So charge them to 4.0, and dont let discharge to lower then 3.8? isn’t this to little of a difference, and will make me recharge every few days? at what capacity (generally) does high quality cells go to 3.8V?
Please notice, I only do this to expensive cells I want to keep for a long time. I am sure its not very practical to do for very high powered lights.
3.8v to 4.0v is aprox. 40% of battery capacity. For example on my AW 18650 Protected 3400 mAh, 40% of 3400 is 1400mAh. That’s a little more than 4 hours on low on my light. So its not very inconvenient for charge every 4-5 days or so.
The Panasonic 18650 A,B & CH and Sanyo 18650 2600 really rock for longevity & capacity.
That’s why a lot of the top brands have these cells inside.
I started this hobby about two years ago so i’m still a newb but i can’t really notice any decline in my very first panasonic cells, an 18650 A and an 18650 CH which may have been slightly abused due to my ignorance at the time.
The cheaper brands really are not worth buying as far as i am concerned - i must have thrown out five “DubiousFire” cells to every panasonic that i still have.
I have Sanyo 2600’s from laptop pulls that must be five years old at least and are still going strong.
When you use your flashlights frequently you really get to know them and can tell good cells not so much from visual output but from runtime and especially from how hot the light gets in high mode.
I even use this as an indicator of when to recharge batteries, there’s a noticable decline in the heat of the light.
I have ruined a few cells and would say the number 1 causes of destroying a Li-Ion is running it to below about 3v, shorting them out or cutting them in half with a hacksaw.
So best to treat them with respect in those regards.
As to prolonging the life of cells, i keep all my cells near enough fully charged at all times and cycle them at least once a month.
I really don’t see the point in storing them at a third or half capacity or whatever because the whole point of batteries is to use them for convenience or when you need them most, probably when there’s no power for your charger…
Sure it may decrease the overall life of the cells but with so many good batteries coming out and the technology improving constantly you’ll want to be buying and replacing cells every 2, 3 or 4 years anyway.
That’s just my thoughts.
I always thought it’s best to cut them in half using a blowtorch :bigsmile:
I was out of gas at the time
Thanks alot guys, i’m realtivley new to flashlights/chargers/batteries, i got my Panas green protected 3400 mah, (NCR18650B) having use them for around 1 year, so i always wanted to know what is the best way to prolong life, while having the max output - and optimal charge.
i now know the “best” way of doing it.
Charge to around 4-4.10V and don’t discharge lower then lets say 3.7 - 3.8V i think this is the best balance generally, i also keep my TK 75 (with batteries) in room temp not over 25-30c at most. Thanks one more time.
Edit, my incmong Efest LUC V4 (updated version) will be great in order to know when to get them of the charger, ~ 4.10V without having to check the volts, it has voltmeter on the LED screen, making life so much simple!
Check your Efest LUC V4 charge termination with a multimeter too though if that light runs in series. I notice some bays tend to terminate lower than others, 4.12-4.17, very dissappointing since I bought it to charge all evenly to 4.2V when I needed 4 at a time, as an alternative to the TR-008, which only has 3 bays and always charges all bays to 4.14V. Its kind of nice in a way, a charger imposed battery life increaser.
I also have had some Panasonic 3400mAh batteries that I have had for over a year, with heavier use than most I have heard on here, I tend to have 1+ hr/night average, sometimes up to 3hrs of usage of a light/night walking dogs. No difference in capacity that I notice yet. I do have more lights and batteries that I cycle through, so at least a couple hrs/wk usage is what they get. The only cells I’ve had a problem with (other than crappy Ultrafire in the very beginning) is a red Sony I got from someone else, they got very hot on charging, so I tossed them.
Thanks for the tips, but can’t you use the leds on the display to see the volts? or its in-accurate? i plan to remove the batteries from the charger @4.10 ±
What are the downsides of different volts (after termination)? not sure if TK 75 batteries are in parallel or serial tbh.
Also good to here about the panas doing great.
P.S. Do you have the updated version of the LUC V4?
You could also hook up the volt meter Kodachrome40 linked to a TP4056 charger board to make one of these and have a handy compact charger/volt meter in one.
You might find this information from HKJ useful too
For batteries you using,
Charge them maximum to 4.1V (90% SOC) and keep cool and recharge when resting voltage 3.8V or higher —> maximum life expectancy
charge them 4.2V and use them till empty and keep hot —> lowest life
Cycle life:
if battery has 300 cycles before capacity reduce to 70% its 100% full charge cycles.
that battery may have around 1000 cycles if you discharge 50%
I’m new to 18650 Li-ions and was wondering how it can have 0% capacity at 3.3 and 3.2. If it has no capacity left at 3.3 how can you still run the cell down to
3.2 and still have light?
BTW that’s a nice chart on capacity TY. I’m keeping a copy for reference.
I just (dis)charge my cells to 3.8v checked with a DMM and then leave them in their battery boxes.
Mine stay at 3.8v for 6 months+. Not sure how much longer because that’s the longest I’ve ever kept them in storage.
I’m no expert but as far as i understand it, about 3v is the lowest a li-ion cell is happy to go to, any lower and damage occurs so the voltage range for these cells is 2.8-3v to 4.2v
3v= fully depleted and 4.2v= fully charged. 3.7v is the nominal, average or working voltage of the cell.
This was confusing to me at first too.
They will still be able to output some power below 3v but like i said, it’s really bad for their chemistry.
Check out my signature links for more useful charts
Great TY CRX I think I understand. Also two more good links to bookmark.
There is a large difference in voltage, depending on when you measure it, when loaded it is significantly lower.
In some cases that difference can be more than a 0.5 volt.
In the chart below I am switching a 3A load on/off. The red line shows the voltage and it jumps up and down with load/no load:
How low a LiIon cell can go depends on the chemistry and if you measure loaded or unloaded voltage. A modern Panasonic cell can usual go down to 2.5 volt when loaded, but will recover to 3.3 volt when the load is removed.
Thanks alot guys! its alot clearer now
I think that they should still hold. I have had a good experience with this. I would say a small loss is expected after a couple of years. I love the chart that was placed above. Thanks everyone
I will toss an 18650 for ANY reason or for NO reason. Sometimes I just get tired of the wrapper colors.
When I get down to ~1 or 2 spares per flashlight, I’ll go scrounge another laptop pack & just dare any of them to so-much as annoy me.
But I charge most or all of mine more than 50 times per YEAR!! The best three or four get charged a couple-three times a week or more.
The newer ones are better than the older ones, so why keep them?
Dim
I still have some of my first 18650 batteries ...
I find they either work ok or they lose their capacity to hold a charge ( cheaper nastier batteries ) for any length of time .
Twice a year I go through my rather large 18650 collection to recharge them all , ( Takes about 3 days ) and its this time I check them for voltage ..
The ones that have lost there charge in 6 months just sitting doing nothing get discarded , but the better quality 18650 hardly lose any charge at all .
I have one panasonic that if left @ 4.2v will still be 4.2v 6 months later .
And other batteries that will be close to 3v after 6 months .. ( See the trend here )
Good batteries will hold a charge , cheap batteries will self discharge , and require more frequent charging ( maintenance )
Im also leaning more towards non protected batteries , as cheap protection circuits might put a slight drain on the battery ( I have noticed this )
Removing the protection circuit stops the battery from self discharging .
If I buy more batteries , they will not be protected .
As for degradation ( ageing ) , this is highly variable and depends very much on initial quality and how much the battery is used .
I store all my 18650 fully charged if they Are garbage in 5 years I don’t care because than we will have better and newer cells which I want anyway…
