Here's an example program I put together for the 1822. It's a very simple flashlight with 3 brightnesses and a randomized strobe that changes modes on power cycle. This should help you get started with the 1822:
//v0 4/21/2014 by Everett //initial version //simple flashlight controller. mode change on power cycle
#include <htc.h>
#include <pic12f1822.h>#define _XTAL_FREQ 8000000
__CONFIG(FOSC_INTOSC & WDTE_SWDTEN & PWRTE_ON & MCLRE_ON & CP_OFF & CPD_OFF & BOREN_ON & CLKOUTEN_OFF & IESO_OFF & FCMEN_OFF);
__CONFIG(WRT_BOOT & PLLEN_OFF & STVREN_ON & BORV_LO & LVP_OFF);persistent unsigned char mode; //must be declared persistent for ram retention trick to work
enum mode{
max=0,
med=1,
low=2,
strobe=3,
#define max_mode 3
#define default_mode 0#define on_time 15 //milliseconds
unsigned int strobe_timer;
unsigned char strobe_position;
bit on_off;
persistent unsigned int key;void delayms(int milliseconds);
void configure(void);
unsigned char stun_rate_lookup(unsigned char input);void interrupt isr(void)
if(TMR1IF){
TMR1IF=0;
}if(TMR0IF){ //fires at 1kHz TMR0IF=0; if(strobe_timer){strobe_timer--;} //count down milliseconds }
void main(void)
configure(); //set up hardware peripheralsdelayms(15); //short delay to avoid power glitches incrementing mode if(key==12345){ //RAM retention trick to detect quick power cycles mode++; //go to next mode if(mode>max_mode){mode=0;} } else{ //long power loss. default to first mode mode=default_mode; key=12345; } switch(mode){ //initialize current mode default: case max: CCPR1L=255; break; case med: CCPR1L=25; break; case low: CCPR1L=1; break; case strobe: strobe_timer=0; on_off=0; CCPR1L=0; break; } GIE=1; //turn on interrupts while(1){ if(mode==strobe){ //no other modes need active tasks while running if(strobe_timer==0){ //timer ran out on_off=~on_off; //flip it if(on_off){ CCPR1L=255; strobe_timer=on_time; //set on time } else{ CCPR1L=0; strobe_position++; strobe_timer=stun_rate_lookup(strobe_position); //set off time } //set output } } }
static const char table[72]=28,30,33,31,12,24,28,33,29,23,19,33,33,23,14,26,9,18,15,29,15,10,19,31,9,27,33,10,15,26,16,28,30,24,14,23,10,24,30,10,23,31,25,33,9,15,19,17,19,18,32,23,33,17,31,13,31,18,20,8,24,33,17,21,20,14,9,20,26,16,22,16;
if(input>71){input-=71;}
return table[input];
}void delayms(int milliseconds)
while(milliseconds!=0){ __delay_ms(1); milliseconds–;}
}void configure(void)
INTCON=0b01100000;
PIR1=0;
PIR2=0;
T1CON=0b00110001;
T2CON=0b00000101;
PR2=255;
TMR2=0;LATA=0; TRISA=0b11111011; ANSELA=0b00000000; // WPUA=0b11111011; APFCON=0; OSCCON=0b01110011; //8MHz PIE1=0b00000000; PIE2=0; OPTION_REG=0b00000010; //8 prescale for 1ms interrupts
// FVRCON=0b11000001; //1.024v to adc
// ADCON0=0b00001101; //
// ADCON1=0b00010000; //1/8, left justify, vref from vddCCPR1L=0; CCP1CON=0b00001100;
__EEPROM_DATA(0,0,0,0,0,0,0,0);
__EEPROM_DATA(0, 0, 0, 0, 0, 0, 0, 0);
__EEPROM_DATA('1','8','2','2',' ','f','l','a');
__EEPROM_DATA('s','h','l','i','g','h','t',' ');
__EEPROM_DATA('b','y',' ','E','v','e','r','e');
__EEPROM_DATA('t','t',' ','e','v','e','r','e');
__EEPROM_DATA('t','t','.','b','r','a','d','f');
__EEPROM_DATA('o','r','d','@','g','m','a','i');
__EEPROM_DATA('l','.','c','o','m',' ',' ',' ');
