YUPARD Mod: 9 XML @ 3P3S with FET Driver (3S 26650) UPDATE: 4.3A per emitter! This is Insane ! (Post #37)
Cool! Go for it!
I have not decided between XM-L2s or XP-G2s.
The build will probably have to wait some time though. So you might beat me too it.
Dx has the xml2 version for a bit more.
http://www.dx.com/p/kinfire-k1200s-12xcree-xm-l2-8700lm-5-mode-high-power-flashlight-touch-6-x-18650-291823#.U2xF93i9LTo
I could probably use some advice on the way. I always find unexpected hurdles.
I’m ordering it now. I’ve had it bookmarked for ages and look at it every day. It was only a matter of time. I was originally trying to decide if I wanted the Hyperboost, but it has no modes. This light will get hot on high.
whoaa… nice mod, I was about to give up on my 9T6… I guess this will help me kick start my project again… thanks,
BTW is this FET driver was the one meant for building Mt-G2 light?
Yes. The same one.
I don’t know if I want to trust DX. It does say XM-L2, but they still have the stock XML pictures. I mean if they’re XM-L2 great.
Now I don’t know what to do.
I wonder if I can run that FET driver with 9 XP-G2 LEDs on noctigon? :bigsmile:
Nice! What firmware did you use on that FET driver?
man 10A whoah! Gotta be getting mighty warm on high
Excellent job!
absolutely!
Will be pushing ALOT of amps but if the XP-G2 can handle it…will make one HECK of a thrower !
I got the FET driver from RMM.
OOOohhh… my hand are itchy tonight… I got spare MT-G2 FET driver and sadly no XP-G2 on noctigon :_(
can you mix them LEDs? say 6 XM-L and 3 XP-G2? in the middle? is that even possible? :slight_smile:
I think Vf is different between the dies, would cause one set to pull more current than the other…don’t think they will work w/o one set of them getting way to hot and burning out
I’d probably take the chance for $1.30 difference. L2 in the link, title, desc, and specs. Worst comes to worst and they are XML you could probably file a ticket and get the difference back at least.
I really liked the light as soon as I saw it as a new arrival, but the price tag and my lack of 6 good cells to dedicate to it :frowning: … Would love to see what you guys can do with it.
Does that link pull up in Spanish for anyone else?
I kept getting it in Spanish. I mucked about for awhile til I got the English site.
I ordered it there. There was a BLFDXDEAL coupon that gave me $4.50 off.
I had a bit of a scare. Light was getting sporadic when I turned it on. Thought the switch was going. Bridged the tail and was only getting faint modes, then nothing, then very faint lows only.
I went to pull the driver and noticed there was a tiny bit of play in the driver. I cranked down the retaining ring and all Is good.
I did a little tweaking on my light today. Braided the tailcap and got the reflector sitting down properly.
Three of the emitters, though not off center enough to notice, were off enough that the reflector was sitting on top of the raised part of the centering discs. This caused the bezel to not tighten properly and leave a gap. I removed the three offending discs and sanded the raised part flush. Since the other six were still intact, the reflector centered itself nicely and the bezel threads down tight.
I remembered I had some UCLp AR Acrylic Lenses for my COURUI that LinusHofmann brought up in his COURUI thread. https://budgetlightforum.com/t/-/23051?page=2#comment-509979 I had ordered two, and they sent me three...and they were the perfect fit for this light.
These are really nice lenses, and they come in large sizes from flashlight lens.com.
When you install them, it looks like air, like nothing is there, with a Light transmittance: 97%
If you hold it just right, you can see a pinkish tone from the AR coating.
Now that I've got everything just how I want it, this light definitely earned its clear bootcap award.
Glad to hear you’re happy with the UCLp AR lenses, I’m looking to outfit the worthy lights in my collection with them. Expensive, but worth it IMO. I know they’re not glass, and some people just won’t like that, but their performance metrics indicate that it really doesn’t matter that they’re plastic. Combined with the fact that they’re almost impossible to shatter, I could see these performing phenomenally well in EDC lights, or really any light that sees a whole lot of abuse.
I’m not worried about scratches. Big lights like this don’t end up in pockets and when you set them down on their heads the bezel keeps them from contacting the ground. These are the only AR lenses I know of that come in the larger sizes. If flashlightlens.com backs them, they’re good.
When I started out, I had no idea what the output was going to be in this light. If it had been under 2A per I would have used XP-G2.
When that 12 XML light arrives, I’m going to jury rig it with the stock emitters in place (connect everything externally from the front) to get an idea of the output with 6P2S. Then I’ll decide whether to go XPG or XML.
That AliExpress light is the same as the KD http://kaidomain.com/product/details.S022371? Might be safer from A-E though...
I’ve always had good luck and fast shipping from KD. I ordered the one from DX. I really didn’t want to, and it might have been a mistake, but I’ll be able to let anyone know whether it really has XM-L2 in it. I’m kinda doubting it.
