Med around an hour and Low around 10 hours. Give or take.
That being said, aināt no way itās gonna run 15 minutes on high! Something would meltā¦
I agree completely. No sense trying to stuff huge wires in there when it's only a 1" run. This isn't a bad example of that but I've seen some pictures where people were trying to stuff 18AWG in a 1" run to an XM-L2, not necessary. Even 26AWG doesn't show any appreciable loss at 5A at that short of a run. On the SRK's I really like the 22AWG because there is plenty of room and because the wires have to be so stinking long, on normal lights with the short wires 24-26AWG is just fine, even for hard driven lights.
Somehow over the years here I overlooked those facts. It will make my projects come out a bit easier using more appropriate gauge wire. I learn a lot from your discussions here. Keep up the good work and thanks.
I have noticed a difference in wire. If I use the Teflon coated, silver plated wire, (with larger strands), versus the silicon coated plain copper wire, (with fine strands), I have to use a larger gauge of the fine strand wire, to equal the lack of resistance in the silver plated larger strand wire.
In other words, I have found 22ga silver plated large strand is much less resistant and I have to use 18ga silicon coated fine strand, to get the same amperage as 22ga silver plated.
I believe it's all about the wire diameter, as DC current travels through the wire, so larger strand allows for less resistance. Of course, the Solid 22ga will do about as well as any of them, since it's one large strand, versus many strands. Silver plating really does not seem to matter, since the current runs through the wire, not on the outside of the wire, like AC current does.
Being as how I have 22ga and 20ga silicone wire on hand, thatās what I used. If Iād known these things I might have used the smaller wires from previous Qliteās.
Thanks for that info, really is nice to know.
I do have some 22ga Teflon wire as well, with the larger strands and silver plating, but itās so dang stiff! Tuff stuff though, might keep that in mindā¦
