Flashlight collection? off the top of my head without looking:
1xAAA lights:
- Fenix LD01
- Liteflux LF2XT natural anodizing
- Liteflux LF2XT black anodizing with emitter upgrade to XPG R5
- Tank 007 TK703
1xAA lights:
- Eagletac D25a titanium XPG2
- Jetbeam BK135a
- Jetbeam PA01
- Sipik SK58 (modded to XML2 neutral, 4 amp, electronic switch)
- Sipik 58 (modded to triple Nichia 219 @ 3 amps)
- multiple Sipik 68s and clones
- XTar WK41
- Sunwayman V10a XPG
- A couple LED Lensers (I forget the exact names)
- Zebralight SC52
- Zebralight SC52w
- Spark SL5 neutral XML
- Zebralight SC80 XPG
- Thrunite Neutron 1A
- 4-Sevens mini AA XPG
- 4-Sevens mini AA Titanium XPG
1xCR123 lights:
- Eagletac D25c aluminum 2012 neutral XML
- Eagletac D25c aluminum 2013 neutral XML2
- Eagletac D25c Titanium 2012 upgraded to 5000k neutral XML2
- Jetbeam RRT01 (modded to XML2 neutral)
- Jetbeam TCR01 (titanium)
- Olight S10 (modded to XML2 neutral)
- Olight S10 Titanium
- XTar WK42 (modded to 3 amp XML2 neutral)
- Sunwayman V10r XML
- Sunwayman V11r XML
- Lenslight Mini XPG neutral
- Spark SF3 neutral XML2
18650 size lights:
- Convoy M1 (modded to 4.5 amp MTG2)
- Roche F12 (emitter swapped to XML2 neutral and lens swapped)
- Roche F12 (modded to triple XPG2 neutral at 4.5 amps; battery tube cut down to 1x18350)
- Zebralight SC600 (early model)
- DQG mini 18650 (first version)
- Shiningbeam S-mini (neutral XPG)
- Sunwayman C20C (emitter swapped to XML2, but will shortly attempt to mod to MTG2 @ 3 amps)
Other:
- Probably 15+ other cheap budget LED lights of various sizes, some modded, some not. Many of them zoom lights.
- Several old Inova lights, some with 5mm LEDs
- Lots of cheap keychain LED lights with 5mm LEDs
- My earliest LED light: a small plastic keychain light with a titanium sleeve. Powered by 3-button cells. Light source is a 10mm red LED. Purchased at least 22 years ago.
- Various old incandescent lights: small maglites, 3 battery powered fluorescent lights, a couple Underwater Kinetics dive lights.
_
My current EDC is my modded XTar WK2, now equipped with 3.04 Nangj 105c with DrJones Lumodrv, a Radioshack micro-momentary switch, and a 5000k XML2 neutral on Noctigon.
