There really is alot to like about the HD2010 and ZYT08. Cheap as chips and can be made to perform very well.
I prefer the grip, size and weight of the HD2010 over the ZYT08. But it needs a hot-rod cell in order to really shine. Ive built mine up with a souped up Qlite. Its a great overall light. When that is said. It does pretty well with something like a King Kong or Keeppower 4500mAh cell too.
In the ZY-T08 with cells in parallel there is no need for "hot-rod cells" since the load will mostly be less than 2,5-3A even in a "hot" light, so you can still use high capacity cells, and still get great peak output and fantastic runtime.
Or you can just get fantastic output from start to finish if the cells are in series and combined with a buck driver. Properly regulated light is just awesome! But then at the expensive of having a basic 5-mode driver and a slightly less safe and simple battery setup.
My twin cell HD2010 with copper throughout leaves the stock light for dead and is a usable camp light with a long run time on maximum if needed. I like it a lot. In this set up as well the MTG-2 operates ideally with a reasonable hot spot.
Great beamshots. Thanks for sharing.
Great shots !
Great beamshots. Thank you for this comparison!
Thanks for taking time to do this! I especially like the dedomed T08. Impressive focus and tight beam!
great shots at a pretty interesting spot. looks like a camp ground.
nice collection as well
Great shots!
You have some nice flashlights !!!
I saw that you lit up the sky in west Norway, all the way to me … 198 miles …
haha.. Kurt_Norway :D
Glad you guys found the shots useful.
I noticed I said one emitter in the Lustefire was de-domed in OP. Its actually two.
If anyone have any questions about the lights feel free to ask..
I have a modded T08 too but yours is even crazier! 6.4A with constant current regulation lol.
Did you measure the lux reading of your 6.4A T08?
And where can I get the HX-1175B driver?
Great beamshots and thanks!
Super shots. Thanks for sharing, this one should be stickied because it’s really a valuable resource for people who are wondering which lights they should buy for modding.
Great beamshots! Thanks for sharing :)
PS: I agree, should be sticky'd
Very nice comparative photos…thanks
+1
I’m interested with the lux reading too. My modded T08 (dedomed XM-L2 T6 1B on SinkPads & ‘blobbed’ resistors) only gives me 5.614 Amps and 151K lux. It is surpassed by my modded Yupard 3405 (dedomed XP-G2 R5 1A on SinkPads & ‘blobbed’ resistors) which gives me 160K lux at 2.709A.
Nice shots!
I love when people do these comparisons. Those wide-angle shots are the best! Very informative going back and forth between the pics, trying to see which beam I like the most!
One question, is there currently any flashlight available right now, that has the Solarstorm SP03 triple reflector, but in a smaller size that would fit the ZY-T08? I love the amount of light that the SP03 puts out, but love the ZY-T08 smaller size. Is there a best of both world's flashlight that takes from both, and combines into one?
Warrior? It's a triple, but 3 cells (https://budgetlightforum.com/t/-/19719)
Need big reflectors for throw, so anything smaller won't throw as well.
Seriously nice comparative beam shots. Thank you.
That is one sweet collection of big lights. You're BLF Certified for the recently rescheduled zombie apocalypses. OK, I'm not authorized to issue the certificates. But, whoever is should issue you one right now. I just slobberized my computer screen looking at those lights and beam shots.
Good source for HX-1175B? I cant say for certain. Check this thread. One source (from aliexpress) mentioned in that thread seems to advertise HX-1175B, but ships out a less powerful HX-1175C. Maybe ouchy had a good link? Again see that thread.
I actually down adjusted the current of my HX-1175B to 6,4A in order to be a bit safer, some info here.
About lux. Nice you asked about the ZY-T08 and not any of the others, because its the only light I have measured. :D
202.000@ 1 meter with a lux meter that reads lower than most/many and no AR lens. Measured at 5 and 10 meters. If I add a calibration value that would get me closer to people with higher lux readings (which seems to be owners of LX-1330B lux meter) I should be looking at around 230-260kcd.
Getting comparable lux values with other members with different lux meters is really hard. Especially since the readings can vary a lot between different lux meters. Im trying to gather some useful info on stock Convoy L4 lights in this thread just to see what differences people see on their different lux meters.
