different tubes I think to use in different diameters from ~45mm to ~65mm just to see how well they feel in hand…
I like the denim one. But I also liked the first one you tried, with the text. Do not paint it :-)
Looking good !
DenBarrettSAR thank you, your new avatar looks splendid too !
Ledsmoke haha if you like it than maybe i make one shell with that bravo drinking just for fun. I think to experiment little with that denim too, its big if i remeber right now around 60 mm diameter and that is a plus for me in the sense I can realize what I have in mind from the start, that can use both 18650, and AA too. I need AA to have high current draw, but maybe they will not deliver in the end …. who knows
my plan is to put 3x18650 or 3x3 AA in parallel if i get over 4 A to the led i will consider it success in my mind :bigsmile:
I just hope that that in 4.5 V setup for AA (3AA in series), they will not drop V too much under load, other-ways they will be useless as performance boost in my setup.
anyone have experimented with alkaline AA? any numbers in different setups? how about in 6 V setup X2 or x3 in parallel that 6V setup how much current they can handle ? how much voltage will drop under load then?
all this is because i want to use amc7135 and not FET or something else and be able to go at least over 4 A to the led (xml or xpg or what ever)
my driver can handle ~5.5A theoretically but voltage drop of batteries under load is the big barrier in my project ….
Wow, fascinating build. You’re a master at fabricating with copper wire.
I like how this build is developing. Keep up the good work!
I vote for black. The cans look recycled. There is nothing wrong with recycled, save for the impression that your light is re-purposed junk from the roadside. While the black maintains the impression that this is a light is an artistic creation of yours. Or I think too much. Either way I enjoy seeing your work.
Very original! Is that a stage lighting lens? Where did you get it?
I prefer the descriptive “revitalized junk” but I think some silver flames in that black ala OL would be cool. Or maybe just a hand print
I like the black tube, maybe with a red thumb print? Or a print panel lock-out?
Think I’d stay with the 18650, keep it light and know the cells performance level is up to the task. Or a 26650 King Kong for the capacity of it.
hahah i was thinking exactly the same with my self but a “Bravo” version is in the progress too …
thank you. i got that Fresnel some month before when i was experimenting with lens, do you find this interesting because you are the reason i bought this one back then
I have read your thread in which you use a similar lens after that i decided i have to play with one too :bigsmile:
yes something with red or dark red have to be… i was thinking similar thing, problem is there are so many choices there is hard to decide and the time is a factor here…
by the way i have found my self several times reading your thread and one interesting bit is that i tend to look A LOOT at my current progress and then the imagination start to do the work, similar no?
thanks for the ideas on printing. Battery section on other side is killing me slowly …
i just hope will not go the route when i take some batteries rolled and bury with the tape all inside the tube :weary:
Hope it’s going well. This is one of my favorite threads.
Thank you RBD as allways supporting others
I wonder where do you find all this energy and time to proced as a swiss clock in progress with your building and also supporting and helping others
I have made progress, in fact from today my flashlight is 100% functional but have to make cosmetic work now. Not to sure on time so I decided that will not spare it with posts, till I make it functional, now I can finally start to update here. Hope time will be ok for me in the end to finish completely and also post all the work.
So which tube did you decide on? Just when you think you have seen it all with hand built lights theres another just as unique as the rest of them comes right at you. Looking real good.
In a way I think the hand made category has an advantage in not being limited by what a lathe can be made to do. You don’t use a hammer on a lathe but I use mine all the time. Used it today in fact. Anyone want a 75mm aspheric lens with 100mm focal length(all that’s left of my magnifying lamp)?
Time forced me to stick with black one and not experiment further.
I am looking forward to it, I can’t wait to see beam shots. Great work Ervin.
scottyhazzard beam shots are ready just started to update
post 2 again updated (how tiresome this days are only us that are building and fighting against time can really know )
Amazing Ervin. You have one extraordinary clever mind with a talent to build what you dream. I'm speechless really. What an effort.
