just ordered 1
thanks old lumen
just ordered 1
thanks old lumen
You’d want a holder for 3xAAA or more probably 3xAA, 3S1P , to get ~4.5 V, but then dimensions of the holder would need to be approximately 18mm x 65mm or 26mm x 65mm.
For example, FT, has this:
https://www.fasttech.com/products/1630/10003869/1276001-3aa-plastic-battery-holder
but that looks like it’s 30mm x 60mm, so it’s a bit too large diameter, and a bit too short, so that one probably wouldn’t work.
Thanks for the consideration.
BTW: Would this lend itself as a tripple host? [anyone]
I don't recall seeing a ~35mm triple board or reflector or TIR.
I think that Ledil has them:
http://www.amazon.co.uk/Cree-35MM-Triple-Optic-Spot/dp/B008AHH4EU
I seem to vaguely recall that someone sold a combo of a 20mm star for a triple together a 35mm triple lens, but I can’t find it now. Seems like it was either IOS or CNQ?
Anyone?
Even with that, for a triple, it seems like the surface where the star was on would need to be moved forward somehow, like a pill extender?
Thanks OL!
I know description and GearBest says XM-L, but I still wonder if it comes with XM-L2 like the lights from WB. Time will show.
In case people want to improve or change how the driver works, and its the typical F13 driver in the lights from GearBest.
-Short connection in red circle if you want 5 modes (adds medium and strobe). Or remove resistor there if you want 3 modes high -"mediumlow" and strobe.
-Add resistor on top of capacitator if you want to fix remove next mode memory. I used an 153 back when I played with this driver..
-If you want to increase current, move positive emitter wire from OUT+ to OUT+1.
-Cooper braid springs
-Replace stock locating ring with butterfly ring from FT.
Or just just replace or piggyback a better driver to it. Which Is my way of doing it. And use a decent XM-L2 on Noctigon.
Thanks for the heads up RaceR86.
Sorry but new to this
This flashlight can take 18650 or 26650 batteries right?
and do you want protected or unprotected?
I assume from my research you want to get panasonic or sanyo batteries and of course I need a charger, suggestions on where to buy batteries and chargers I am in the US.
Thanks
CaptQ
Protected Keeppower 26650 4500mAh
Of course, 10440.
3.6 Volts average anyway.
But it’s that big dye strawhat they all use, with that tiny step up driver without current limiting, just like they all do in that price range.
Bought 2 units, Thanks O-L
Bought one.
2 and a bump.
Hi,
I’m just curious: On my order, placed 5/9, it still says “Processing” and the progress bar is still stuck “Pending”. I’ve already received email from both Gearbest saying they received the order and PP that payment was made. Is this the same for everyone else’s order?
Thanks OL!
Short connection in red circle if you want 5 modes (adds medium and strobe). Or remove resistor there if you want 3 modes high“mediumlow” and strobe.-Add resistor on top of capacitator if you want to fix remove next mode memory. I used an 153 back when I played with this driver…
Hi,
What kind of current increase did you get by moving the emitter + wire to the OUT1+ contact? Will that work with the F13s from this GB?
Cant remember exactly.. Its a fairly long time since I made the picture, and I cant remember where I posted it (and the info about it)
I think it went from about two amps, and up towards 3. But I believe output were sinking fairly fast, and you need a good cell if you want to stay at 2,5A+ for a decent amount of time... When that is said, Im not sure if I tested it with any decent high current drain cells back then.
If its still the same driver it will probably work pretty much the same way.
Cant remember exactly… Its a fairly long time since I made the picture, and I cant remember where I posted it (and the info about it)
I think it went from about two amps, and up towards 3. But I believe output were sinking fairly fast, and you need a good cell if you want to stay at 2,5A+ for a decent amount of time… When that is said, Im not sure if I tested it with any decent high current drain cells back then.
RaceR86,
Ok, thanks.
This is a FET type driver right? I wonder if there’s a resistor mod for this?
CX2829 is the controller and the MEM2309 is the FET. Though really the 2309 FET only has one input, plus 3legs is for Vcc and four legs is for Vout - theoretically only need three pins so why they put in in 8-legs I never know.
CX2829 is somewhat kick-ass cheap controller being able to provide output 1.5A by itself in that tiny package. But it’s only used to control the 2309 FET here, and this FET in my experience can only give out around max 3A when driving older XMLs.
But we’re probably jumping the gun here - not sure which driver we’ll get anyway - this one will be Ultrafire version (instead of Skyeye).
It’s nice to speculate though :)…
According to this:
Please bear with me on this, I’m not expecting to get any answers but it’s worth a shot incase one of the resident electronics experts has an idea. Before I start, let me just say that this is a photoshopped image. I couldn’t find a picture of my driver, but found one very similar but with a few extra components, so I shopped them out. In the image below, what you will see is Exactly the components I have on my driver board. There is nothing on the back of the driver. It is a 3-mode driver. I…
MEM2309 Series P-channel enhancement mode field-effect transistor is a MOSFET
Is there another FET that might be compatible that’s lower resistance/higher current?
I don’t recall seeing a ~35mm triple board or reflector or TIR.
Cutter sells triple and quad boards that fit 35mm TIR optics. The Ledil Cute-3 and Cute-4 as well as the low profile GT4-xp series. The only 2 boards I’ve ever seen anywhere else fit these fantastic optics where Pilotptk’s integrated board and one made in EU, also integrated.
