Is there a path between LED- and the big copper pour on the back of the board when:
- the light is off
- the light is in low mode?
obviously thereâs a path for M/H/T
If they are sense resistors, which component on the board is reading their voltage drop? If the LTC1871 were controlling the modes I could see it, but we know it's not. It looks to me like it just boosts up to whatever set point, then the path to ground is routed through the appropriate resistor via each mode's little FET.
The big cap between the inductor & the LTC1871 is on the main B+ pad on the R/H side, its L/H side goes to a longish fat trace that goes down to a medium size cap, the thing marked 82LE, and a tiny cap. There's a big horizontal B+ trace at the top of the inductor. Easiest seen in this pic:
Anyway, I'm about certain there's not enough room in the light to fit a piggyback board on top to hold the attiny - depth in the head is only 5.8mm off the top surface of the original driver, and the inductor takes up 3mm of that already. The only workaround I can think of at the moment is something like gluing the attiny upside-down onto the board where the original MCU is and use jumper wires to route the legs to the right pads. :(
Funny you should mention that. I worked on this some but decided it was a stupid idea. You have to reflow the adapter PCB onto the main PCB of course - either a big hoof tip or some chipquick might do OK, or just hot air. Then you solder your regular ATtiny on top. Total height should be around 3.5mm
So as to this stuffâŚ
My bad on sense-vs-limit. Now that I think about it Iâm not certain that they arenât limiting resistors. At this point I could go either way, without a schematic itâs hard to guess. Gotta figure out whatâs hooked up to the SENSE pin to know for sure. This thing can do a weird sensing setup as well as a more normal one. Iâm not certain they arenât used for sensing, but Iâm leaning towards you being correct.
Thanks for the clarification on that path, I see it now. The LH side of that cap is a ground of some type, even if itâs not real GND. The medium sized cap you mentioned hooks up to INTVcc (pin8), so it must be a smoothing cap for that. (Therefore the other side, which connects to the big cap, is ground).
Is the mode separation as good with the MT-G2 as it is with a triple?
Just from memory, I think the output currents were something like just a few mA in low, .25A in M, 1A in H, and 1.5A turbo. Of course now we know what they do, those levels can be adjusted with different resistors. I don't know how that compares to when it's running the 3S XPG2s, though.
Sorry, now I forgot what I planned to learn from that.
Anyway I went ahead and put an outline on that adapter PCB and uploaded it to Oshpark. It has to be slightly large in order to meet minimum size restrictions, you can file it down.
~~http://oshpark.com/shared_projects/WtKCjCqt~~ EDIT: see post #57
I also thought about putting a via through the middle of each pin. Youâd need to file up to halfway through the via, but it would make the board easier to hand solder.
just burnt my driver, bridging the r120.
one of the two mcus, that they are on the spring side, burnt.
If I try to power again the flashlight, this mcu burns again.
I measured 11 amps on high with a KK 26650.
Those are FETâs, not MCUâs. They are just in the SO8 package.
I only know the model information for one of those two. It seems you are lucky, you burned the one we know about.
Digikey has it in stock:
http://www.digikey.com/product-detail/en/AO4468/785-1038-1-ND/1855980
eBay is probably much cheaper for you, luckily there are plenty on there:
http://www.ebay.com/sch/i.html?\_trksid=p2050601.m570.l1313.TR11.TRC1.A0.H0.Xao4468&\_nkw=ao4468&\_sacat=0&\_from=R40
EDIT: fixed Digikey link.
Thanks, is there any which can handle the extra current?
Possibly, but I donât think itâs a good idea. 11A is 30-35W from a single 26650. 11A looks like itâs pretty rough on a KK.
We don't really understand how this driver works. Swapping FETs could cause big problems. That said, maybe a PowerPAK SO8 style FET would be a good choice. For example, the SIR462DP can handle more current and has much lower RDS(on) figures than the stock FET. You'd have to take a look at what is under the FET and make sure that you weren't bridging anything. I wouldn't do it.
AO4468 is also used on other drivers, most common one is probably the 3-toroid SRK drivers. If you have any dead drivers laying around it's worth a look.
edit: Also, I doubt there is any other FET out there that will survive having the resistor bridged. Being a boost driver, the input current isn't self-limited by the LED voltage like in a DD setup, and that's why these same parts survive fine in other driver designs but not in this one.
Yeah, donât bridge the resistor
My comments on replacing the FET were not intended to facilitate bridging the resistor, just decreasing the resistance. Itâs still not a great idea either way, as I mentioned.
I got confused when making these adapters. Do not use them, they are clearly wired wrong. I knew better than to do this and did it anyway - oops. Iâll re-attack the problem and get it right next time.
OK, v04 -> v06. Now the adapters should be functional, but after that last mistake I wouldnât trust me if I were you.
I didnât bother to keep track of what order the pins are in now compared to where I thought they were with the previous version of this adapter. They are in the order that was easiest for me to route while still making GND and VCC connections. So the firmware I posted above (and never tested of course ) may need some tweaks to work with this board. Pins 2, 3, 5, 6, & 7 are all straight through. Pin #1 on the ATtiny (PB5) goes to the location of Pin #4 on the PIC (GP3).
I think there is no interest in running STAR on this light using the stock levels, but for the record I think the latest firmware I posted has an error. It looks like I forgot to set âRUN_PINâ to output along with the MODE_X pins.
its nice that you can tune each mode separate ,if you glue a small piece of copper on top of the chips zeremefico exploted might solve the problem?
I have replaced the mosfet but I noticed that the sprint of the driver gets really hot after some seconds of running. I worry that might some other components have damaged, except the replaced mosfet. Using a fet driver with star firmware is my next step, what do you think?
11Amps is lot ,maybe add copper braid to the spring
Do not bypass these resistors. Bypassing a boost driver which does not have an additional limit is bad. For example, people do a bypass on Fenix boost driver sense resistors, but those drivers have a 4.5v voltage limit. That keeps the current from getting so high that it destroys those drivers.
The spring getting hot may be normal. If so, a copper braid mod is in order. Maybe comfychair or someone else can tell us. Did you remove the bypass?
An FET driver will require you to put the emitters in parallel.
I removed the bridge that caused the mosfet meltdown. I am planning to use a noctigon triple in parallel. xpl would be great but they are damn expensive for now.
