What is the voltage range of that driver? If it can buck 3x in series down to run a single emitter…I have a home depot defiant I can upgrade to a 26650 rather than C cell
I expect this driver to perform like a less-efficient new-version DRY driver. The voltage range should be something like 2-3s or 2-4s. Remember, this thing will be huge with the torroid on top.
I have revised the driver to add 0805 caps for both Vin on the QX5241 and Vcc on the ATtiny. I also added a second sense resistor in parallel. I did not do a very clean job and I will probably improve the layout in the C1/R4/R1 area at least, as well as some unattractive traces.
Yea, I think they look off too. 0805 should have a pad separation around 0.7mm. Oshpark renders boards using tStop for the copper areas instead of Top for some reason. Makes all pads look 3mil larger in the renders.
Are you using the oshpark DRC? The default eagle DRC has 4mil mask instead of 3.
I don’t know, even if its the eagle default 4mil, pads look off. Course I didn’t sleep last night so my eyes might be off.
I didn’t realize that I could adjust that - I see it now. Thanks. I had it set to the default, 4mil. I’m using the Eagle R0805 package for the divider resistors and C0805 for the caps.
WarHawk-AVG, please read the thread. It’s a buck driver and will go at least low enough for a single white emitter. Results are posted in the short thread I linked. The driver will not operate on a single lithium ion cell. The links in the OP were meant to answer this question.
Thanks, let’s hope we get something useful out of this thing. I’m feeling pretty good based on the lineage (all the other successful drivers based on this controller). The only thing that I’m concerned about is how big an efficiency hit we take from eliminating the weird dual-FET setup I mention in the OP. It’s not a synchronous buck configuration, so I really don’t understand what those other designs are doing with the second FET.
At ~$2.50/each in China I figure that’s not much better than the new-version DRY driver. Has anyone seen these drivers around on AliExpress or eBay for a better shipped price? I see them on eBay for crazy prices (>$10!!), but no decent prices.
I’ve just taken a closer look. I’m seeing about a 0.16in / 0.4064mm spacing. Are you guys using the stock Eagle libraries or something else? Thanks.
EDIT:
Well, I made some mild placement adjustments, cleaned some things up, and fixed a couple of DRC issues. v014 is ordered for testing. I don’t have a lot of parts to test with, so let’s hope it doesn’t fry stuff.
Custom Eagle parts makes sense. I’ll have to take a look at these PCBs when they arrive (since I know exactly what Eagle parts I used) and compare with real life 0805 components.
While looking at other drivers I recently realized that there’s no reason for me to fret over the need for a big inductor. I’ve been looking for wrapped toroids like we find on the DRY driver and original SRK driver, but I wasn’t able to figure out where to shop parametrically to find high-current toroids at the desired inductance. Turns out there’s no reason not to plop a (phsyically smaller!) SMD inductor right on top of all the other parts. It’s big enough to easily hookup with an air-wire.
This solves half of the crisis I was running into… the parts on the new-version DRY driver are probably spec’ed for 3-5A, it’s hard to say. zeremefico showed the driver running at 7A, but he did not discuss heat. I assume that at that current the diode and inductor are putting off some heat due to being under-spec’ed. I know people are going to want more current. A bigger diode is possible with a redesign and easy to source. We’ve already got the FET bit mostly figured out, that’s old news. So the missing link was the inductor.
Big inductors still cost a few bucks and the corners start to poke out past 16mm or so, but I think this is doable.
FWIW the lfpak56 is about half the size of the larger fets and is rated for 100A if you find board space tight. There’s an even smaller “33” rated for 60A. The design is only a few years old so it might not go out of production soon like the Vishay did.
Thanks RBD. I’m going to look into that package, space is tight if I try to put an SMD inductor on the board.
The particular DPAK Vishay product we were buying on eBay was no doubt out of production long before we started buying it. Powerful DPAK/TO252 FETs will probably be produced until after we are dead. There should really be no fear of the supply of DPAK FETs drying up.
Well, thanks again RBD. That was a great suggestion, and together with making my work area an actual 17mm circle instead of 16mm (!), that freed up a lot of space. The pin configuration is also different, in a good way. I’ve done a total rework on the board.
SMD inductor. There is space for approximately an 8x8mm inductor. I will rework the pads to better accommodate various landing patterns.
~1.1mm uncovered via to add a big wire-wound toroid inductor instead of the SMD one. This is just an option in case that makes sense for a build.
Large +/- LED pads on more or less opposite sides of the board.
Swapped diode to top of the board. Lots of space for the diode. You should be able to fit various ~5A diodes on those pads
Moved MCU to the bottom
LFPAK56 / SOT-669 / Power-SO8 style FET - there should be many options for this
Three 1206 sized sense resistors, still on bottom.
The bottom now has a smaller component height. You should be able to use a standard Nanjg 105c spring (5mm x whatever) or a standard 5x2mm brass peg. I’ve removed the wings from the 5mm BAT+ pad though, so in order to install it you need to put it on before the sense resistors. There is a large copper pour between them, just heat the pad using the sense resistor pads.
I kept the offtime cap, but I also brought out PB2 on top of the board. It’s available with a covered trace between inductor and FET - just scrape off the resist. This can be used for an e-switch, but like I said before this driver will have a really high parasitic drain and is a bad choice for an e-switch. I’ll probably remove most or all of this trace when I rework the inductor pad area anyway.
