That’s pretty good output Tom - 1100 lumens and 97kcd stock. It seems the addition of our upgrades to this model have now made it best performer in its class - single 18650 light. That’s no small achievement.
What is the anodizing? The latest 2X was in matt black and looked very classy. How does this one differ?
This is shinier - looks more common. Maybe you can see in pics in the OP - definitely not matt black, but Amanda told me it cost more on the M12... Weird, but I like it and seems like high quality... Wish I knew more bout finish's though...
This light could prove very popular with HD2010 fans.
That was a great wee light 1-2 years ago - ran round 45-50k? stock - but only available now in various cloned forms which are often poor quality - as you know.
This M12 lifts the quality to a high level, and boots performance up to Olight levels of 2 years ago. Powerful wee unit.
Good thing is that at 98kcd stock it can be boosted to 210kcd with just a 10 minute dedome - and 210kcd is a very strong performer = 916 meters ANSI. That’s seriously good for a little belt mounted walker light. Makes it ideal for hunting too - very small but thumping output.
Interested to see what you get from it fully modded - 300+ would be massive from a wee single.
We are after high performance scope mounted hunting lights and to date we are using two 18650 batt models which are longer and heavier. In this context the M12’s smaller size is significant - esp with its similar power output to the M24 and 2X maxtochs.
It is really an impressive light from the reviews. I hope Amanda can help us to reflect our opinions about the dielectric layer to their engineers. We want direct-copper MCPCB.
Pulled the LED - confirmed not direct thermal path - no continuity, but if you see the tracing on top of the star, it's pretty apparent there is a layer over the surface of the star that continues under the pad. K - will attempt to sand/grind it out...
Ok - finished the mod to the MCPCB. Sanded then scraped out most of the dieelectric layer, fillin the void with solder paste, piled up, then reflowed the LED - looked good. My concerns:
no extra solder flow out of the center pad, maybe didn't use enough?
wear/tear on the LED from the reflow (used hot air from below, but took long to melt the solder)
I did a couple of tests, so maybe didn't allow enough cooling off time
Before: on a fresh 26700 (KK) 5000 mAh cell, 6.42A: 1,462 - 1,377 lumens, throw: 120 kcd @5m
Now: on a fresh 26700 (KK) 5000 mAh cell, 4.22v, 6.10A: 1,612 - 1,455 lumens, throw: 130 kcd @5m
This is an improvement, but not as much as I thought. Also not sure why I'm only getting 6.1A now when before I got 6.42A. Maybe unreliable amps measurements - little tricky to work around the fat 26700, or something else is going on. Also, the 150 lumens drop in 30 secs is fairly high - probably attributed to the poor bonding of the star to the pill top (uneven pill top). I added more thermal grease and still didn't see any squeezed out after screwing it down.. Hhhmmm....
Improving emitter cooling (like going from standard aluminium to Noctigon) increases Vf. Probably seem thing with the mod you did to the mcpcb. Increased Vf resulted in lower amps but at the same time higher output.
Yes - that's the general pattern. Agree - could be right there with the better thermal path up'ing the Vf. Thought my XinTD X3 got higher lumens (domed LED) even at 5.X amps - gotta check #'s. I know the XinTD X3 had outstanding OTF. Of course best is maybe my TN31, measured 6.2A at the LED, and over 1,800 OTF lumens (domed stock LED) - but you got a rock solid big copper direct thermal path MCPCB, and nice buck driver with bridged resistors, and much bigger reflector, good qual AR lens, etc...
True, should be in the 3.2 to 4A range, depending on the cell. With the stock 5000 cell they offer, it's pretty good. It's really in the range of a modded light. Two cell lights, like the M24 would be better if you want more runtime - classic tradeoff of runtime vs. size/weight.
The drop is higher on the M12, but there's more to lose with a DD at much higher amps, while the X3 is using a stacked Nanjg. The X3 has advantages with sheer mass, big chunky pill top, but of course it weighs a ton too, but the smaller width reflector results in the lower throw, but respectable for it's size.
Note: all measurements done on my home brew PVC lightbox and $35 meter, so no guarantees
