Thank you for your review, I am considering warsun for my next purchase, are they HAIII finish? Can the driver be modded for more power? Is the button waterproof?
Thanks!
Thanks!
I'm trying to find out now how to get to the driver without damaging it. I will update the review one I figure it out I was told by another member that the driver can me modded with a resistor for more power. The manufacturer said it is HAIII and I would have to agree, from the feel of the flashlight.
The MX-800 seems to have a slight shine to its HAIII though compared to the rest though.
I just tested the MX-800 in a bucket of water for about 5 minutes and see no leaks whatsoever. With all the double seals on every section though, I don't see how its even possible.
YES! the driver can be easily mod with simple resistor mod to give out extra lumens and they have excellent heatsink too
YES! the black LED cover is on the high side, but they do gives out a nice round hotspot without ugly corona as in regular C8, however be very careful when upgrading this light with high Amp driver, it will burn that black LED covered and create smoke that can ruin the reflector finish ( don’t ask how I know )
but if you just want a simple resistor mod to somewhere around comfortable zone of XM-L2 at around 3.5A… this is definitely an awesome light, if you don’t care about the size of course as it is longer than most C8.
lucky for me I found another reflector donor from another light which is longer than the original, now it even gives out more intense hotspot
I love that M900X lighted switch button.
btw… to take out the driver all you have to do is disconnect the solders on the LED star first and then just yank the driver out by pulling the spring
Thanks dayLighter, that was easy, just unsolder the LED and out comes the driver! Here are some pics of the driver. Now what do I need to do?
Driver can be stripped, drop in a Nanjg with e-switch support, maybe FET based, and you got an awesome light! I did a CT9S that way. But if you have a Warsun with the power switch red indicator for low voltage, you will lose that capability with the stndard e-switch drivers.
Hhmm. Looks like they upgraded the CT9S to CT9T. Think WallBuys was selling the CT9S...
Anywhere else these lights can be bought retail?
Hey TomE, thanks for some help. I think that might be above my skill level, not sure. I have a soldering station, but no hot air rework station. I do have a heat gun though! I have also never stripped a board naked before. But I did get some 70N02 in the other day though!
Is there anything I can do to the stock driver instead, before going the full driver rework method you suggest? I would prefer that method, if possible! Is that a PLCC2 LED on the stock board, and can I swap it to blue if I wanted?
As for buying retail, I have not seen them anywhere. Hopefully sellers will start carrying them, since they are all built very solid. They also all feel very good in my hand! This is my first time getting a 26650 light, and in my hand they feel great. I always thought 26650 flashlights would be to big for my liking, guess I was wrong. Getting 4 of them is way too much for me. Might just do a random giveaway on 1 or 2 of them, but I need to see which one's I like the most first.
edit Add: The driver board I posted came from the MX-900, wondering if thats why the driver you have posted looks a little different.
Hey blfdemigod. Nice review. Those 2 R160 resistors are probably the voltage sense resistor bank that is used to regulate current. Combined they equal .08 ohms resistance. You can stack more resistors on top of them or use copper wire if you are adventurous. That should increase current to your emitter.
Thanks Ima4Wheeler. So just remove them and do a straight copper bridge? I need to push this baby to max! 1700 lumens here we come!
+1 - follow Daylighter's or ImA4Wheelr's advice on the resistor mod method. May have to swap out that LED black centering piece though, as Daylighter mentioned. Anything over 3A though, I would go for a copper (direct thermal path) mounted LED though. RMM at Mtn has good LED's pre-mounted on Noctigons. Not sure of details on the Warsun's though for the MCPCB swap - fit, height, etc.
Ok, I'll give that a shot. Got 10 LEDs and some insulators on the way from RMM.
You can just put the copper wire on top of the resistors. No reason to remove them unless you want them for something else.
Resistor bridging is a bit risky... I'd go conservative on adding resistor(s). With keeping the driver, of course, you would keep compatibility for more than one cell, and all the other driver features. My idea of sandwich'ing a Nanjg driver would restrict it to only one cell.
I got a SupBeam L6 (review: https://budgetlightforum.com/t/-/26046), and do like feel of this size 26650 lights in the hand, plus the advantage of using higher capacity cells. The Warsun's will cost more, but sounds like they are a little better quality too.
Oh, I think I got lost in all the models. If the driver is for a multi series cell light, you may want to try just halving the resistance first. You could add a common R082 resistor. Thanks for catching that Tom.
Have you tried the light with multiple cells to see how much brighter it is that way first?
@TomE What kind/type of resistors should I add to it?, I have alot of 1R0, but I think that might be it.
I see that L6, and I will try to take apart one of the 26650 models when I get time, which one for now?
@ImA4Wheeler Yes, the MX-900 is a multi-cell light, maybe thats why my driver looks different than the CT9S driver TomE posted.
I did try it with both 1 and 2 cells, and its noticeably brighter with 2 cells, but still not where it needs to be. I don't have an R082 resistor, what other resistors could I use? And I guess I just solder it on top of the existing resistor's?
hmmm, do you have an old electronics that you can harvest resistors from?
The "R" is a decimal when shown. So each of your R160's are .16 ohm resistors. Parallel resistors reduce resistance. So 2 R160's create .08 ohms resistance. If you added an R082 (.082 ohms resistance) on top of your existing resistors, you would get a combined resistance of .04 ohms (rounded). That would theoretically double your current. I say theoretically because other limiting factors may get in the way.
I use this to calc resistors in parallel: http://www.1728.org/resistrs.htm
What I do is measure the tailcap amps, say for example you get 3A with the two stock R160's.
Using Ohm's Law (V=I*R), solve for V: 0.08 * 3 = 0.24v
So, add one more 0.160 ohm resistor, you get: 0.0533 ohms, solve for I:
V = I * R, 0.24 = I * 0.0533, I = 0.24/0.0533 = 4.5A
So if you desire to get 4.5A, you would need to add another R160 or equivalent (50% bump). I say equivalent, because you could add two R320's which is the same as one R160. To go more mildy, you would add a higher value resistor instead:
So, adding a 0.200 ohm resistor (R200), you get: 0.057143 ohms, solve for I:
V = I * R, 0.24 = I * 0.057143, I = 0.24/ 0.057143 = 4.2A
So, adding a R200 resistor will result in a 40% increase in amps. Pretty easy? Don't you just love when the math works? I've done this stuff before and it comes out exactly with the bump I expected....
Problem is, of course, having the Rnnn resistors (current sense) laying around. I ordered a few different sub 1 ohm resistors a while back in the 1206 size from DigiKey. This is one example: http://www.digikey.com/product-detail/en/RL1632R-R160-F/RL16R.16FCT-ND/714519
I received an MX900 yesterday. The newest warsun model is called MX900 find6. I love the feel and look of the light. Much better feel versus convoy L4. The side button has a nice machined chrome look to it. The output is lacking with a single 18650. It looks as if it was designed for max output with 3x18650. I only got 1.15amp at the tail with a typical samsung or trustfire 18650. I got 1.5 amp at the tail with a single panasonic ncr18650pf. maybe the driver spring has high resistance? I got 1.8 amp with 2x18650. I didn’t have the third link to see what it does with 3x18650. This light is definitely underdriven. It needs a good boost for the single 18650 format because i won’t be running it in the 2x18650 or 3x18650. The black led isolator definitely blocks some light. I got a little better output without the ring. I will be in touch with the manufacture and hopefully they can make a few changes to this light.
The back button and side button both control or cycle through all the modes. The neat part about the side switch is that when the light is on. You can hold down the side switch for 3 seconds and the light goes off. Then it is in standby mode. You can instantly turn the side switch back on and take over control of the light with the side switch only. Kind of hard to explain. I will definitely see if Warsun can eliminate the sos and make the strobe hidden with a fast double click of the side switch.
This is a solid light and was designed with heat sinking in mind. Appears to have a good thermal path to the body. The green water seal that wraps around the lense is a very unique design.
@ImA4Wheeler and TomE: Ok guys, I just looked around and I have R332, R499, 5L0F, 221, 101, 5R1, 1R0... on all the junk pcbs I have stashed. Can I use any of these? If not, then maybe its time I order from digikey a resistor bundle pack.
@phsinvent I agree this light feels amazing in my hand, and quality is very good. On my Build Quality Index I give it a 98% up there with my Solarforce! What would you rate it from 0-100%?
Anyways, I already asked the manufacturer to make the following changes, we'll see what he says:
If i had to be picky. I would give it a 80-90%. I can see a few machine marks on the end bezel silver piece. And there are a few spots on the tail cap that have sharp edges that needed deburred.
1. I doubt they will want to do a stainless bezel to keep the cost down. But a stainless bezel would be nice.
2. Remove SOS and hide the strobe. It’s just too much nonsense to cycle through. Also, I don’t think I could detect any PWM like I can with solarstorm lights.
3. Boost output of the MX900 Find6 in single 18650 format. 3 amps or higher would be nice. I wonder if the CT9T has better output and a different driver. Did you try the CT9T in single 18650 format? I don’t think the CT9T driver would have the big torroid on the driver.
4. Definitely a new low profile led isolator. The current black one blocks a lot of light.
5. I agree 100%!!! A blue led light for on would be superb. And keep the red low light indicator.
6. Possibly better springs for resistance purposes.
7. Flat anodizing with less shine or gloss.
8. Maybe better XM-L2 tint, mine came as cool white. A little more neutral wouldn’t hurt.
Wow, I must have got a lot nicer batch than you. My MX-900 is almost, if not flawless, except for the glossy-ish anodizing.
The CT9T and MX-900 on single 18650 are comparable, but MX-900 seems slightly brighter. On 2x18650 in the MX-900 it's noticeably brighter than the CT9T.
The CT9T I have has a very flat finish. Mx-900 definitely glossier.
I also forgot to email him about the modes. After thinking about it, the only true culprit is the driver to me, and the black insulator piece.
