Review: Skilhunt H02 Headlamp with Full HD Video Review and Pictures.
Thanks for another nice review and entertaining video.
So not really any low voltage protection then? In reality the drop to the low (only available) level would be a pretty obvious sign of battery depletion. I would be curious to know at what voltage the lowest level kicks in if that's a simple test. I would be happy to run my Pannys to 2.5V but not some of my other cells.
No low voltage. But the light blinks before it steps down. But yeah it just keeps running and running. If you’d like I could throw one in and see how long goes or if it ever dies? For time constraints I cut the tests short, but the 2.6ish volts is quite low anyway so I figured most people probably wouldn’t run it that low. I find that most of the time when I’m using a light on a higher mode and it starts to significantly dim I throw in another battery anyway.
Thanks for the kind words on the video. I spend a lot of time on them, and try to throw in jokes and a few visual gags to keep them interesting. I’m probably the only person who writes an entire script for a flashlight review
I reckon there a quite a few of us that appreciate the videos mate. Always well done!
No need to run the light down more than 2.6V but I would like to know at what voltage it blinks and steps down to the lowest level. In other words, approximately when is the cell too far gone to support anything but the lowest level?
(Slightly OT, did you ever work out what was the issue with the Spark SG reverse polarity malfunction. My nephew is looking for a AA headlamp and I was a bit concerned after reading your review some time back.)
No, I wound up donating it to a member here. It was screwed up for sure- I wouldn’t trust a Spark for reversed polarity protection and they never got back to me about it either. I also began having problems with the SG5. The run times all significantly dropped (nearly in half) for both NIMH and 14500 batteries. Also the light flickers quite often and I have to smack it to get it to stop- until it starts again. Looks like some people had some flickering problems from that recent group buy too. Mind you I never abused the SG5 like I did the SG3, other than testing runtimes and letting it run about a dozen or more times until the light turned off. I’ve got a Fenix HL50 light coming and an Armytek Tiara I’ll do some reviews on.
I’ll get back to you on the H02, hopefully in a day or two.
Just read the SG thread again today. Seems your SG5 had some runtime quirks from the outset. I've been very happy with my SD73 and SX5, though I get a peculiar shorting problem with some AAAs in the SD73 from time to time. Still can't work out what's happening. Anyway - that's OT
No rush on the voltage issue with the H02 - whenever you get time will be fine.
I have the first version Armytek Wizard Pro (with the software bugs still in-situ) so doubt I'll be buying the Skillhunt but it seems like a pretty nice light for those who don't want to spend the extra cash on the Wizard. I was interested in the Tiara Pro so look forward to your comments on that and the HL50 in due course. Let's hope Armytek have got the Tiara right first time.
It blinks at 3.28v on high which is around the 2.5-3.0 hour mark. It does not blink at the initial 800-500 lumen voltage step down that happens in the first ten minutes of run time.
Thank you for the excellent review. I made particular note of the tint differences between the Wizard Pro and the Skilhunt. I take it that Skilhunt only offers a cool white tint?
Just for the record, I have a Spark SD52 NW 2-AA headlamp and it is rock solid in performance, reliability and durability.
As of the time being they only offer it in cool white. A neutral would be quite nice, as would a warm like the Wizard. Glad to hear about the Spark, I’m likely one of the unlucky few.
thanks. So the blink is a pretty good warning to change the cell. Really wouldn't want to drop much below this if possible.
How about a video of it.
What is difference between H02 and H02R version? Photos show different reflector.
I can’t say what the difference is. Are there any reviews or specs on the other unit?
MHanlen, or any of y’all, do you know if there is room for a protected cell in this light?
Yes I use a panasonic 3100mAh protected
yes!
i just hoppped in my basement and tried…
the tube has 19mm inner diameter and 65mm unprotected flat top pulls work as do my 70,5mm protected panasonic
(i have the old model with round optic)
oh - btw: i have a code to get it for 39,99 :wink:
At 1:42 in the video I show using a 3400 shoshine protected cell or a panasonic 3100mah unprotected cell. I have a variety of cells at home and it takes every protected or unprotected 18650 I throw at it.
Thanks for all the information, I just pulled the trigger with on this with a great discount code. Should be a great worklight for inside electrical cabinets.
Once again, BLF rocks!
-Ford
Glad you liked it! I’m currently working on a review for their new color headlamp- if you don’t need RGB then this is a great choice.
I like this type of review.
Showing me how the light’s use with magnet, outdoor, stream, etc.
Good video commentary.
Thank you!
which btw you can now find here:
