New light or new build SST-90 vrs HID
With the SST-90 you have to be careful at the tailcap, the resistance, some switches won't do 9A.
I am not sure about this but I think non-spring tailcaps are better than spring tailcaps when it comes to high current. Anyway in this case there's no spring in either host.
They all have the spring, the "springless" ones just have a cap over it.
Das, it's the 35/50w model. CNG sells the other weaker model, too, they just mixed up the specs.
Bro, get the 65W ones if you are interested. Cheaper...I have 2 units. I am getting 235k PBCP for throw. Lumens is ~ 4000 lumens as compared to a 2.5A XM-L @ 800L for reference. My timing is about 80 mins run time on high and with a bit of breeze it can survive through, i tested it multiple times. You may have to wrap the ballast up with foil if you do intend to run it long and on warm nights. These are the specs which you'd know, the others on the site are a bit off. This is more like the lowest performing models in the HID world, but for the price it is ok.
http://www.aliexpress.com/product-gs/469546972-HOT-65W-HID-Flashlight-6000-lumes-for-outdoor-hunting-very-brightness-wholesalers.html
It is slightly more expensive to USA I guess. It's only 122 shipped via EMS here. You do get a nice alu box. Spare parts like spare batts and ballasts are available, not expensive as well.
But the beam profile of this kind of HIDs are less useful than those nice circular discs that you'd be used to LEDs. The advantage is that it is focusable and so it can flood as well as spot/throw, it floods really good so its useful for flooding 45 deg to say 50m, no LED can come close. Throw is not good in HID-speak but at 235k it is still decent. You can look at my beamshots at CPF. It is also doing 3S3P for Li-Co, the chargers charge to 12.4V so that's cool. You need to be aware of this because so many are very touchy. A Li Po safe bag solves the problem, charge outside if you want guarantees. Issue is discharge, there is no way of checking cell balance. I guess if it vents, fling it away.
But seriously, now with the advent of TK70 of the same form format and available from HKequipment at a nice price, i am not sure why aren't you going that way. You already have a hobby charger, 4 Tenergy cells are only 28 bucks.
BTW, EMS costs 36 bucks to here. I think its over 50 bucks to USA. This is for CNQ.
Thanks for letting me know.
How about going all the way bro? Get a re-con UPS. Semi-portable. Forget about what 60 x XM-L builds.
http://www.aliexpress.com/product-gs/481467543-M-2005-Eight-Search-light-wholesalers.html
Specs. http://www.aliexpress.com/product-gs/247673595-HMI575W-metal-halide-lamp-wholesalers.html
240,000 lumens from 8mm gap, 2500W. Or you get 30k lumens from 1mm gap. Compare with XR-E. Who's the daddy? And big ass reflector, simple pure physics.
From Guangzhou : http://www.youtube.com/watch?v=APbk6vcZR5E
http://www.youtube.com/watch?v=5MNsDh8Q42Q
These are like the digital world. If you like analog warmth, there are also options.
http://www.youtube.com/watch?v=3qDc1MIKnMo The beam is brighter than what is depicted in the video, check out the HPS streetlamps, so dim!
Carbon arc close-up
http://www.youtube.com/watch?v=u8e_u_xqN30&feature=related
At a place near my home now they have about 20 waving around madly since its near our National Day Parade, and I think about 12 from a local hotel (Marina Bay Sands, parent company is Las Vegas Sands). 2 weeks ago it was stormy and raining, too bad I did not get the video, simply awesome. I don't have space for such stuff though, I live in an apartment. Something like this : http://www.youtube.com/watch?v=FKHwsxTTf-I&feature=related
BTW when playing with high powered HIDs, be aware that the intensity can blind you, in addition to some UV risks. A collimated HID beam has fire risks as well. Treat them as if they are like lasers. Carbon arcs have CO poisoning risks as well.
This video shows nicely what a typical beam profile is http://www.youtube.com/watch?v=o5WV3vviL64&feature=related Spill, big corona, small central hotspot.
2100- Those things are nuts! But not what im looking for, The search lights that is. The 65W one looks as good if not better than the 35w/50w but i gotta look deeper. Also you have a link to the review? I find CPF a mess to find info at times. Also does that 65W Hid do 110v on the charger as the AC input?
agenthex- I spent a few hours on Google last night researching the light and found it to be the 35W/50W when i saw a place advertise it and they didn't copy/paste the description like every other place does. But i gotta weight the costs as CNG charges shipping which i didn't realize.
I didn't mention this, But id like to keep the light between $125 - $150 no matter if its an SST-90 build or HID. The HID gains points as the cell comes with it and i only need one.
Ill look on our vendor section, But whats the word on www.aliexpress.com and CNG as a company? Hopefully better than DX or ill forget using them, Same for CNG.
Looking at aliexpress.com i can also get a 7800mAh battery for $30 more. Both are better than CNG's light and the price is about the max i was wanting to spend, But im not so sure the higher mAH battery is worth $30 extra. But buying a spare is about $60 with shipping.
US $168.45 http://www.aliexpress.com/product-gs/457543621-65W-55W-45W-HID-flashlight-HID-torch-7800mAh-wholesalers.html
110mins(45w), 80mins (55w), 60mins(65W)
US $138.94 http://www.aliexpress.com/product-gs/469546972-HOT-65W-HID-Flashlight-6000-lumes-for-outdoor-hunting-very-brightness-wholesalers.html
130mins(45w), 100mins (55w), 80mins(65W)
BTW i dont like the TK70, Its just not a style i like.
Next i need to look into the SST-90 further and look at hosts and parts prices. As it should do pretty well running 2x 26650 IMR cells. Luckily they have just as high capacity as a Li-Ion cell.
If I were going to build an SST90 I would probably do it in a Mag with DW's heatsink and driver.
Das, don't go the 7800mAH route. Use the money to get a FF STL-V6 for $16 more. 6600mAH gives you 80 mins run time once the cells are cycled, more than enough. I actually have a 50W rated ballast which the 65W is quite a bit brighter and the 50W gives just below 100 mins run time. I have tested my 2 lights combined ~ 20 times already before buying a bunch for use in Indonesia now with nearly 500 man hours usage, i mean it is definitely > 70 mins reliably even after like 100 times recharges for each light now. Maybe it'd start to show signs of cell degradation/less runtime at 200-300h mark I don't know, but even then it has more than exceeded our expectations.
I have played with the SR91 (SST-90), forget about it.
We also have some Guangzhou Sanmak 55W 7" reflector (after minusing the bezel it is 6.25") throwers to do nearly twice the range at about 650k, but the runtime is pretty short at 40 mins.
But now we might be going the TK70 route. Luckily we did not go for a full lot with the Ebay/Aliexpress flashlight format HIDs. The thing about HID is not about warm-up, which is pretty fast if you can wait 10s. But the repeated ability to switch On, Off, On Off at your command, at 2000L, at 1000L etc. That saves power and also maintains "covertness". Hot-restrike is also bad for the bulbs, but of course for home use that is not an issue, and China bulbs at usd13 a pair of 55W that is no issue. If you are hunting/patrolling for people (LOL!) or animals then you may not want HIDs if you need the light a a whim's notice occasionally.
The thing about these Ebay/Ali lights and ballasts, is that 65W actually means 65W input, and more often than not if you get 60W then you are lucky already. It could be 55W nominal and 50W wouldn't be a surprise for me. I have got some auto ballasts which are way off, some are way under and some are over. But the cells seem to be decent, it is a 3S3P config inside with 18650s, 2200mAh each cell but probably some 2Ah in reality. That is why it can still do 80 mins. The specs are off, as usual, but fear not so are the SR90/SR91. :)
Also...do look at this first in your home country.
http://www.batteryjunction.com/titanium-innovations-hid-products.html
the 6" reflector one is the famous Amondotech 3152 (back in 2005/2006). The Mega has a 8 or 9" reflector I think.
BTW, can i ask at your local K or Walmart or any hunting store etc, how much can you get the Costco Thor X colossus? That one with the 9" reflector. Just get a 100W ballast/bulb kit (1 pair - very rarely can you get 1 piece) for 100 bucks and be done with it, you'd get 2 million lux @ 1m easily.
I've never actually seen that light at costco as of late (since getting into the hobby), but I would imagine something like that uses a h3/standard bulb would be available somewhere for similar prices to amazon. Basically ~$50 + hid parts, but some labor to make everything fit and work well, and even then you're left w/ a SLA battery that you have to maintain unless you want to spend even more $ and effort.
Personally, if I'm going to spend the time to make something custom, I'd go for silvering out a parabolic dish and making something like superlight above. Even with a normal led at the the focal point, it'd be pretty epic.
Wow, This is kinda overwhelming atm.
Id like to restate im aiming for 65% throw and 35% spill configuration, And a large cell setup like the 22650 or 32600 2x-3x cells. But the HID has the large cell pack which is ok also.
BUT, The hid takes the fun out of building it. That is building something that fits in a normal flashlight form factor.
Also building an SST-90 will cost as much if not more than the Hid to build and im not sure it will even compete power wise.
Im also a budget guy at heart, Even tho i do like to try the higher end stuff as long as i can justify the extra expense. I know im getting bored with putting XML's in everything, Well kinda as i like upgrading smaller lights to run brighter and more useful.
Ive been thinking about one thing and that is i rarely get to use my lights outside the house, And i doubt a 65W HID light is good for interior home use. But id still like a thrower. Maybe i should look at a recoil thrower? And also get the 26650 light from CNG either as an SST-50 and upgrade it as i go or buy the host by itself, As the electronics are worth the extra $22 if i gut it.
Ill be honest my head has been a mess lately so until i get that clear and working well i have the cash waiting.
My only experience with HID is with dive lights and the one I had was only 10W but the bulb itself (replacement part) was close to $100. If you go with HID make sure you know how much the replacement bulb will be.
They are also more delicate. If you drop it while it's on (hot) the bulb is probably toast.
At least with mine you also can't just turn it on and off without waiting like you can with LED. Balast needs replacing as well.
The Auto type HIDs can hot-restrike, no issue at all. I must have strobed them hundreds of times like disco doing signalling. Heh.... It just runs them down a bit from 5,000 hours, no biggie. Like your flurorescent tubes (not supposed to strobe them bro). One thing that is extremely hard is overdriving and esp if you like to point the HID more than 45 deg up, ie burn position. If guys can gun P60 XM-Ls at 3.5A with lousy heatsinking, you can do the same for HIDs. Each 55W bulb is just like 6.50 bucks shipped. I think I must have close to 30 bulbs in total here, waiting to be abused. Tongue out
I purchased the generic flashlight form bulb + ballast combo before, believe it was $40 shipped EMS, unit price is $24 or something. So not that bad. Battery is around the same.
But of course I'd not encourage you you to go HID if you don't need the pros and are affected by the cons, as you can clearly see it is not for the usual folks. Start with the small stuff like SST-90 first and slowly build up when you have the urge for more light. :) I mean come on, you are not aiming to be able to hit 1 million CP mark with just 150 bucks and expect zero cons? But talking about your needs with 35% flood requirement, i think the Ebay/Ali flashlight HID is good.
12V 7AH SLA is just usd15 a piece here, or a pair of XTAR 2600s on offer. :)
I guess I don't understand the difference between the different applications with HID. A 10W Welysh Allen light bulb is close to $100. I know the HID bulbs for work bench lights are $10 or less so there's something I'm missing obviously regarding HID :)
Im just not feeling the HID and its purposes will fit much into my needs, And i have very few needs and could have bought a KD C8 and i would have bought all the lights id ever need in reality. But this is a hobby and not a necessity thing for me. But i do need to justify very pricey purchases so im not spending money on stuff im just looking at everyday and get no use from it.
Id prefer to build something, But thats not so easy with HID imo. But i do think an SST-90 build with well matched emitter and driver run off of 2x 26650 IMR cells would make a really strong light. So im still looking at the host 2x 26650 from CNG or the SST-50 version since its only $20 more and i can reuse the old parts in another light for alot less than i could buy them for.
If you're looking to reuse parts, you might even look for a 18650 x 2 host and get IMR's. Like the fandyfire stl-v6/ skyray stl-v2 ~50$ and pop a ssr in there. As long as the 9A driver fits the reflector should work ok as long as you focus it right.
A Philips D2S is also close to 100 bucks. They do perform some higher wattage ones do 120 lumens / watt. The Chinese ones usually are not that bright/efficient, some have arc chamber deformities after certain hours as the QC is not very consistent etc. But they do not really matter to us hobbyists who are just after having fun and the occasional blast for a few hours every week at most. Like there are applications/needs for AW IMR cells and also apps/needs for BIO IMR cells (quite good, there are some good info here)
Like some of the Ushio sealed PAR64 cans and the Chinese cans and bulbs, it is $600-1000 for Ushio/Philips bulbs and $50 for the Chinese ones as I have shown above. This is why they can churn out a 100 million CP advertisement searchlight for usd400, and shipping to Taiwan is just $200 via EMS and $350 here.
Of course if you have a specific use for it, then go for the good stuff. HIDs also generally have better CRI than LEDs.
