Don’t have any more tools than you - I have to manually check the light in the light box every xx hrs and log it on a piece of paper - a PITA.
I did run a medium test as well - 7.5 hrs @ 20 lumens on a ~1600 mah Eneloops so call it ~9 hrs on a new cell. I usually don’t test the higher modes - I rarely use high modes so don’t care, don’t want to burn my lights up, and rather rely on SB’s results. My lumen scale is, of course, going to be significantly lower than yours/Selfbuilt for reasons we’ve previously discussed, but at least we seem consistently in the same ballpark.
Last night, just two nights after I got a couple L10Cs, I apparently managed to damage both of them. D’oh. Or, at least one of them anyway, and the other one stopped working.
I was going out for a bike ride and tested my black L10C first as sort of a force of habit. But it didn’t turn on. I came back in to do some tests, and determined that the pill no longer responds to power. No idea why. I used it an hour earlier and it was fine, and nothing happened to it.
So, I swapped it for my grey L10C and went out. While getting onto my bike though, I somehow managed to snap it on something which pulled it away from the place it was clipped and flipped it downward onto the concrete. It still works fine, but now it has some dents on the head and tail. All my older L10s are now in better condition than my brand new L10Cs.
I’m a bit confused about the black one just suddenly not lighting up any more. If I had dropped it or something, I’d assume I managed to damage the driver. But nothing happened to it; it simply stopped responding to power after sitting unused for an hour. Maybe a solder joint is loose or cracked, and I could fix it myself. I’m not sure. But when I tried to remove the pill, I discovered that the L10C pill is apparently glued in a bit more firmly than the old L10 pills. I couldn’t get it to budge.
Just picked up a D25A Ti from 2012 to go along with my new T10t. Cant wait to get them in so I can do a nice review of all of these lights.
Do you think that all the L10C mifht have the problem you discovered or shall I order one now? Id assume since the L10 was perfect that it might just be select ones that have issues???
I’ve been meaning to… just ridiculously busy the past few days, and I probably will be for a few more days.
I can assert that not all have the issue I ran into, since my other one got thrown onto concrete and still works fine. And as soon as I get the L10C pill out, I might be able to determine what the issue was… I just need to get myself some leather work gloves so I can actually try to unscrew it while it’s heated up. And, of course, find time to do it, which might be scarce this week.
Thanks for the review. I bought one for my dad and one for myself, but had to wait until yesterday to really play with it as I wanted to give him first choice on the color.
The l10 had been on my radar for some time for an edc light but the clip concerned me and I want sure I’d like a twisty. When I saw the l10c, it was an instant order and I’m really impressed. The modes are great (moonlight seems brighter than specs, need to compare it to my zebralight h52), I love the switch, the beam is very nice and the effeciency is one of the best in class. My zebralight h52 is still my go-to backpacking light, but the price on the l10c makes it a very affordable and effective edc for me. I may even bring it as a backup for my h52.
FWIW, Zebralight’s moon modes are low even by their own lumen scale. After calibrating my light box so that it matches my ZL SC52 almost perfectly (from 2.7 lm to 108 lm, anyway), I get about 0.10 or 0.11 lm for the “L2a” mode spec’d at 0.34 lm. And I get about 0.07 to 0.09 lm for my various L10 units, on that same scale. My other Zebralights are also lower than spec, but that’s okay since the level they actually run at is almost perfect for my purposes.
In any case, you may find that your L10 moon mode is very close to the highest moon mode on your Zebralight, despite the specs being different by a factor of about 3. And I think this is due to an error in ZL’s specs, not an error in L3’s specs.
That’s great info. I suppose I was a little biased as I remember reading (selfbuilt, I think) that the L3 L10 moonlight mode was widely variable between lights and I assumed the same would be true for the L10c. When I noticed that the moonlight mode seemed brighter than my H52, I assumed I had one of the brighter L10s. That will teach me to assume, eh?
I don’t have a way to do any objective measurements myself so thanks for the correction. And either way it ends up, the L10c modes are pretty close to perfect for what I need out of my pocket light. The moonlight mode is nice for checking on the kids when they are asleep, low is great for inside a computer or under a desk, medium is a decent walking around in the woods level and high is not a bad “WHAT WAS THAT SOUND?!” level.
Moon modes do tend to vary a lot more than other modes, on pretty much all lights. At such a low power level it seems more sensitive to the variation in individual components. However, Zebralight still tends to measure low on moon modes, and the L3 L10 measures a bit closer to its actual spec. On average, that is… but some L10s are quite a bit brighter on moon than other L10s.
I took my broken L10C apart today, the one which spontaneously stopped working for no apparent reason. At least, I took the pill out of the head. I had to heat it up to melt the glue, but after that it was pretty easy.
I’m not 100% sure, but it looks like the black wire may have simply disconnected itself from the driver inside the pill. Bad solder joint or something, probably just cracked and fell off. Fixing that promises to be interesting, since the only way to get at it is to unsolder the MCPCB wires then unsolder the driver from the pill. Maybe remove the foam battery pad first to avoid melting it. I’ll probably wait until I’m not quite so busy.
However, that aside, I have more L10s to test now. It should be interesting to see how much the output varies from unit to unit.
Oh, also, it seems that the newest 2014 batch of non-clicky L10-219s now use the 219B emitter. I just discovered that yesterday, and it was a pleasant surprise. They probably won’t be very available until old L10 stock is cleared out though.
ToyKeeper - Thanks for the review. Do you happen to have an L08 in addition to your L10 and L10C? It would be cool to see a picture of the whole family standing next to each other.
Nope, I don’t have a L08. I don’t really have any interest in one, since it’s mostly just a L10 with a fraction of the battery capacity. However, selfbuilt did a nice review on it. http://www.candlepowerforums.com/vb/showthread.php?383111
Sorry for all the delays; I’ve been extremely busy lately and haven’t had time to do much on lighting projects or reviews.
I know what you mean. I lost interest in the L08 when I saw how big it was. The only reason I would ever use AAA instead of AA is because of the smaller size.
Once that’s out of the equation we’re just left with an inferior light for no good reason.
Lol is that really how you read that or are you just ribbing me?
Assuming you weren’t kidding, when the AAA version of this light is not appreciably smaller (not to mention the regulation/runtime getting butchered) there is no reason to get the L08 for me.
Oh really? I still prefer the 219A. I hope Jake keeps the 219A’s, or at least put the older ones aside for separate purchase. I wonder if the L08 219’s are A’s or B’s? They may have a bit of stock left over
Nice looking light, but i would have prefered keeping the twisty head for selecting modes and a forward clicky for on/off. Like an improved version of the Fenix E11, ideal for the none flashoholic family members and as gifts to friends.
