Ha, Chinese lumen just bounce off me anymore; I didn’t even take note of that ‘spec’.
I’m hoping it has the same boost driver as the mini-01. (per spec;High, low, strobe) It’s not bad; direct drive above Vf, .15 sense resistor, about Iout = .1/R …adjust R according if you don’t want to drain a CR123A so fast…. draws about 650mA on a fresh CR123 and goes up from there as the battery drains. (…that’s what I do per my ‘LowLumen’ namesake) I will report back on how this clone compares to the original.
My mini-01 mod runs on CR123A for 4-5 hours on high, 40-50 hours on low. 100 lumen high, about 10 lumen on low. .37 sense draws about 270mA on high…. .27 works well on CR123A too. …. Low Lumen, long run time.
From the pics. looks like these clones have smooth reflector too.
I also ordered one (red, for my keychain) and we will see how it works out! I’m going to try my hand at OshPark in the coming weeks to see if I can make a 7135-based driver for this light. God help us all.
Scratch that, just going to use the 15DD V3.0 for both my SS and my new Al lights coming in, no sense in making it more difficult than it has to be.
I have gotten three of them off of evil bay for about $5 each. I like them. Very light weight even with the battery in. Perfect for a keychain light, the one thing they all had in common though was that the emitters were not centered. Not exactly a deal breaker but it would have been nice if they had spared the extra two seconds for a proper centering.
They did put down some kind of thermal paste but it was dried to a crisp and worse than nothing. So if you feel like taking the time to pull it apart to center them you might as well put some fresh thermal stuff down too.
Probably at least $5 and they don’t seem to give a break if you buy more than one. You can try but I’m tired of trying to get deals from their site. I have managed to pick up one light that was a deal from them so they do deliver but they are a PITA to deal with.
I have only one light from them, and with the shipping it was not the lowest price. I am waiting for a shipping cost email. Not giving a break for multiple items is a bad problem with these small items.
I got the blue one and the chrome/silver one I ordered a few days ago. Shipping (to the east coast U.S.) was SUPER fast, and darn, these little things are bright. Definitely a good deal!
I got my Smiling Shark SS-508. It has less lumens but better throw than the TrustFire, as one would hope. However it is the first Smiling Shark light that I have found not working properly out of the box. These are simple twisties with the edge of the body contacting the driver to switch them on. This one has the driver contacting the head. The threads are anodized, but imperfectly so. So it is on when screwed tight and intermittent when loose. I will have to file the edge of the driver. Nice looking. Slightly longer than the TF but very light. Very nice keychain attachment, except for a simple ring that looks weak and I will replace with my smallest keyring. The hook looks secure, but I might replace it with a fishing swivel attachment to be sure.
The driver consists of two resistors in parallel. At least that makes it clear how to increase the output.
Added: I have it working now. At first the driver came out and in easily, but it got stuck and I took the whole head apart, which is hard for the usual reason that there were no notches on the pill to unscrew it. The pill is a thin aluminum ring, cut out for the star, but the driver butts against the pill and fits snugly in the head.
It weighs only 20 grams.
yours is probably the best in that you wont kill it with a 4.2v li-ion.
anymore i wont even look at anything i cant use a common rechargeable in.
how good is the thermal path from led to body?
Thanks for the heads up. I think frying them might annoy me slightly. How would I know which I have? They both list CR123 and 16340 as options, but both also state working voltage is 0.8 - 3.6v. One from FT, one from Kaidomain. The KD one was $5 dearer.
