Review: DX Powerlight HX-G011 1W 1xAA (DX sku 2089)
Powerlight HX-G011 (Silver)
Reviewer's Overall Rating: ★☆☆
Summary:
Battery: Single AA
Switch: Reverse Clicky
Modes: Single
LED Type: Generic
Lens: Plastic
Tailstands: Maybe
Price payed: $4.28
Pros:
  • Very long battery life
  • Very affordable
  • Small and visually attractive
Cons:
  • Highly variable build quality
  • Not anodized for hardness
Build Quality: ★★☆☆☆
The Powerlight is basically a term for cheap 1xAA LED lights with a clicky switch that look approximately like the light pictured in this review. They are available in a rainbow of colors from a multitude of suppliers. I don't think there really is an "original" one, but I bought two units in two different orders from DealExtreme because DX is well known. The first sample has a black rubber switch that protrudes from the tail by about 1mm. The switch on the second sample is almost flush with the rim of the tailcap, and it does tailstand, albeit a bit wobbly. It comes with a nice landyard and a quick disconnect. The threading on the tailcap of the first sample was quite smooth for the price, but the second sample felt much grittier. The thread is linear, with no definitive feeling when the last thread is being traversed to seat the tailcap onto the body. The body doesn't seem to be hardened in any way. The lens is plastic. The tailcap has a regular spring inside. The light feels almost weightless. It has an O-ring on the cap, so I imagine it will withstand heavy rain or even a brief dunking. The head does not disassemble. The first sample I received worked very well during the first week, but then it started to fail to power on. I think I have isolated the source of the problem to the switch, as it flickers when I nudge the switch with my fingernail. So in summary, you might get a really nice flashlight for the price, but you could also receive a dud.
Battery Life: ★★★☆
Despite being one of the cheapest lights available with a cheap generic LED, it really excels for its battery life. On a good quality fresh Alkaline AA it will produce usable light for several days. On an old AA that no longer powers my wireless mouse, it runs for 12 to 24 hours. If you use it with a very low battery in an emergency situation, make sure not to turn it off, as it will not power up when the battery is very drained, although it will keep running on the same battery. If you accidentally turn it off, wait a few minutes and will probably fire up again.
Light Output: ★★☆☆
The light output won't stun an intruder or blind your dog, but it will light up your path or let you read comfortably at night. The LED could be Luxeon-type, as I have seen this light advertised as "Luxeon LED" on other sites. The hue is a tad bluish. The hotspot has a few little dark spots in it, probably because of manufacturing smut on the LED. The hotspot smoothly transitions to the aura. The focus seems normal for a light of this size.
Update: Upon further examination, the beam quality of my second sample is actually excellent. I would give the light output a full five stars. The brightness isn't so excepcional, but the light quality is. There are no spots, no shadows, no noticeable hotspots, just smooth, clean, usable light from the center all the way out to the edge of the aura. I'm impressed. My second sample is up there with the best of my flashlights in this criterion.
Summary: ★☆☆
The Powerlight HX-G011 is a fine option for a truly bargain conscious buyer. It is also good for using in dirty or harsh conditions, because if it gets lost or destroyed you can probably afford a new one without shedding many tears. I like it. Recommended. If you own this light please leave your star rating! Anonymous users can also rate this without registering. Note that you are not rating this post, but rather the product itself.
DX will sell you switches. If it works fine with the tailcap removed and the negative end of the battery connected to the body with a paperclip you can go:
A) the ultra cheap way and throw away the tailcap then get some metal foil. A square slightly larger than the battery tube will do. Wrap that over the end of the light. Stick it down with some duct tape. Press on the middle of the duct tape to make it switch on. Any sticky tape will do - I just like duct tape. Which we call gaffer tape in the UK.
or
B) Less cheap but still not expensive. Keep the tailcap and do what it takes to dissect it - there may be a screw ring under the plastic cover. If not, go back to A). If there is, unscrew it. Take out the switch assembly - measure it and get a new one of the same size from DX. These ones should be around the right size.
or
C) Free but fiddly - once you have dissected out the switch take it apart and fiddle with it till it works better. Then reassemble
or
D) Most expensive way of all - buy a spray can of switch cleaner and spray it into the switch (Preferably after removing any rubber boot) then operate the switch a lot. Shake out the excess then see if it works any better. If not, then go to A.
Thanks for the tips! What do these cheap switches use, a belleville washer?
I've not had to gut any. I am about to tear apart a Maglite switch to see what is wrong with it - though those are supposed to be pretty good mechanisms good for 10A.
From what you've said, I imagine you don't live in a town so are unlikely to have a Radio Shack or the equivalent nearby. Most such places will have any number of switches for mere pennies. Me - I'd go for the duct tape method.
would that be black gaffer tape by any chance Don
Obligatory Star Wars tale, "Why is gaffer tape like the Force?"
"It has a dark side and a light side
and
it holds the universe together"
Now that was just too funny......i would try to install a smaller tailswitch in there......and where in the hell did the spammers come from.
Preferably to lengthy terms of imprisonment.
Yes......that would be nice, or make a member of the site a Moderator to help get rid of the spammers.
Hmmm, this is quite a pain. The spammers were dumb enough to list their location in the optional profile field. They put Jamaica and Turkey.
I have not been on a site to date that has been spammer free.....and it will not be the last.
Glad to see that it is in fine working order now.
First thought. Wow, it's light. Second thought, "It's nearly weightless". Brighter than I expected with a cheap alkaline in it.
Doesn't look like the head is removable short of sawing it off. Having had a good look with a 30x magnifier, the head would need a saw to remove it. On both of them the LED is better centred than expected.
The squeaking of the threads got to me, but a small drop of thin oil and some graphite (IOW I scribbled on the threads with a pencil) followed by a wipe with a tissue soon sorted that out.
I am skeptical of water resistance, the O ring at the tail end doesn't seem to engage with the tailcap. Will test this when I get home.
Will do a proper set of tests soon.
3 watts - no chance! Not even close.
Hey Don, I'm glad you received these. Not bad for the price wouldn't you say? I'd be interested to see what you think about the beam quality. In my opinion, the two samples that I own have the nicest, smoothest looking beam of all my flashlights. Reasonably bright too, although 3W is obviously a stretch.
CJ 1-Watt Pocket LED Flashlight :
$3.99
http://www.goldengadgets.com/cj-1-watt-pocket-led-flashlight.html
Rubber 1-Watt Pocket LED Flashlight
$2.99
http://www.goldengadgets.com/rubber-1-watt-pocket-led-flashlight.html
I wouldn’t dare request this at the ‘other’ site !
Thanks.
I have two of the ones in the second link...and for the price the kids love them. Not as bright as a cree, im suspecting the led used is a Nichia. The light has good runtime and seems to run fine on 3.2 volt cells. And just wanted to say Welcome to the site CPF..........
Hey there cpf, welcome to the site, enjoy your stay here!
I had two samples of the CJ 1-Watt Pocket LED Flashlight. They are excellent for the price. The threads on the tailcap were nice and smooth, the clicky switch worked well, and the runtime was excellent, more than 24 hours on a good alkaline AA. I carried one with me every day for a year or two, and it finally started to get flickery and I eventually threw it out. It was a great investment of $5.00. I wouldn't buy more just because I personally don't like the rubber grip. But if you like the looks of the CJ-1 you'll probably be very happy with it, and you can't go wrong for the price.
And thats the difference between this site and the other......feel free to be part of the group.
Glad to see you here. I have what I believe to be the same as the second one. It's not what I'd call rubber, it is some sort of hard polymer - as is rubber but not as hard.
Mine lives on my work keys. Still has the AAA I got with it and it is still working just fine. I'd not reckon on serious water resistance, the plastic window at the front has got itself pushed in by some of the stuff I routinely carry in my pockets and I've not yet found a non-destructive way to get into the head and glue the lens back in place. Still looking though.
Other than that, it is a robust and useful little light that seems to have ample runtime for most purposes. If it stays dark longer than that, then even in winter here, we are in trouble.
