sounds like a potential issue - i would try charging the cell and see what happens… or perhaps try a different battery to confirm - if it persists email hkequipment for a RMA
Stung for custom charges that almost negate the GB discount, but still worth it!
Only had the lights a few minutes but i like them, seem like nice, solid, ‘no fuss get the job done’ lights, and if i’d realised how easy it was to change the emitters i probably would have bought more for gifting. Might still do.
Thanks again jmpaul, and glad you got a little bonus.
One question, does anyone know how to remove the lens? (as in the actual piece of glass.) It looks like i need to unscrew the silver metal bezel, but can’t see any way to grip it.
I did try again after charging the cell and then ran it on turbo. The low frequency flickering happened after 17 minutes. Pulled out the cell and the voltage was 3.8V. I’m not sure what to do now just waiting for my new cell to arrive.
SG3NW is awesome and perfect except some minor cosmetic “dings”, and has already eaten its o’ring, but that’s not really a problem.
SF3 NW is ok except it looks like it will be eating o’rings quickly too, but there is a small darker spot on the led, and the lowest mode is flickering
It will probably receive a new led very soon, I also got some XM-L2 T4 7A4 this morning
I think the SG3 will replace my Zebralight SC31fc for now :party:
Your SF3 has the same problem like mine did except the flickering is in medium 2 and turbo only. I think this light (SF3) is picky with cells. I just returned this light to HKE and swap with SF5. Great customer service by them! I think it will be easier to just use my eneloops. I don’t mind the lower lumens and the runtime will be longer too. Well, I did lose $6 for postage (not really expensive from my country) but overall still a great deal.
I have not received my SF3 yet. But I worry about the problems I read about the flickering in some modes. I wish to not have such problems, i would be really upset.
I also think the SF3 is just picky about cells. I actually get the flickering on turbo with my brand new AW cells. My theory is that the SF3 is pushing the battery so hard on turbo that it’s causing grief with the protection circuits. I think the flickering is the protection circuit partially tripping. For whatever reason my EagleTac cells just power off when they hit that point, where the AW cells seem to step down a little and flicker for a little while before the protection circuit trips all the way. The TF flame cells seem to go about 30 seconds before they trip the protection and just power the light off.
My SF5 doesn’t have this problem, but then again it doesn’t seem to be as bright on turbo. I think the SF3 is just pushing the batteries too hard. I was thinking of getting some AW IMR cells next to try.
I’ll try some RCR, I have AW protected and IMR, and some Nitecore/Eagletac.
For now I tried with CR123A battery, after leaving it on for a little while it seems to flicker a bit less.
