Appreciate the review ToyKeeper. Thank you for the photos. I’m preferring the black after seeing these, maybe the orange. After reading this, for me, I’m glad I didn’t preorder one, too long. I may go back and have a look at the original orange Nichia however. Thanks again….
FWIW, the switch isn’t a forward clicky. To turn it on, the user must fully click and then release; it won’t turn on until the button is released. However, a light tap while on will turn it briefly off to change modes. So, it’s a reverse clicky instead.
A forward clicky would come on with a light tap, and only require a full click in order to stay on. After full activation, a light tap does nothing on a forward clicky.
To turn the light on in “medium” mode, a reverse clicky would be “click, tap, tap”. To do this on a forward clicky, it’d be “tap, tap, click”.
Thanks for the review ToyKeeper. My order of Tiara A1 got canceled by HKE because they are out of stock. I’m thinking of getting the T10T now but I’m not sure because L10C looks interesting too with that Nichia and well spaced modes. The only thing that kept me from buying an L10C a few days ago is the $15 shipping. I could just add a little amount of money and get the T10T with that titanium goodness.
I just bought a T10T and debating buying a D25A Ti. I already have the L10 and love it but I love titanium so much! Not sure if I want to spring for a L10C now or wait to see if they do mpre color options
The T10T NW is pretty nice. The main complaints I have about it are: no “low” mode, and no way to get rid of mode memory. The L10 and L10C have what I consider a nearly-perfect mode selection, and I love how it always starts on the lowest level… not to mention the best tint available anywhere. It’s not even a tint, really — it’s just white.
The L10C is still a small light; it’s just longer than I thought it would be. The length isn’t such a bad thing though, since it’s easier to hold. The original L10 sometimes felt like it was almost too short.
I should add a shot comparing it to the popular SK-68. The L10C is tiny in comparison.
The $15 shipping definitely makes things difficult though. That makes the two lights practically the same price.
If you’re interested in the D25A Ti, you might want to look for an older model, or wait until next year. The ones currently available are kind of … not so great. I ordered one in January but they ran out, so I didn’t receive it until EagleTac made a new batch. And it seems the current batch has issues: Review: EagleTac D25A Ti 219 (mid-2014 botch, er, batch)
If the D25A actually lived up to its specs, it’d be an awesome light. But mine is way off spec in several ways, and some of those are systemic issues that pretty much everyone seems to have (others seem limited to just this batch). For example, it claims there’s no PWM… but that’s just blatantly false and has been for a long time. What concerns me most is that the moon mode is forty-seven times brighter than any other “moon” mode in my collection, and therefore not a moon at all… and the AR lens turned a high-CRI neutral-white Nichia 219 into a low-CRI yellow beam with a bright blue ring around it. It’s a really nice host, but I kind of want to rip its guts out and replace them with something else. If it were large enough to fit a qlite in, I probably would have done so by now.
First time I’ve ever been unhappy with a light with a price over $10.
FWIW, I ran a low mode runtime tests on my twisty L10 219 using old Eneloops (~1600 mah by a C9000) and got 49 hours at what I meter to be 2.5 lms (47/ET lumen scale). Great regulation, it should do 60 hrs on a 2000 mah cell, so the spec is way understated.
I’ve been wanting to get accurate numbers for runtime on the L10 / L10C, but I don’t really have good equipment to test it.
All I can say is that it feels like it lasts a lot longer than spec, and the closest I’ve found to a measurement also suggests the same. Selfbuilt measured medium mode on an alkaline cell and got 7 to 8 hours, and when I’m primarily using moon and low, a battery lasts almost as long as it would in a Zebralight. So, I was guessing the 30 hour figure was a very low estimate. Plus, selfbuilt’s graph (medium mode) shows the L10 getting higher efficiency than any other lights near the same level.
Maybe I should just leave one on and check it manually to get a ballpark estimate. No nice graphs like some reviews provide, but at least a better idea how long “low” lasts. I suspect the 60-hour estimate is probably pretty close.
Don’t have any more tools than you - I have to manually check the light in the light box every xx hrs and log it on a piece of paper - a PITA.
I did run a medium test as well - 7.5 hrs @ 20 lumens on a ~1600 mah Eneloops so call it ~9 hrs on a new cell. I usually don’t test the higher modes - I rarely use high modes so don’t care, don’t want to burn my lights up, and rather rely on SB’s results. My lumen scale is, of course, going to be significantly lower than yours/Selfbuilt for reasons we’ve previously discussed, but at least we seem consistently in the same ballpark.
Last night, just two nights after I got a couple L10Cs, I apparently managed to damage both of them. D’oh. Or, at least one of them anyway, and the other one stopped working.
I was going out for a bike ride and tested my black L10C first as sort of a force of habit. But it didn’t turn on. I came back in to do some tests, and determined that the pill no longer responds to power. No idea why. I used it an hour earlier and it was fine, and nothing happened to it.
So, I swapped it for my grey L10C and went out. While getting onto my bike though, I somehow managed to snap it on something which pulled it away from the place it was clipped and flipped it downward onto the concrete. It still works fine, but now it has some dents on the head and tail. All my older L10s are now in better condition than my brand new L10Cs.
I’m a bit confused about the black one just suddenly not lighting up any more. If I had dropped it or something, I’d assume I managed to damage the driver. But nothing happened to it; it simply stopped responding to power after sitting unused for an hour. Maybe a solder joint is loose or cracked, and I could fix it myself. I’m not sure. But when I tried to remove the pill, I discovered that the L10C pill is apparently glued in a bit more firmly than the old L10 pills. I couldn’t get it to budge.
