Somewhere back in this thread, Richard mentioned that he was getting a batch of M6s and was thinking about modding a few (like he does with other hosts) for sale.
I am certain that the $38+ price he quoted is for the stock light.
I should have made that clear in my original post; I (like all others) am still uncertain of Richard’s intentions/pricing.
IMHO, the light I describe is a bargain up to $_. You all and Richard will make that decision.
The SupFire M6 is NOT an SRK variant. Radically different light with robust construction throughout. The emitter shelf is integral in the head, the entire top end was carved out a single piece of aluminum. Heat sinking is great in this light. No flimsy little disk sitting in a hollow head.
DBCstm is spot-on correct with his differentiation between the lights.
As I type this, I have both at my desk. From merely the physical differences (weight, Anno, machining, glass, button push, etc.), I could fill a sheet of paper. I am a layman of lights.
Someone else with technical expertise could, I am sure, fill the other side of the paper with plusses for the M6.
I was prepared to buy a stock M6 on its own merits before talking with Richard.
I believe it uses the same size driver, lens and reflector, so I'm okay if folks call it a variant or SRK version 2. It's definitely not a clone though. Even the clones have vastly different construction even though they look roughly similar externally.
Different driver, different reflector, everything about it is different. I’ve modded the SupFire M6, a SkyRay Kung and SkyRay King all at the same time, the King and Kung were VERY similar but not identical, the M6 is a totally different beast.
You didn't deny what I said. Same size driver, same size reflector, same size lens.
SRK clones already use different drivers, so it doesn't matter if the M6 uses another one so long as it's the same size. The first M6 group buy had the reflector changed out to a standard SRK reflector, so it's not different, just different in this batch.
all emitters make light, for the most part, so I guess they’re all the same as well.
The 3 lights I had in hand, and tore apart, were vastly different…so much so that it seems ludicrous to imply they’re the same or even similar.
I’d not have a King/Kung if you were giving em away. I’ve been trying to get my hands on an M6 for a while now. After working on about 250 lights, this fact alone speaks volumes. Immediately after modding the M6, I contacted SupFire and got on board…I was that impressed with their fit and finish. I just didn’t get on board with the M6 due to the insane shipping costs.
Uh, okay. SRK variants are very similar, but so vastly different it's ludicrous, and are and are not variants because they use different drivers. Wut? I can't make heads or tails of your point, but I'll agree that this M6 is a better light than the real or clone SRK's and SRKung's.
Like I said, they all appear to use the same dimensions as far as the driver, lens and reflector goes, so that creates a lot of modding options. AR lens, BLF "SRK" drivers and a 6-7 emitter reflector is on the list. I might even try swapping the tailcap with another SRK variant.
he said in one thread the modded M6 would be $70, i think.—-
but i guess that was a ballpark figure.
he does good deals so i plan to get one depending on price.
i like the driver.
does he sell just the driver ??
My opinion, the M6 is the best of the "soup can" lights, so SRK's and M6's are both soup can lights in overall form factor. Maybe using a generic non-branded term like "soup can" is better?
The King/Kungs I’ve seen are indeed cylindrical in form, like the proverbial soup can. But the M6 has a larger head diameter than the body, or am I remembering it wrong?
I’ve got a spare driver, need to take a look at it…
Also, isn’t the M6 a triple XM-L while the King/Kungs are Quads?
