QUOTE:āThe reason that the stock lens is so thick is that it can sit close to the led and catch a lot of the light, and still able to focus the led . You used a thinner lens that neccessarily is further from the led, so it catches much less of the light. That does not affect the brightness of the spot (that brightness is almost entirely dependent on the lens diamer, altering the focal length does not affect throw) , but it does make the spot smaller. It all depends on what the goal is, with this lens you end up with a very neat led-die projection and equally good throw, but also with a tiny hotspot.
MY CURIOSITYā¦
I keep HEARING that, basically put, āfocal length does nothing, diameter is everythingā
why then, operating on this logicā¦ does not everyone simply use WIDE lenses, and have extremely short focal lengthsā¦ why, you should det 5mm FL lens, set it real close to the emitterā¦ and be done.
after all, focal length does nothing.
iām not being mean, iām only being facetious, and using an exaggerated example to demonstrate my point.
maybe my experiences with IR emitters (oslon 4715S) is a radically different sort of light than the visible you guys all use, and it reacts radically different?
since IR is largely invisible, AND we dont have meters to measure stuff and post numbersā¦ a certain one or two camera sensors are what we useā¦ and every one of us, either buys or builds an IR light, mostly lensed throwers.
while the human eye can be āfooledāā¦ we are watching a SCREEN the camera sensor is feeding toā¦ our main figure of merit, in lieu of meters and readings? How far away can you SEE the scene? how far away can you SEE the stuffed animal on the screen?
low focal lengths just dont āthrowā enough that we can SEE anything on the screen, at distanceā¦ I got my best distance with increased focal length.
i think I realize what you guys MEAN when you all say āhigher focal length is not BRIGHTER !!! its the same BRIGHTNESS!!! only beam shape has been changed!!!ā
butā¦ how FAR away can i show of a picture of that stuffed bunny rabbit on my night vision screen?
it may not BE brighter, in reality or mathematically? Butā¦ the higher focal length sure shows up on the SCREEN being brighterā¦
(and FL being EQUAL, yes, wider diameter is definitely an improvement)
maybe i dont understand exactly what is meant by āthrowā being (or not being) āincreasedāā¦ to ME and MY application? nothing else matters, except whether i can watch a coyote or a wild pig, at 300m or 400mā¦ and 400m is better. To me, thats more āthrowā.
i kinda skip over the kilo-candela and mega-lux meter numbers, and just look for the ābeamshotsā, lolā¦
I mean, i KNOW what is MEANT when you guys say āit has not increased in brightness!! the longer focal length only altered beamshape!! its actually less brighter, cause its further away from the emitter!! only a wider lens can increase brightness!!!ā
but, knowing that, and i understand itā¦ but, when i look at my SCREEN, and the image got ābrighterāā¦ and can now see the trees behind the stuffed animalā¦ not just a dim outline of th animal?
Thank you
yes its interesting but donāt forget from stock is around 20K
I am going further playing around with what i have yesterday I hit around 800 K lux. my aim is to go over 1 million lux but for that I have to wait. for my new setup i think to make another thread because i think its not fair to call the new flash light just a UF-20
some photos
distance in sec photo around 170 m
you are right and wrong this time sry. I get more lux more than 50% and you can be sure about that. how it is possible? simply by the gain i made on diameter alone. it may look strange but the only thing that matters in throw is diameter of the reflector or lens in my case, and of course the brightness of the source in my case the xpe led. so believe me on this, that having two different lenses with the same diameter but different focal length (so in other terms one thinner and the other thicker) will not differ at all on throw. so thicker or thinner its not important in throw. so how did I improve in result you may ask? I gain in used diameter of the lens. the original lens is using only 33 mm in diameter despite being a bigger lens in reality. I design my new lens system with care taking attention that wasted space to be as small as possible. the real diameter of my lens is ~40 the effective one used in throw ~38~39. from 33 to 38 may not sound much but pay attention, what count is the real area of the lens A = Pi*r^2 =3.14*r *r so in the original lens we have an A = 854.87mm^2 in my new design A=1163.57 mm^2 conclusion:
if we look carefully to the numbers what we see? a small difference in diameter i just ~0.14(14) gave us back a difference 0.306(31) (almost double in this case) in area(and of course because of the r*r factor we donāt have a linear correlation here) !!!
in practice i should see 0.3 or 30% gain in lux (so in throw) what i see are around 0.4(40) ~0.5(50) this because the original lens i got its not so good and have some loses. still a good example when theory meet practice i must say
to not make it more complicated, i do not count here the factor that I am using both lenses in the same time but this do not interfere absolutely in throw. than why I am using those both? because I gain in total lumen that way, but this is another discussion hahahaā¦. (so in my case that spot its not that smaller )
so yes you are right in throw only diameter count and the thickness do not make an difference indeed, but in my case you are wrong because relatively with the same diameter of the flashlight head, i gain around 50% throw simply by engineering little better and making it little more expensive
Part of the problem is, itās not a linear relationship. You need four times the light to get twice the beam distance. Which is part of the reason why, what seem like big gains in candela, arenāt percieved as brighter by the human eye.
We do have tools that can measure IR intensity, they are very expensive but they do exist. IR light is measured in different units than visible light. These guys have āem http://www.intl-lighttech.com and http://www.grlabs.com/ will build you one too for about $600-800. The light meter is the only quantitative way to measure output of a given light. What you are talking about is percieved brightness. I believe there is a member on NVUKforum that has one. before I called it quits I was working with GRlabs to build me a meter.
Lux and Lumens are photopic units weighted based on the response curve of the human eye. The human eye is not sensitive to infrared, therefore you cannot define a lumen for infrared wavelengths.
However, you can define infrared incident energy in radiometric terms such as power per area, e.g. W/m^2. There are instruments that can measure incident infrared energy as well, but you have to be careful in defining the wavelength band youāre interested in, and the expected energy levels.
There are huge differences that factor into perceived brightness. Some of them are but not limited to, in your application, is LCD screen, camera, scope, IR lightsource, human eyesight.
human eyesight alone has remarkable differences from person to person. Namely pupil size as we age. As we age our pupils dialate less and less. So, the exit pupil on your scope you use has a huge influence on light transmittance to the eye.
As I am sure you know, the scope you choose makes a big difference. There is a big difference in quality glass and quality coatings from scope to scope.
When you add lenses to a system you lose light transmittance. Bottom line, add lenses lose efficiency. To see a good example of this just watch Rolandās videos comparing scoped vs scopeless digital NV tests. The only difference is the number of lenses the camera has to ālookā through.
Part of what makes the T20 so good as a hunting light is the beam angle. The beam angle of the T20 with an XPE/XPE2/osram 4715s is such that it closely matches the field of view of most scopes. Thus eliminating the āblackā ring you see when using a large long focal length lens. I donāt know if you have looked through a scope with an illuminator with a 66mm lens or larger but the beam angle is so small that the die image projected is smaller than the field of view of the scope creating a black ring in the scope. If you have ever hunted with a light like this you will find it very difficult to reacquire your target if you lose it in the āBlackā ring. And you also have to āaimā the beam to center it in the field of view. Which only works at a specific distance. Lets say you have the light with 66mm lens mounted above the scope and have the beam centered in your field of view at 300 yds, and a pig or coyote walks out at 200 yds, wonāt be able to see it! Which is one of the reasons I never marketed the 66mm or larger builds. That said the throw of the larger lenses is enough that if the hunter is hunting fairly still targets, the larger lens systems have a huge advantage.
One of the reasonās you are seeing better results with short focal length lenses is the center thickness of the glass. Thin glass transmits more light than thick glass.
I had a hunter in OHIO, using one of Rolandsā scopeless systems and my T20 ID and kill a coyote at 420 yds! Thatās hard to do in daylight! And I have killed coyotes at 300 yds using a T20 with RED emitter. Keep in mind that my red T20ās put out over 24,000Cd. And my red T66ās are approaching 80Kcd.
A large lens has the ability to gather and focus more light into a tighter spot than a smaller lens, increasing throw.
example: XPE2//sinkpad/1.4Aā¦ā¦32mm lens(T20) 24KCd
same set-upā¦ā¦ā¦ā¦ā¦.66mm lens(T13w/66mm) 75Kcd
The IR light behaves about the same whether behind a reflector or lens as the visible LEDās. The 4715s and the xpe2 are about the same die size, so the projected image is about the same size. I have built many aspheric and reflector type lights both IR and visible RED and GREEN emitters.
What I would really like to see is a IR or color emitter with the die size of an sst-90 or XM-l then we could use larger lenses with better results.
I really like your initial picās, for someone whoās never handled a UF-T20 before and thinking about building one thatās very helpful to see all the parts like that. I wish there was more reviews of different lights with picās of them broken down to their individual components. I know that would have kept me from being disappointed at least a few times.
heyā¦ that comment about āmy buddyā¦ coyoteā¦ 420 yardsāā¦ that jogged my memory banks! That was probably YOU that posted that on the night vision forum.
its meā¦ SEDstarā¦ I use the same screen name anywhere i go.
(Iām the guy on the night vision site that made the first āfutonā build and named it, lol)
counter point: diameter cant be āeverythingāā¦ on that logic, no lensed IR illuminator using less than 40mm diameter lens should be able to ākeep upā with larger diameter lens illumnatorsā¦ i have pictures of illumination 100, 150 metersā¦ with three-quarter inch diameter lenses!!
would you really expect to see ANYTHING at 100m to 150m with a 3/4ā lens on your oslon? (less than one inch in diameterā¦)
my ābigā illuminator build, has under 40mm clear diameter on the main objective lensā¦
i keep wondering what improvement will be made with my āsystemā when i try the same setup out with 66 or 78mm diameter main objective lens on my illuminator, instead of the sub-40mm diameter lens i use for a main objective nowā¦ i dont DOUBT the theory, I have been sort of āhandicappingā my illuminator build style with comparatively small diameter lenses.
I have illuminated well at 400m, with a scoped setupā¦ my scopeless goes up to twice as far.
its not like my scoped setup is using anything wonderful, its a hopelessly ordinary gun scopeā¦ its not like i am not using the same oslon emitter everyone else isā¦ same cam as everyone else too, ej230 is the only one i gotā¦ i use the one J230 cam in both my scoped and my scopeless buildsā¦
the only difference that could account for my distances i am getting? that i can determine? the only difference would beā¦ how i set my lenses up.
i mean, i guess its possible i got some super duper oslon emitter no one else got? but, i doubt itā¦
Yeah ,hey sedders , I donāt post much anymore or build as many lights. My new job is very demanding and stressful , leaves very little time or energy for lights. I am still working with Roland on a few projects.
Bigger is definitely better when we talk about lenses/reflectors and throw, the trade off is laser-like pencil beam.
I think another area that should be explored is AR coatings. I think substantial gains can be made with aspheric light builds. Having lenses coated to perform well with the given wavelength emitter being used 625nm(red), 850nm, 940nm is crazy expensive.
I just got an AR coated lens to try in a dereelight night master build that has a red Cree xpe2. I will post the results when done. I am not very optimistic , however, I have purchased dozens of lenses in the last couple years and very few work out the way intended.
I definitely need to get a meter to measure the gains/losses with IR light.
Strictly the brightness (at small angles) will scale with average intensity*lens coverage angle^2*focal length^2. In terms of lens diameter, the problem is that intensity is not uniform across the lens as it is a function of the emitted angle. Even assuming that the intensity was uniform per angle (which it is not), the relationship of the lens radius to the coverage angle from centre is not 1:1, but tan(angle). In other words itās always less than 1:1, except at tiny angles.
The brightness will scale (at most) with arctan(radius)^2, so itās difficult to know the change with lens radius, but unlike focal length it is not squared. The brightness will always be slightly reduced in some way when using a lens with the same diameter and shorter focal length. In reality you also have to take into account the non-uniform Lambertian intensity which peaks at the centre. There is some balance to be found in what focal length produces useful throw.
Thanks islisis, I had not thought yet of the effect of reduced intensity of the light at an angle, and the other effects, that made me think it all over again (which is a nice thing :-) ). What also may reduce the brightness at shorter focal length is increased reflection on the underside of the lens because the angles are increased.
np, itās good to think of these problems in context. Itās not hard to understand but I like thinking of how to explain. I have edited the postās language far too many times already cos I hate causing confusion
thanks all for the inputs, all appreciated. unfortunately do not have much time to respond all one by one but just to quick read. will find some time, hope sooner than later.
the review is a review in progress so I am trying to complete and polish as much as I can with photos schematics and measurements. still wating for parts.
second mod is almost finished, will open a new thread and put the link here as soon as I can.
I am open to all other mods so if you have something interesting please share here, photos and measurements will be more than wellcome. comparisons are allways a good thing and helpful.
finally i have some new shiny little parts with me now have started work, some pics are on the way some numbers too, still some work to do too to finish like I hope.
sedstar as easy as is seems in first sight as hard can become some times to think about how light bend I suggest(if I may) that you experiment in visible spectrum of light. it will be easier for you than, to see,measure and come in conclusions about your experiments and projects. than after that i believe it will be a safe bet that changing the source to infra will not alter the results.
As kevind43 said brightens is little bit tricky when it come to perception by the human eye, because eye can adapt in very wide range in different situations, but experimenting and measuring in visible spectrum is more easy nevertheless. plus light meters are very easy to use and to get.
wish you luck in your projects!
my second lens is coated. its an quality lens I got form a dead projectorā¦.
I think its good that its coated and maybe improve little bit still i donāt believe it make a huge difference at least in my case. maybe when the lens sits very close to the source can make more difference because theoretically should reflect back less light, but i havenāt tried that yet.
well i would love to go in details here, because i think its an interesting arguments, buts its frustrating for me to express myself well enough(and explaining this will need to be long enough) because I donāt know very well English. however as soon as I read your comment one experiment crossed in my mind soā¦
I just make this quick enough
, do not have a caliber right now but its around 22mm in diameter(inner circle).
I put it in front of my modified UFT20 and measured. the result are:
UFT20 *`3.15 m ~670 lux (dimater of the lens around ~38mm)
UFT20 modified lens +22 mm ring `3.15 m ~237 lux*
UFT20 original lens +22 mm ring @3.15 m ~235 lux
anyone is free to duplicate and or interpret those results and what this means
and some new photos:
, still measuring but with dome i get ~105Kcd at start(that beam is around 800 Kcd!!!) but it goes quick down after thatā¦ hm it seems i have a huge amount of work with managing of heat . why it have to be so hard still work is going on
what i wanted to stress here is that i really like effect of the ray of light with dome. its hard to explain with words but its a lovely bluish tint and for some reasons it looks strong. when dedome the lux go up (the light is there the meter see it) but the ray of light lose some of this bluish aura. I think the particles in the air reflect more the blue spectrumā¦
thermal management done I could follow soldering MBCP on pill way and probably would have one of the best heat management possible but I wanted that despite having a good heat management also have the flexibility to easy experiment later. also i want to have the led centered as much as possible so chose the hard way. after reading god know how much on heat dispersion, cree led construction and so on, finally is over.
working with pill take me the biggest amount of time:
its sanded with 1200 flint-paper and it come almost mirror finish. small touches are here and there too, do not want to go too much in details for now
the end result is this (for now bc i have to add something later ):
what maters is that the led hardly surpass 50 grade Celsius in max and output is very very stable, with slight reduction from cold start(till both pill and mas of body is saturated ā¦ ).
some numbers:
with dome on(want to finish all work and than go dedome! )
in max 2.4 A (but i suspect its a little more because Vf was 3.6 ) it throw 104K cd
in max with original lens (without my optical mod) ~68 Kcd
i make some work with light collar but even that only with collar i manage to get 40 % more light punting it at work with lenses was a total failure. in the pics above one is with collar. i find a way to make it work somehow but the flashlight dimensions grow to much, lumens go down way too much and the spot was very small. working with collar need some serious equipment.
well next step is dedome, some cosmetic here and there and its done
some beam shots(all my photos are from my phone) one is from actual third mod that with dome is around 700K cd and is looking in good shape to go over 1M cd soon
the other is my moded UF-T20 100K cd but with dome on:
Sorry, originally I was thinking of the problem in terms of a diameter:focal length ratio argument to try and keep the discussion simple and in the end botched the general expression I showed
brightness is proportional to (1-cos(angle))*focal length^2, which I simplified as (angle*focal length)^2 without thinkingā¦ only also leaving out the ^2 which iāll edit (again :/) now
i took the partial differential with respect to focal length and plotted them, and they are both positive with a maximum gain followed by drop to zero at infinityā¦ so for a constant diameter there is always some slight gain in brightness with longer focal length
anyway the bigger and more complicated factor will of course be the non-uniform Lambertian intensity
@islisis interesting, I didnāt thought before how to prove theoretically/mathematically but it sound like you are in the right track at first look. unfortunately i forgot to make partial differentials, because are more that 15 years that donāt exercise on math. If i find some time will open my books and will try to do it myself just for fun if i can. pretty sure some math software will make it very easy.
In practice there is like 0 difference or like ~2% from what I measure, but that can also be part off human mistakes or tolerances in light meter or other variables.
pretty much my sec mod on UF-T20 is done.
from around ~100K cd with dome on de-domed now is ~180K cd
I would love to manage to put some kind of small light collector inside but with tools I have is almost mission impossible. still I am looking around for some random object that can be suitable for the task just some small gain like ~30% will be perfect
about dedoming I almost never manage to double lux, but max ~80% is this normal?
waiting night for some beam shots.
meantime i make yesterday some photos:
ok I give up for today trying to learn mouse over thing (no more free time at my disposal for today)
i tried to rely on intuition arguments and didnāt research the problem at all but i came across a random thread with a link to this explanation: āas the focal length is reduced, the beam divergence increases at a greater rate than the total beam powerā. that might be easier to understandā¦
I got my T20, in spite of the pictures, partly because it was well liked on another thread here and partly because I thought I might be able to use the lens in my Yezl T-9. The build quality really is good, perhaps the only better build I have is a C8. I like the brass pill, trapezoidal anodized threads, etc. But it is pug ugly and feels just as bad in the hand, so I donāt want to use it as a regular white light.
Instead, I took its lens and put it into the Yezl, put the DX lens that didnāt quite fit in the Yezl in the T20 and put my deep red led into the T20. The pill cutouts for driver and star were nearly right and it is functionally excellent. It works well in that role.
