Gday Ric, I just tried to buy a couple of items but it keeps asking me to select a shipping option. But there are no options for shipping to choose from. Same result in Firefox and IE.
EDIT: Never mind I found out why. I logged in just fine to the site but my personal details are all screwed up. I needed to correct that.
Top right of page, click ‘my account’.
On the left side is some options, look for consignee address.
Check your address in there.
I found it differently, but it was my address that was wrong. No country was selected so postage couldnt be calculated I guess. As soon as I fixed that, I had a postage option.
However, the options next to Country, are empty. I assume based on the lack of state and town options elsewhere that they are what should go there?
But Australia uses post codes that are unique to a street address, so even if my address is repeated around the nation many times, only one will exist within my postcode (zipcode), so it will get to me anyway with what is included already.
But might be worth looking at Ric. I tried it with other countries but those other two drop menus never fill with anything I can select.
Thanks! It fixed the problem.
After I updated the address in the account menu it still didn’t work, I had to click “modify” on the address in the cart and confirm the new address, only then it worked.
Thanks for your info here. Your operation steps are correct.
We noticed the problem too. After reloading the web date, The “country” date of old registered users are missing. So Old members have to modify and select the cuntry again before submiting the order.
Ric, sent you a PM. I’m having troubles setting my country. I select Canada, but it never shows me any selections in the 2nd menu (where I probably select which province).
I also had the same problem, so I just entered province as part of the Address field, after selecting Canada, the last country in the list.
Then the next problem is that only numbers can be entered in Postal Code field. But fortunately it is not a required field. So I left it blank and entered the words”Postal Code” and our AnAnAn alphanumeric postal code in the Sign Building field. I also identified the problem & my Postal Code in the Order Postscript field.
My order was shipped on Tuesday July 15. So my BLF SA-22 is on the way, but before the clean sale price was offered.
So Canadiens can find a way to make it work. Hope this helps fellow Canucks.
