Yes, that cap is for offtime STAR firmware. Unfortunately I’m sort of out of space to put it anywhere else and still look all cool.
Thanks for the compliments and thanks for taking a look!
umm…where is the + and - pads for the wires?
I do need to add those GND vias, totally forgot about that.
Mattaus is a stickler for rounding corners, but as far as I know there are only two reasons to make nice corners:
Since we have guaranteed tolerances for these I don’t care about fab issues. None of our signals are delicate.
Being the off-time cap it’ll be ok there since you have to remove it to flash anyway. I’m glad it’s there, not that it’s hard to out it between the pin and ground but it’s always nice to have a real pad for it. Looks good, I have a light that needs a 22mm driver, I have a contact board ordered but I’d love to order a set of these for it instead and test it, if your looking for someone send me the files and I’ll order 3.
Yeah, makes fine tuning the traces a pain but make for a cleaner render (but makes your head hurt from all that tweaking, re-tweaking, and tweaking some more)
either way, once it’s done it will be a POWERHOUSE of a driver…gonna make those XM-L’s cry for mamma
This will go into a F13 and other 22mm rigs right…I got mine in today
ah…forgot about that
And I guess if you get a good off time build you probably won’t be reflashing that often huh?
Yeah, that’s a minor problem…
This version has:
I haven’t gotten things 100% worked out with where I’m removing the solder mask for LED- and LED+.
First set is on the May 04 panel!
tStop on minus pad
need - and + on tDocu
And I usually make the identifiers .6~.8 but that’s just me (yeah…nitpicky I know)
And need a BLF on it somewhere
I did mention that in post #10. There’s plenty of copper there to solder to. I’ll probably leave both pads covered in the next version and remove the mask from at least part of the two big vias. If someone wants to solder to the small 1x1mm surface area they just need to scrape.
Identifiers? The GND vias are 0.5mm because that’s what fits.
The tDocu letters R1, U1, the white letters on the silk screen (identifiers ???)
Still a pretty darn cool design
Oh, gotcha. I just ignore that stuff until the rest is sorted out.
Is R1 a resistor or diode?
Depends on whether D1 is populated with a Zener diode or not.
I was confused why there is a zener diode for a single cell flashlight driver. I'm guessing you're designing in options for use in other lights later on?
It looks good.
Well, really just for flexibility. Mainly as you say - in case someone wants to use it in a different light. Also though, someone might choose to run the F13 on a pair of 18350. Or if some battery manufacturer ever made a good 26350 :drool:
Thanks, I couldn’t reconcile the print and the pictogram.
Don’t tease me bro.
What did I change? I don’t know. I spent too much time tweaking stuff tonight.
Just for fun, here are the drills:
