so i got my new L2T and i do not have my dropins yet ...
i figured i would test continuity after reading the SF XPG dropin post , well the LP has a forward clicky also when i depress both slighty i get continuity , the L2T after the click has none while the other one does maintain continuity , i tested a reverse clicky it maintain a circuit
this is certainly a bad switch right ???? i dont have my dropins yet from MF but still, should i wait or email SF
2nd issue - very disappointed to hear forward clickies have issues with multimode droppins
i put the good forward clicky on a two mode light and it would not cycle the modes !!
I'm not sure what your question is? There is no problem (in general) with forward clickies and multi-mode lights. Some people don't like using forward clickies with multi-mode lights because once clicked on they can't change modes without clicking the light off first.
I prefer them but just realize that I have to choose the mode before I click it on (or turn it off when I want to change modes). I like them for the momentary feature.
If you have a bad switch that's another matter of course.
If its just that its a forward clicky - you might be able to swap in a regular Solarforce L2 switch
If its that some may have a small momentary glitch that changes modes on you as you turn it on - Not really - other than swapping out the drop in or switch ...
