I believe the SF series comes with both flood and spot reflector. But its a flashlight form factor, light comes out the front.
The SG series only comes with a flood reflector (spot reflector is extra) but it is in Headlamp form-factor, where the light comes out the side. I also like the SG3's small size personally, as it takes 16340 batteries. This is all I know between the SF and SG series. Maybe others can chime in about more differences.
Sorry for the off-topic, but you know your Zebralight can also start in Low (several low available), if you do a ~0,6s press on the switch? It can even start on medium if you do a longer press (the light will switch on in low then go to medium)
My Zebralight H31fc is currently my favourite EDC…hope the Sparks will replace it!
Guys, Wallbuys will be having a sale on SF5 NW for $42.99 starting on April 30th. This is a good news for those interested in SF5 if this GB doesn’t happen.
chibim has been talking with WB as well to see if they can get their typical sale/GB for $43 for all 4 of these lights/headlamps so maybe if we dont meet the minimum required pieces we can just order from wallbuys individually.
Put me down for a NW SF5. I’ve been toying with the idea of getting a Zebralight SC52w, but this might do the trick instead (unless someone can point me to a great deal on the Zebralight).
But this effort is proceeding slowly and I wont wait forever, so I reserve the right to purchase something else in the meantime (if I do, I’ll report back here immediately).
Fun fact: I just bought a SG5 NW from HKE the other day. Hadn’t I done so I would be all over this group buy.
Good luck to you all, I hope this one works out for you.
Switch your light in low, then double click on the swicth to access the Low n°2. And if the low n°2 still doesn’t suit your needs, you can also program it by switching to low n°1 (by double click), then by 6 (or 7, don’t remember) double click, you should have access to 3 possibilities (double click after the 6 or 7 double click to switch between the different low).
If one of these suits you, than switch off the light (simple click) and it will be memorized. After that you’ll have the choice of the low n°1 plus the “low you programmed” by double clicking when in low. This applies to all modes I think, at least on latests Zebra.
Sorry again for the off-topic, if it’s not clear, or it you already knew all that
Any chance Stanley might lower the minimum units req’d? Wallbuy’s promo on the Spark lights ends on May 3rd. A lot of us would prefer to buy from HKequipment but I can see some of the people committed to this GB jumping ship on May 3rd.
