Uh, okay. SRK variants are very similar, but so vastly different it's ludicrous, and are and are not variants because they use different drivers. Wut? I can't make heads or tails of your point, but I'll agree that this M6 is a better light than the real or clone SRK's and SRKung's.
Like I said, they all appear to use the same dimensions as far as the driver, lens and reflector goes, so that creates a lot of modding options. AR lens, BLF "SRK" drivers and a 6-7 emitter reflector is on the list. I might even try swapping the tailcap with another SRK variant.
he said in one thread the modded M6 would be $70, i think.—-
but i guess that was a ballpark figure.
he does good deals so i plan to get one depending on price.
i like the driver.
does he sell just the driver ??
My opinion, the M6 is the best of the "soup can" lights, so SRK's and M6's are both soup can lights in overall form factor. Maybe using a generic non-branded term like "soup can" is better?
The King/Kungs I’ve seen are indeed cylindrical in form, like the proverbial soup can. But the M6 has a larger head diameter than the body, or am I remembering it wrong?
I’ve got a spare driver, need to take a look at it…
Also, isn’t the M6 a triple XM-L while the King/Kungs are Quads?
The M6 has a larger head so it more resembles a standard flashlight. It’s also deeper with more complete reflectors in the triple configuration, while the reflectors in the 4,5,6 lights are very cut up and shallower.
a quick steal off a google search to show what I mean
I don’t have either light, and it’s been a while since I modded the 3 simultaneously…I’m very forgetfull…probably don’t even remember what my point is, other than that I like the M6 much better than the King/Kungs.
And for the record, I was also slow to learn that’s not a serial number on the M6 but the company’s phone number, in case you are out shining your light and want to make an impromptu International phone call to order a few more…
The warrior does not qualify as a soup can - it's too purty for that classification (in case you are not aware, I'm the official classifier... ), and all those blue buttons and lights? way too much classiness goin on there.
I got 2 M6's now and one FandyFire SRK, and head width are the same, so reflector width is the same too I believe. The M6's height is mostly from the tailcap bump, but it's head does extend a little lower. It's way too close to an SRK to be classified differently. Internally - yes, superior in several aspects.
I'm done -- no more on the names please!
I do think Richard is gonna be overwhelmed for the modded M6 requests. Basically at these prices, he's selling parts and doin all the labor and testing for free. Awesome light and deal....
I was just looking at the M6 driver and am intrigued. It’s got 3 mosfets, one for each channel/emitter, and essentially an ATiny13 or what appears to be so…the top is scratched clean of writing.
There are 4 bays for resistors in each channel, with 3 having R056 resistors in place. Looks like it’d be pretty easy to bump it significantly without changing the driver, which is indeed what I did to the one I modded before and it’s pretty much a beast as I recall, with a start value around 4000 lumens. (need to get verification on that)
So could the mcu simply be swapped out with an ATiny13A that’s been flashed for use with FET’s to get a more desirable UI?
Could the existing mcu simply be flashed with our newer Star firmware?
No, you can’t flash the stock MCU with Star FW and it has a different pinout so you can’t just swap it with an attiny.
You could disconnect the stock µC and connect a star FW flashed 105c to the Driver to control it.
Werner has done it and there are some pics in the M6 resistor mod thread.
btw.: I like the driver concept of the M6 as well. Actually I think it’s way better than driving multiple LEDs in parallel like most of the FET drivers do.
I will make a 105c based design with with 7136 instead of 7135, as soon as I have some time…
Sounds like a nice modded light. I don't care for the M6. It's way too forward heavy and feels awkward in my hand, as it constantly wants to go head down and you have to hold it more forward than the SRK. I still like the SRK best, but RMM does some nice mods.
