Matts retired. Everyone wore him out.
And you were the last straw.
I've been sort of shocked seeing 18 AWG in the big Fenix lights (TK61 and TK75) with the heavy insulation, making it look more like 16 AWG. The wires going from the contact board to the driver are that thick and less than 1" long. I suspect they have a good reason for that, since everything about the design of these lights is about weight reduction. So they seem to value heavy gauge wires over using an aluminum reflector instead of plastic, for example.
Did I break him? Bugger. I did send him a present this morning but now I have to send a get well card as well? This budget light hobby is certainly expensive. Have you seen the price of cards lately?
I'm alive lol. Just trying to focus on finishing renovating my bathroom so I can sh*t again. Nah just joking. I've been doing in my back yard*.
The 72x7135 board an OL request. Lips are sealed on what he wants to do with it! Note it will NOT fit an SRK. Way too big.
- Matt
* It's an en-suite so we've been using the main bathroom. It's just at the opposite end of the house to our bedroom. First world problems.
Now all of the enlightened forum knows where you take a dump, whew, we were so worried! Can you sign this piece of TP for me, pleaaaase!?
Now, get back to work!
Speaking of dump, either yâall are rough on a house or yâall bought a dump cause youâve been fixing on that place for 2 years!!!
(yk Iâm just kidding right? Gotta personalize itâŚhey, look who youâre talking to, the guy that customizes EVERYTHING!)
I donât know what you could use to dissolve fiberglass leaving behind the dielectric, copper and mask layers. Maybe instead of doing that a person could delaminate the board? As I understand it you could just add a ton of heat until the dielectric layer no longer wanted to be stuck to the fiberglass layer. The other layers might delaminate before the one you want though.
Either wayâŚgoing to be a âdestructiveâ method [and probably toxic/chemically as heck], getting that top layer masking and traces off the pcb then mounted to a copper slab is the end goal without destroying the integrity of the overlayâŚgetting there is the tricky partâŚunless you pay a hogillion dollars to have someone MAKE them from the get go
oh and anyone want to see the process for making the boardsâŚas in the actual construction and whatnotâŚpretty interestingâŚitâs europeanâŚbut I donât think the process is much different here
http://www.eurocircuits.com/index.php/making-a-pcb-eductional-movies
In fact in the last video, you can see some tell tale purple boardsâŚnot sure if OSHParkâŚbut makes ya wonder
Iâve purposely de-laminated boards. Some boards are are not bonded as strongly as others.
(This post will de-laminate / self-destruct momentarily)
Oh boy... Not all the boards have their own thread, like the 15mm. Is there any one place I can find the latest, greatest info on the BLF15DD? I just got mine today but they don't have the R4 and R5 resistors, so, am I out of luck? Should I just go ahead and order the latest? Anyone test it yet? Do I have to navigate thru this massive thread?
IIRC the IRLML2502 used on BLF15DD hasnât yet been reported to be buggy without R4 & R5. No need to jump to order replacement boards just yet.
Also, if they are needed, you could cut a trace & scrape a bit of soldermask off to add R4. R5 would fit across 2 vias.
Rufusbduck, was trying originally to keep this thread less cluttered. Seems he was forced to abandon that goal.
Hi Tom, I was hoping to have original research done in other threads and just use this one for links but Iâm not willing to go tyrannical over it so it is what it is. If you have any questions just ask and Iâm sure those of us that monitor this thread will speak up.
After Comfychair finished the initial research on the SRK version( most of which was discussed in pmâs) Mattaus worked up the 15, 17, and 20mm versions and then I posted them here without any real testing on those versions. A few bugs have shown up and since been sorted out but this is new enough territory that unknowns may persist until others can duplicate results.
Dbcstm reported complete success using a customized version of firmware but I myself had iffy results using stock Qlite firmware. He was using one of the Tiny10 boards without extra resistors and I used a Qlite depopulated of 7135âs and needed a 200 ohm gate resistor to obtain stable results. Thereâs no question in my mind that either board can be made to work and as Helios points out itâs pretty simple to break the gate trace for the 100 ohm resistor and jumper to ground with a 10k if one or both are needed. The irlm2502 seems fine supplying as much current as you are likely to get from any 14500 or 14650 cell but standard programs need to be adjusted downwards for the lower mods as each pwm pulse is an unregulated DD rather than a pulse limited by the sum of the 7135âs. Unless you are limited by space or after a very high drive current(both of which Dbcstm overcame) you are better off with a stack of 7135âs.
I had issues with the Qlite FET as well, including blowing out the positive trace under the MCU. I bypassed this by drilling a hole through the pcb at one of the non used 7135 chip ground pads next to the diode and running a 22ga wire from the top of the contact spring to the emitter in a direct route. Then we learned of the resistor in the pwm gate and that has been working. I built my first one containing both extra resistors yesterday on the BLF 17mm DD board (#1 with no grnd springside) and used a contact board of larger size for this particular light. The driver is functioning just fine, albeit with a bit of whine in the middle modes. I used a 200 ohm resistor between the FET gate pin and pwm pad (vertical orientation), one of the 1912 resistors for the pulldown. Not using moon in this light.
The BLF Tiny10 with irlm2502 FET is running perfectly with no extra resistors, 3.11A from an Efest IMR10440. The 4 base modes work perfectly with no audible. Everything done here for these boards is greatly appreciated, and this particular BLF Tiny10 has made my year!
While that BLF 17mm DD board is capable of well over 5A with the right cells, Iâm having difficulty achieving that in the light. It would seem that the battery tube to head connection isnât permitting solid enough ground to reach the high amperage. Testing with the same cell applied directly to the back of the pill results in nearly an amp higher readings. Iâve filed anodization, wire brushed threads, donât know what else to do. (Defiant Super Thrower with a different make of lightâs cheap 26650 battery tube and tailcap)
I'll do a separate build thread for each version once I have the boards. Oshpark estimates they'll be back from the fab on the 13th.
I tested the same version of STAR FW with the only change between them being the PWM speed, one at 9.4kHz and one at 19kHz (both using the same CPU clock, 4.8MHz). Both worked the same, except the 9.4k one was noisy in the upper-middle modes, and the 19k one was silent. Some of the early prototypes weren't happy running the fast-PWM code, but the latest versions seem to handle it just fine.
I've since tested the 19kHz NLITE and also luxdrv converted to fast-PWM, those work fine too.
Sorry if it's obvious but there should be NO noise at 100% PWM...
All good, thanks guys!! Sometimes I think I know this sh#$%, then I realize I know squat, so at this point, some things sound obvious, some are goin right over my head... The terminology can throw me off, and then there's the real details of doing the work - I'll miss something obvious to many others... Ugh.. trials/tribs.
I probably got into the boards too early, more my fault than anyone's. I need way too much hand-holding at this stage. Also, I'm trying to do way too much for what I have time to do. Losing billable hours (pays the bills), way behind on promised mod lights, etc.... I really want to do more, but at my age, I still need some hrs of sleep, otherwise I'm worthless at work (finding that out ).
I've been stay'n with the 9.4 kHz (not the fast-PWM), guess because of the moonlight PWM's.
Yes, for example the version of luxdrv I used for so long has levels of 2,16,84,255. It's only audible at 16 if you hold it close to your ear, but at 84 you can hear it in normal use held out at arm's length.
Tom, the FETs work reliably all the way down to a PWM level of 1, they're not like the 7135s that only start working at 4 or 5.
Yes, understood with the FET's you can go full scale down to 1 PWM - I've been using that feature, but with 7135's, the min PWM value is higher than the standard value of 5 I've been using (4 works flaky). I'm also used to specific PWM values based on phase corrected PWM's, and I thought the output levels scale differently with fast PWM's. All a matter of experimenting I suppose.
I received some of the LFPAK56 FETs from mouser and put one on the test board (standard Qlite firmware with star 4 soldered). After cutting some traces to isolate the drain tab it wasnât at all difficult to solder. A cheap protected 14500 delivered ~35mA moon and 3.5A high with no pwm noise. Any cell that could deliver more current had unstable modes so I added back in just the gate resistor(no pull down) and this resulted in stable modes. An efest 14650 delivered ~75mA moon and 5.5A high before the led started smoking(obviously I need to upgrade to a copper star for testing high currents) also with no pwm noise in any modes. Both cells were 4.05-4.08V rested. The modes still seem well spaced though it would be nice to have the moon shifted back down to under 10mA. I donât know if the instability is a firmware issue or not. Someone would have to try the same board with stock and custom firmware to find out but the resistor does seem to alleviate it. The chip easily fits on the board without covering either the ground ring or the wide central pwm trace. Pics of this mod are in the phone and will be posted later tonight.
