Supfire A6-T6, nano-review
26 posts / 0 new
djozz
djozz's picture
Last seen: 12 hours 40 min ago
Supfire A6-T6, purchased from farfarled (DHgate store, no Paypal!), payed $17.92. type: 1x18650 battery, XM-L led, smooth reflector, tail clicky.
It is of similar quality as the Convoys and Eagle Eye's, but this model is a bit different, a bit wider head and tail compared to the tube-style lights. The finish is great, everything fits well and comes apart easily, there's no unpleasant surprises like hollow pills and such, there's a good heat path from led to pill to body, the body has enough meat in the right places that the heat can spread well, without the head being too fat the reflector throws noticably better than the tube style lights, with a distinct hotspot, the switch is not too tiny (unbranded), the driver is 17mm, modes:high,mid,low,strobe,SOS (a familiar driver, same as in the Eagle Eye flashlights: high PWM, good mode spacing), led is on 16mm board, fujik-glued to the pill (there's room for a 19mm board, but the wire-holes are too far towards the middle, you need to drill new ones), stock the OTF-output is 600 lumens.
I'd say it has everything to easily make a fine pocket rocket of it, and that is my plan with one of them. I am considering to make a quad light of another one, it fits the 4x XP Carclo optic nicely Smile
Exploded view:
other arrangement of the parts:
some dimensions:
standard C8-pill does not fit
Edited by: djozz on 07/06/2014 - 14:35
Werner
Werner's picture
Last seen: 1 year 1 month ago
Thanks for posting the innards…
Until now I thought this light was dark grey, just checked the dhgate offer and it looks different for me.
RaceR86
RaceR86's picture
Last seen: 4 years 8 months ago
Thanks for the review/teardown. Smile
BLF LED database – collaboration spreadsheet and latest news about where to buy LEDs
http://budgetlightforum.com/node/19342
Tom E
Tom E's picture
Last seen: 9 hours 4 min ago
Looks excellent, ordered, along with this zoomie (dhgate-zoomable-XM-L2) and the C8(dhgate-supfire-c8). The zoomie looks like a deal for $12 with an XM-L2, and hopefully SupFire quality.
The pill in this A6 looks like the L6 pill - wonder if it is. The L6 pill is ~26.9 mm wide at the top, ~22.6 mm on the threads, ~18.4 mm height. If it does match, then it should be the so-called standard C8 pill.
Ejected Filament
Ejected Filament's picture
Last seen: 2 years 3 months ago
Thats a substantial opening in that reflector?
Thanks for the review djozz.
Ejected Filament
Edit: Deleted
djozz
djozz's picture
Werner wrote:
Thanks for posting the innards... Until now I thought this light was dark grey, just checked the dhgate offer and it looks different for me.
It is dark grey, my phone camera apparently finds grey boring and makes it brown (at any white balance setting).
I will post a list of dimensions tonight  as well.
djozz
djozz's picture
added some dimensions in the OP, standard C8 pill does not fit, for who cares: MT-G2-dome fits very nicely in the reflector hole Smile  (but i would not count on a nice beam)
WarHawk-AVG
WarHawk-AVG's picture
Last seen: 4 months 4 weeks ago
Very nice! Give us a update you drop in the quad star and Carclo, how much current does the stock driver push, could you bump it up with a mod?
Nice threaded reflector too…good review..thanks!
djozz
djozz's picture
WarHawk-AVG wrote:
Very nice! Give us a update you drop in the quad star and Carclo, how much current does the stock driver push, could you bump it up with a mod? Nice threaded reflector too...good review..thanks!
I will give an update on the quad mod, it will have to wait though, another project comes first. The current, wait, a couple of minutes....
djozz
djozz's picture
there you go, tail current bypassing switch, on high, on a semi-loaded NCR18650PF:
I measured lumens a bit more thorough, now it is 568 on high, 318 on med, 43 on low. Hmm, not that great mode spacing after all...
There's the two r120 resistors that are in series with the two FETS, those can be lowered. But too low, or shorting them will cause the modes go funny or when shorted vanish: just high at 4.5 A. (ledsmoke and I did some attempts on EagleEye lights)
Cereal_killer
Cereal_killer's picture
Last seen: 10 months 4 days ago
I like the look of this light cause it reminds me of my old quark, would it be possible to get a shot standing next to a tube style light (like the convoy S series) so I can get an idea how much wider it is at the head & tail?
Does the light fit in a standard holster for an S series?
djozz
djozz's picture
I do not own any Convoy holsters, but here it is next to a Convoy S5 and a Eagle Eye X2 (the S5 is the slimmest Convoy tubestyle light).
djozz
djozz's picture
I did a one-evening-mod on my Supfire A6-T6 because I want to take it out camping the day after tomorrow (the quad mod I will do on my second unit, it will take more than one evening)
The fastest way to make a FET-driver for it was to turn a qlite into a 'NANJG92', comfy-style ! I followed The Great Tutorial to the letter and it did of course not come out as neat as comfychair's  , but it works like a charm:
I changed the led to a XM-L2 6A1 80CRI on a 16mm Noctigon. I put a thick stiff o-ring between the reflector and the ledboard-retaining-piece-of-plastic to have the reflector push the board onto the pill (the original board was not clamped down but glued to the pill, this one only has arctic silver 5). I braided the tailspring. Now I have 4 amps (tail measurement without tailcap/switch), and 37-55-320-970 lumen in beautiful 3700K high CRI ! (on a NCR18650PF battery).
Cereal_killer
Man I want one of these, I was PM’ing with that seller that posted the video of the light in the 18650 section, he’s got them for $17 and I want one so bad but I just ordered my GAW lights and don’t have money for another light right now. Sad
I would need to find a driver (most likely MAKE a driver) but it’s be awesome as a RGBW light with a quad in it.
Tom E
Tom E's picture
The UniqueFire C108S I have match's up to this pretty well in size - head diam is an exact match and the Carlco quad optic with the quad board fits. I've been taking some measurements. The C108S is maybe not as robust as the A6 - pill is smaller, takes a 16mm star, but does have a brass ring in the alum pill for soldering the driver while the A6 has the brass screw-in retaining ring. The brass solder ring seems like it's a thing of the past - I only see it in my older lights.
djozz
djozz's picture
Missed this post. Yes it is the exact same form factor, nice that there's another one around. I like the looks of the Supfire best, but there will be some who will prefer the Uniquefire  Smile
djozz
djozz's picture
I have put yet another driver into the Supfire A6-T6. I had done a bench test of led4power's new driver, and I have put it into this Supfire now. It has cost me a bit of the maximum output, but the lower modes are better and more efficient. On a NCR18650PF, current is now 0.02 0.07 1.07 3.9 ampere, output is now 5 20 290 760 lumen. efficiency at max (3.9A) is 52 lm/W, on med (1.07A) it is 67lm/W, on low 70lm/W. I like that!
Now, there was some discussion, I think it was in the X6-thread, on low modes being useless in a thrower; well, this flashlight is not a real thrower, but has a fairly 'throwy' hotspot, and I can state here that the lowest 20mA/5lumen mode works extremely well for pathfinding, enough light in the spot for looking ahead where you are going, without destroying night vision much. And 140+ hours of runtime of course Cool.
Tom E
Tom E's picture
djozz - so do you think your 2nd A6-T6 is a replica or fake? Heard from a China source there might be replica A6-T6's around...
Here's your thread on it: http://budgetlightforum.com/node/32998
Ejected Filament
Tom E wrote:
djozz – so do you think your 2nd A6-T6 is a replica or fake? Heard from a China source there might be replica A6-T6’s around…
Here’s your thread on it: http://budgetlightforum.com/node/32998
Mine appears to be different so maybe..
My pill has two round divots to twist it out while djozzs has a two cavities that you can see extend down the sides of the pill. Mine do not.
Driver (excuse the phone pic …and shake)
It appears black, its not, its very bronzey grey. Almost a shade of desert camo if that makes sense. The o rings are brownish, not red, same as found on my XinTD X3 purchased from the recent GB.
djozz
djozz's picture
E.F., it looks like yours is the same as my second one:
I guess it really was Supfire doing the changes, and in the end it does not matter much, this version's quality is still better than average.
Ejected Filament
Edit:
Low 0.27
Med 1.20
High 2.34
Recently (a week maybe) fully charged HE2, using decent leads linked by comfychair on ebay, with copper alligator clips and a reasonably decent automotive use DMM.
BTW, thanks for the link comfy, they fit perfectly.
JaredM
JaredM's picture
Last seen: 7 hours 55 min ago
Yes. I know this thread is from 2014. But it’s October, so it’s okay to wake the dead..
Anyhow, I remember this thread from the start, as I always had this light on a list somewhere, but never pulled the trigger. Now that I’m looking for Carclo quad host, this came back up. One detail that always kept me from this light was the hefty-for-tube light dimensions and the $20+ price. But it’s a different age here, and I have a new idea.. and a question..
*Is there enough meat in the battery/body tube for this to be bored out to accept a 21700? Could someone measure the O-ring groove diameter (generally the thinnest point) ? *
If 21700s were to fit (with machining), I think this would be the most-bestest quad host around. The length given up by going to the quad optic would provide the extra length needed for the longer cell. I might add a lighted-FET tailswitch, too. Beer
djozz
djozz's picture
Sad
JaredM
JaredM's picture
Dang. All that meat and they taper down the threads that far.. Facepalm Sad
Oh well, I guess. 18650 will just have to do. Tailswitch quad hosts are hard to come by.
JaredM
JaredM's picture
BTW, thanks for the pic djozz!
