just in case…
Update 20/06/2014
Finishing driver and my eyes together with it
Shrinking the mass of wires switches and AMC chips that I call driver in one small place
I really was afraid how will pas this. Lots of unclear thing is the process so I spend a lot of time thinking about how will do it. Once I make a general idea than I start work on it.
This is how it looks before I started this part of work:
In that state it served me well for testing and measurements. Again since it is a lot of work I will try to post the smallest number of photos that I believe can give you a right idea of the work. For those who are curious here is the link of all photos in driver section:
http://postimg.org/gallery/9idvvcto/
About measurements of Vf after I made them and studied one sentence come to my mind:
‘Huston we have a problem here’ lol
Here are the measurements:
I have an printed copy of Match tests that I usually use for deducting I in my led. I chose this way simply because measuring I from multimeter is very hard and inaccurate usually. Measuring V in other side it’s easy and usually very accurate even from cheap meters.
Problem in my readings is very high Vf compared to Vf of Match. In the start when I is low everything match pretty well but later one in high ampere levels to my eyes something is wrong. I can’t explain this right now and invite anyone with more knowledge than me on the subject, please come here and share some light. Maybe match used some PWM power supply and these affect readings? Maybe latest cree with higher bin act slightly differently? OR I am missing something and am just interpreting wrong this graph?
But let’s move on. Since I can’t say for sure what current my led is getting I am making some educated guess. I believe that from a single cell fully charged I am getting around 4.5 A, but again I can’t be 100% sure on this. Judging by Vf of Mtach I should have more but I don’t believe am getting more than this from a single cell…
Saying this lets move one with the build:
After I made some drawings in real scale (1:1) which helped me to clear ideas
I started work on this
Than I make solid the inner part
next step was ripping apart the old driver getting AMC I have solder before from there:
in the first version I use 10 AMC (380mA) in 4 groups in 1,2,3,4 configuration optimizing it now will use 15 AMC (380mA) again in 4 main groups but this time in 1,2,4,8 configuration. This will gave me 15 levels of output from 380mA to ~5.7A
For doing this I preserve 1, 2, 4 stacks and only added 5 AMC to the 3 group.
The next step was putting them in place. One of the biggest mistakes I made during this build is that in this moment I chose to experiment with the group with 4 AMC and not solder it in the pill but use epoxy just to see the differences with soldering procedure I chose for other groups
I ran on different problems later on during the work
The green wire is the temperature monitor I put there to monitor temperature during soldering process of AMC. I do not need nasty surprises like burned AMC or flickering after, during use. I have not much time for repairing later so better do it right. So soldering was a pain for deferent reasons. My eyes starting being tired so in this moment I decide I need to do something for them, after little thinking I come with this :
may sound like stupid but work good and the added light really help. I like it so much that now I am thinking on building something more seriously or just to buy one. However for now I finished the work with this and was very satisfied in the end lol
So let’s continue with building
I made some temperature measurement to see what I have done:
And the results where more than good, the most problematic single AMC during use in one full 18650(worst case scenario) after ~2 min in use rise only 0.2 grade C. the big stack with 8 AMC rise only 0.1C during use.
Next I played with different switches (I can’t stress how important is a good switch in the overall performance of the flashlight in my case) to get the one with the lowest resistance.
Opened and check different ones but too tired to go in detailed analyze now. What I chose was one that worked really well. It was not the best looking of the bunch but what differentiates it was how well it works.
update 23/06/2014
I think a lot how to make something very solid for holding all parts of the driver including DIP switch and general power switch too together with all AMC and wires. This is a key part that connect led and battery section. I have done led part and also batteries section, this was my last big hurdle making my project a reality and finalizing 3 month of hard work. Ok. I look what materials have around make an last evaluation and start the work.
And put the driver inside
it looks that with some work everything will fit inside
so I continue work for switches
it was not that easy:
it was a fight against the patience this:
and I am not going in details here how much tries I have made till I was satisfied with result in the end
When I all connected first thing I do before put batteries on and fire up I check all with multimetter. This was a wise decision; I have something very wrong somewhere causing a short circuit between plus and minus. In an unprotected 18650 or even worse three of them this could cause serious problems…
Can you imagine what mean connecting all together and now to not have idea what was wrong; I was devastated for a fraction of a sec, lucky me I find defect and what goes wrong and repair it for living, so I gathered forces and started to check. Problem was here:
During put all together one of cooper wires soldered in driver pill for cooling cut the positive wire that go to led. Well cooling is soldered in GND of AMC so was negative…
I was so happy I find it, it was little bit hard because it was not a permanent short, some time it make contact some time not depending on pressure. I take measurement that something similar not happen again in future.
Everything was smoothed there to not cut anything again
This photo shows the original driver on UF-T20 compared with my driver
I had another defect that causes some flickering AFTER some use of dip swich, lucky I find again where problem lie:
this photo explain it all:
i was not vigilant enough during projecting and this detail escape me back then, do you find where problem is???
in the end i fix this too and driver was more than ready to work:
