Fantastic shots RaceR86. It puts things into perspective. If I have asked this question before I apologise, what is the rough diameter of a single shocker reflector? Measured through the glass lens would be fine. I'm just curious how it compares to a C8 reflector.
[/quote]
Did you shake your head or something in order to make the blurry shots sharp MRsDNF? :D
A single BTU shocker reflector is roughly 42mm wide. So they are wider than a C8.
:beer:
Yupp, its great. Easy to fit in a pocket. And even with half empty cells its got full output, unlike all the other lights in this comparison.
I used to have a ZY-T13 and STL-V6 before. But I prefer to have two cells in series in a shorter more pocket friendly body.
Im not that into de-domed XM-L2s though. But that light have an emitter with very nice tint. I picked the best out of around 4 emitters, and the 3 others looked like crap in comparison. I was really lucky with it, so im not pushing it harder than 6,4A. But the driver, HX-1175B can do whatever I want to do in terms of output. I took it from the lustefire.
Great shots RaceR86. Thanks for setting them up. Looks like you have someone aiming them down from the top of a cliff. Those lumens must be just falling right of those flashlights.
Thanks. Yes my head shakes a lot. One, in amazement at what some members here can do and achieve, two, I cant say as it against forum rules and thirdly when I get home from work (l'll leave the last two to your own imagination).
awesome comparison shots… just wondering, what kind driver or mod is the one being used in 6.4A constant current for ZY-T08?
’cos I got 3 that begging to be mod
Im a bit higher than the ground below (about 3 meters). I just hand held the lights above the camera, somewhere between 0-30cm away from it.
MRsDNF, I was thinking about including your little 14500, but im only using a Protected Sanyo cell in it. I dont have any IMR14500 so I cant show off its full potential. At 2A+ its still a very good thrower considering the size. I used it on my keychain for several months in the winter. :)
Thanks Daylighter. HX-1175B, slightly trimmed.
:beer: Tom. Dont tell me you too are getting a shaky head. ;)
I prefer the grip, size and weight of the HD2010 over the ZYT08. But it needs a hot-rod cell in order to really shine. Ive built mine up with a souped up Qlite. Its a great overall light. When that is said. It does pretty well with something like a King Kong or Keeppower 4500mAh cell too.
In the ZY-T08 with cells in parallel there is no need for "hot-rod cells" since the load will mostly be less than 2,5-3A even in a "hot" light, so you can still use high capacity cells, and still get great peak output and fantastic runtime.
Or you can just get fantastic output from start to finish if the cells are in series and combined with a buck driver. Properly regulated light is just awesome! But then at the expensive of having a basic 5-mode driver and a slightly less safe and simple battery setup.
My twin cell HD2010 with copper throughout leaves the stock light for dead and is a usable camp light with a long run time on maximum if needed. I like it a lot. In this set up as well the MTG-2 operates ideally with a reasonable hot spot.
Super shots. Thanks for sharing, this one should be stickied because it’s really a valuable resource for people who are wondering which lights they should buy for modding.
